Old 05-22-2007, 05:28 AM   #1
globol
My Ride: 2002 330ci
Send a message via AIM to globol
HID lens COLOR MODDING
has anyone on here modded their hid's (swapping out lenses, bend shields, using washers to get a cleaner cut off line) I heard e46's projectors sucks compared to other oem manufacturers. Wondering has anyone done it and what are your results? heres some example i found online. the this pic is an E46 with ECE lens (its pretty much clear all around the lens, my cars hid len's has this split line through the middle i heard they are E46 BOSCH DOT lens)
Now this is the same projector using washers to increase the distance from the lens to the shield and bulb, using 3 washers
and now with 4 washers
I also read some where that 330ix has the better lens of the e46's they dont have the split line in the middle and their cut off line is cleaner. They use ZKW lens, which are better than ECE ones. I have a 02 330ci and the cut off like looks like **** compared to these pics.
globol is offline   Reply With Quote
Old 05-22-2007, 05:57 AM   #2
vision_promo
My Ride: M3
Sweet!!!
.45.hwf.HH.
vision_promo is offline   Reply With Quote
Old 05-22-2007, 06:23 AM   #3
grzes12n
My Ride: SRT8
grzes12n is offline   Reply With Quote
Old 05-22-2007, 06:48 AM   #4
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
The horizontal line you see in the projector has nothing to do with whether it's a 'good' or 'bad' projector. The horizontal line is on the bi-xenon projectors, no line equals single-xenon.
russ330 is offline   Reply With Quote
Old 05-22-2007, 08:10 AM   #5
BrianJ1888
My Ride: 330i ZHP Imola Red
where'd the stagger go? did this guy set up his lights to blind oncoming traffic?
BrianJ1888 is offline   Reply With Quote
Old 05-22-2007, 08:29 AM   #6
sstainba
My Ride: 02 325Ci
So I have a question about this whole "bi-xenon" and "single-xenon" thing. When did BMW make the non-bi-xenon lights ?
sstainba is offline   Reply With Quote
Old 05-22-2007, 08:30 AM   #7
sstainba
My Ride: 02 325Ci
oooo... and another question... what the hell does this have to do with color? and why is this *exact* thread also posted on this forum under "has anyone modded their HID's?" ?
Old 05-22-2007, 10:11 AM   #8
mister wiggles
My Ride: 2009 335i x-drive
Send a message via AIM to mister wiggles
will this work with p46's they don't have a shield inside the projector. its just a lens and a hole for the bulb to go into.
edit. ok i see the shield. what do you use to bend it? its so stiff and i can't take it out of the projector.
mister wiggles is offline   Reply With Quote
Old 05-22-2007, 11:27 AM   #9
russ330
Mod Squad
russ330's Avatar
bi-xenon = Xenon low beam and high beam
single xenon = Xenon low beam and halogen high beam.
Bi-xenon lights were introduced for the E46 in 2002 (maybe '01).
Old 05-22-2007, 02:08 PM   #10
globol
My Ride: 2002 330ci
I wish i could answer all your questions, But I'm still trying to research this. For all you who are wondering why the light is pointed so high. The person who took this pic has the Hid Projector/lens out of the headlight housing they tweaked it using washers shined it against the wall and took some pics and tweaked it more and took some more. With the reference to the bi-xenon and single xenon i'm not sure. I'm sorta surprise no one has brought this up in the forum. I did a search and couldnt find anything in here. Check out http://www.hidplanet.com/forums theres alot of stuff about modding hids.
Old 05-22-2007, 04:17 PM   #11
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
that is frickin cool. I wish my HIDs had a straight cutoff. I'm scared to take them apart and mess with them though
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 05-22-2007, 04:53 PM   #12
n3985
My Ride: E92 soon?
Those pics are from HIDplanet.com right? They are not ECEs, they are all E46 DOT bi-xenons. An ECE single beam has a slope cutoff like below:
n3985 is offline   Reply With Quote
Old 05-22-2007, 05:09 PM   #13
globol
My Ride: 2002 330ci
are you sure? but after modding you can make the cut off straight no? I have Bi-xenon and my slope is the same as the picture you posted. where i got the pic i posted its from hidplanet.com also.
Old 05-22-2007, 05:16 PM   #14
sillieidiot
My Ride: '06 AW 330ci
you can make it straight. it requires cutting the shield straight. extremely hard to do. even a small mistake shows up when the xenon is against. it. bending it back make the cutoff sharper, but only to a certain point. using the washer mod adds color, but will eventually make the cutoff fuzzier.
Old 05-22-2007, 05:17 PM   #15
globol
My Ride: 2002 330ci
well all i know is that we can mod/or change our lenses to our hids to get a better cut off line or focus more light towards the center.
Old 05-22-2007, 05:18 PM   #16
sillieidiot
yes, you can do that with almost any projector for that matter. i will probably take a go at it when my warranty is up.
Old 05-22-2007, 05:35 PM   #17
russ330
Mod Squad
russ330's Avatar
Don't worry, I got it, check the post above yours.
There's not a lot that hasn't been brought up in this forum before. I know I have personally answered the bi-xenon versus xenon question many of times. If your referencing doing a color mod on projectors, yea, that's come up before too.
Old 05-22-2007, 06:03 PM   #18
PYRITE
My Ride: 1965 Ford Mustang
This is with 19 washers
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 05-22-2007, 06:12 PM   #19
globol
My Ride: 2002 330ci
hahahaha
Old 05-22-2007, 06:13 PM   #20
sillieidiot
lol nice chance to post that pic up. pyrite. you should take a new picture at night. that way i can use it as a wall paper.
