Old 05-22-2007, 10:35 AM   #1
dwj100uni
My Ride: 318 Ci Coupe
Instructions to Fit Angel Eyes
Hey all,
I have done a search but cant find any useful info...
I was wondering if anyone had an install guide on how to fit Angel Eyes (any type) to my e46?
I just want to make sure I will be OK with fitting before I make the purchase.
Thanks,
David
dwj100uni is offline   Reply With Quote
Old 05-23-2007, 12:37 PM   #2
DVS1
My Ride: 2001 330ci
http://www.fastm.com/m3/angeleyes.html
DVS1 is offline   Reply With Quote
Old 05-25-2007, 08:30 AM   #3
paraklas
My Ride: ESS TS2 320ci
Total time: 2 Hours.. P E R F E C T!!!!!
Before starting, remove excessive dust from the headlights. You don't want dust particles falling on the xenon projectors!
Good packaging for their international journey.
The inverter: Indeed no OBC error
Preliminary testing:
Indicator out:
Bottom headlight trim must be removed as well
Headlight cover out (Watch the clips) 3 on top, 3 on bottom and one on the left side:
Also remove the rubber on top of the headlight covers (5 clips)
Mount the ring on the high-beam reflector
Mount the ring on the bi-xenon projector
I run the wires out through the rubber boot of the highbeam assembly. I know the inverter should be inside the headlights but I couldn't find a nice spot to put it. For now it's under the black metal that holds the radiator.
To work easily, remove the airbox. Gives you a lot of space
Placed the black trim back
Place headlight cover back on, again watch the clips!
I wrapped the inverters with self-amalgamating tape.
Ok, here I used high-temp silicone (not necessary but that's what I had) to seal the small gap between the rubber boot and the headlight where the cables come out.
Connected all cables now, placed heatshrink, then self-amalgamating tape, and then water resistant pvc tape.
Final Results
More photos tonight!!!!
You can still see the rings even with the xenon lights on.
Old 05-25-2007, 08:31 AM   #4
paraklas
Night Shots!!!!!!!!!
Old 05-25-2007, 10:49 AM   #5
ca1242
My Ride: 2003 330i
Nice work.
Looks like someone needs to do some engine compartment cleaning!
Old 05-25-2007, 11:05 AM   #6
xPhantom
My Ride: 2003 BMW M3 (TiAg)
Send a message via AIM to xPhantom
my friend has a kit like this... and we didn't know where to tap it to.. or how to tap it.
can you show a picture of your tap?
xPhantom is offline   Reply With Quote
Old 05-25-2007, 11:32 AM   #7
ca1242
My Ride: 2003 330i
This is what most people use (fan wire in ECU compartment)
Old 05-25-2007, 12:12 PM   #8
paraklas
Originally Posted by ca1242 View Post
Nice work.
thanks
There was fine sand in the air coming from sahara, and it rained as well so the car is a real mess right now. will do the proper cleaning soon
Something I didn't mention, I secured the ring brackets on the reflector using 90sec clear epoxy glue
Old 06-04-2007, 12:33 AM   #9
Bimmerguy57
My Ride: 2003 BMW 330CIC
I would have it done by a good Bimmer mechanic.I have a guy if you live in Illinois
Bimmerguy57 is offline   Reply With Quote
Old 06-04-2007, 01:44 AM   #10
mfanatic325
My Ride: '01 911 Turbo
paraklas, where did u get ur kit from? I'd like to know >=D
mfanatic325 is offline   Reply With Quote
Old 06-12-2007, 12:27 AM   #11
ExcelonGT
My Ride: 04 330ci ZHP 6-speed
do these same directions work for the Predator Chromium kit? Also, I believe i have to bake the headlights for 20 mins since i have an 04 Facelifted coupe (ZHP). Is the remote kit installation just as easy as running the brown wire into engine compartment and taping into the interior lights? My end result is that I would like the angel eyes to turn on when unlocking the doors and turn off when locking the doors and turn on with the fogs and low beams. I'm having a hard time finding a good DIY guide for my scenario. the ones i do find dont mention anything about baking the headlights.
ExcelonGT is offline   Reply With Quote
Old 06-12-2007, 01:21 AM   #12
mfanatic325
Ex.......contact JleviSW they can help you out. The Chromium kits come with installation instructions. You will need a "remote kit" ($10) for the fade-in/out features you speak of. Other than that, regular install should get power from the engine
P.S. btw, you're right about needing to bake your headlights as you're a facelift coupe. I also had to do this. It's not difficult after the first time =] just take your time doing it, all will be ok! OH, and when you buy a kit, make sure it's for your facelift coupe, as FL coupes have different angel eyes (full circles as opposed to partial circle rings)
Old 06-14-2007, 06:08 PM   #13
MatthewLFD
My Ride: 550i 6spd + Corvette
I tapped into this wire for my angel eyes and they stay on after I shut off the car. Sometimes its only for 5 sec, but other times it can be a minute or two. Anyone else have this issue?
Is there any other wire in the ECU box that I can tap that would shut off with the ignition (or at least a few seconds afterwards consistantly)?
MatthewLFD is offline   Reply With Quote
Old 06-14-2007, 07:48 PM   #14
Kmoy2002
My Ride: 2002tii, 540i, 330i
I just did this exact wiring yesterday with my setup and so far it is doing what it is supposed to do.
Did you make sure you attached it to the accessory wire? I know there is another wire that looks exactly the same but is not the accessory wire
Kmoy2002 is offline   Reply With Quote
Old 06-16-2007, 12:29 PM   #15
MatthewLFD
Yep, I hooked it to the same wire in the picture. The pin layout was a bit different, but the bundle of wires is the same (color, number or wires, etc).
Old 06-16-2007, 03:11 PM   #16
BimmerZealot
My Ride: N/A
That is the ECU accessory wire, if you're fan is on after you turn off your car or any other accessory the angel eyes will stay on. As long as you make sure they go off after a short amount of time you will be okay. Mine stayed on about 30-40 seconds after I turned off and pulled out my key. I was able to use it to light the walkway as I took off my shoes, etc.
BimmerZealot is offline   Reply With Quote
Old 06-16-2007, 06:28 PM   #17
paraklas
http://www.ssdd-motorsport.com/
Got them for a year and still running as bright as the first day
Old 06-16-2007, 11:38 PM   #18
mfanatic325
how much did SSDD charge you? They should've been $90 at the MOST
Old 06-18-2007, 03:42 AM   #19
BBB543
My Ride: 02 325i
Send a message via AIM to BBB543
question:
what is the pink/white and brown wire go to? (from the pic in post 13)
BBB543 is offline   Reply With Quote
Old 06-18-2007, 08:13 AM   #20
paraklas
!! 90 not $90!
