Old 05-07-2002, 07:04 PM   #1
328ciMontreal
Question need help? is this normal?
when i turn the fan off in my car (climate control) , it will go on automatically...i think its the defrost. sometimes, its on (not on auto) and it will go up and down by itself.
Is there a setting for this?
328ciMontreal is offline   Reply With Quote
Old 05-07-2002, 09:03 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I am not sure...
about the setting, but sometimes when I set the temperature and turn on the AC, I get a funny smell for like 5 minutes then it clears out (or my nose gets used to it ) and it seems fine...ne one else have that problem?
Old 05-07-2002, 09:20 PM   #3
first323
too old for this crap
My Ride: 07 Acadia,06 4MOTION
Re: need help? is this normal?
If oyu are talking about the fan speeds changing on their own and you having no control of it no matter what you do then it is the same problems I had. Mine would go on and off and changes speeds and i could not do anything about it. It is a sensor in the AC unit, I forget the name, that regulates the fan speed and temp. iIt should be replaced under warranty. I hadmine replace din August of 2001.
2006 VW Passat 3.6 4MOTION & 2007 GMC ACADIA SLT-2
first323 is offline   Reply With Quote
Old 05-07-2002, 09:59 PM   #4
emi323i
E46 Pioneer
My Ride: none
the smell is "normal"...
according to bmwna... the only thing i gotta say say to that is ... "pffft... wha'eva'..." anyway... you can't fix it, the only thing you can do is disinfect the condensator thingy, every now and then.
emi323i is offline   Reply With Quote
