Old 05-21-2007, 07:54 PM   #1
wceoscar
My Ride: 323i
Finally installed HID kit
well today i just proceeded and installed the kit... i must say this was a PITA.
Me and my cousin removed the headlamps to clean them and stuff... i must say this is the worst headlamp I've ever worked on (everything is so close and it takes loads time to make it fit right...
My kit was an h7 based kit: When installation time came i opened the bulbs and poured some silicone on the outer surface of the bulb... then i inserted in the headlamp and let it dry (i had to do this since this kit didn't came with the bulb cover like the OEM halogen bulbs did)... then i installed the ballasts... one near the intake air-box and the other one i just attached the mounting bracket near the radiator (didn't found any other place to hold it) then i proceeded and mounted the ballast on the mounting bracket...
Everything works good just didn't liked so much the color 6000k (white) i love when it burns on, its like bright white with a crisp of blue... maybe they will be like this when hey burn on.
What worries me is that the engine compartment gets to damn hot so does the ballast, now could this be an issue on the ballasts life???
Also does glueing the bulbs with silicone is this right??
wceoscar is offline   Reply With Quote
Old 05-21-2007, 11:01 PM   #2
whosechariot727
My Ride: 2001 325i
Send a message via AIM to whosechariot727
I was told you should mount the left ballast on the windshield washer fluid tank. Ive never heard of siliconing bulbs in, but id think it would shake because silicone is like rubbery.
2001 325i
5Mt, Black on Tanin
Light Gunmetal ZHP Reps
CF Csl Trunk
Tinted Tails
4300k P46's
20% Tint
whosechariot727 is offline   Reply With Quote
Old 05-22-2007, 12:03 AM   #3
M3kka
Banned
My Ride: Another Make Vehicle
I just installed my HID fogs on saturday and boy does this car look 120% better than when i had halogens on both headlights and fogs. I had the hid headlights and halogen fogs and thought they were alright but after installing the fogs, definitely looks a lot better.
M3kka is offline   Reply With Quote
Old 05-22-2007, 04:03 AM   #4
wceoscar
My Ride: 323i
yes it definatly looks better... so who else has glued the bulbs with siicone??? i dnt thonk hey will shake cause it is a thight fit.
Old 05-22-2007, 04:14 AM   #5
hapalover
My Ride: white e46
take some pictures and post them up
hapalover is offline   Reply With Quote
Old 05-22-2007, 07:44 PM   #6
wceoscar
My Ride: 323i
Here are the pics of the ballast location
Old 05-22-2007, 11:33 PM   #7
whosechariot727
My Ride: 2001 325i
Lol I hope i get those brackets with the P46's aka prolumen kit.
2001 325i
5Mt, Black on Tanin
CF Csl Trunk
Tinted Tails
4300k P46's
20% Tint
Old 05-23-2007, 12:59 AM   #8
jlcool007
My Ride: E46 330ci Smoked Out
just make sure those ballasts DONOT get wet!!!!! my last car burned down cause of that....
_FOR SALE_ (below)
***staggered style #68 330ci spt. pgk. wheels w/ PS2's***
***full set amber 2001 330ci lights***
***99-01 coupe smoked corners***
Jason Le Blanc's Facebook profile
jlcool007 is offline   Reply With Quote
Old 05-23-2007, 04:10 AM   #9
wceoscar
My Ride: 323i
what you mean with burned up????
anyways these ballasts get pretty damn hot since the engine is near them...
Another thing i wanted to know is: does silicone melt with heat???? my bulbs are saftened with silicone.
Old 05-23-2007, 04:35 AM   #10
sillieidiot
My Ride: '06 AW 330ci
they won't melt, but they might burn.
the p46's should have the ballasts mounted right on the headlights.
Old 05-23-2007, 04:54 AM   #11
wceoscar
My Ride: 323i
you mean the bulb will burn or you mean the silicone???
Also, are my ballasts in a good location?? jlcool007 just scared me by saying his last car got burned because of this. why should the ballast produce a fire?? arn't they waterproof.
Old 05-23-2007, 05:03 AM   #12
sillieidiot
the silicone.
for the one on the passenger side. i'm not so sure. why don't you try to hang/tie them with zip ties from the bumper shocks? they are untouched there. that's what i did when i had the older gen p46's. i just ziptied it to that, and put some double sided tap between the ballast and the bar. not to hold it, but for padding in case i hit something. worked fine until i sold it to go OEM
and only some ballasts are waterproof. but the connections going to them may not be. his may not have been waterproof therefore shorted and some how caused a fire
Old 05-23-2007, 05:10 AM   #13
wceoscar
My Ride: 323i
ohh ok i understand now... my connections are waterproof exept for the plug that comes from the car to the ballast... the from th ballast and uo eveything uses seals.
Old 05-23-2007, 12:30 PM   #14
wceoscar
My Ride: 323i
can i have a few pics of your systems... where you mounted your ballast and stuff.
Old 05-23-2007, 04:13 PM   #15
sillieidiot
sorry i went OEM. so i don't have any pictures. but if you take out your headlight. it's the black horizontal rod that's connected to the bumper reinforcement bar. that's what i ziptied them too.
