Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Old 05-28-2007, 11:55 PM   #1
nick@cunningham
Banned
My Ride: A lot of BMWs
Send a message via AIM to nick@cunningham
Attention SoCal E46 Owners!!!
BMW is coming out with a new line of their own Performance Parts. These parts will be backed up by warranty nor will they void vehicle warranty. BMW NA is planning on releasing these parts late June. At this time only e46 and e90 parts will be available.
Here is a list and brief description of the first parts to be available.
BMW Performance Parts - Destined to be released in late June, early July.
BMW Performance Wheel/s - 18" (E46 E85 E86) - 19" E90 E91 E92 E93
- Machined for less weight, up to 2 pounds lighter than conventional wheels
- Two-tone ferric gray polished surface with BMW Performance wordmark
- Largest technically viable wheel/tire combination released by BMW
As far as I know there is only one design available, I assume more will come as the performance line grows.
BMW Crossed Drilled Rotor - (E46 330i, xi only)
It's pretty much a E46 M3 Competition Package rotor, but its made for the non M cars.
I believe the setup uses stock pads, however there might be an alternative. I'll know more in the future.
BMW Performance Strut Brace - (all 6cyl. E46 M54, E90, E91, E92, E93 (not 335i, yet) Intake air box gets in the way.
- Increased stability and structural stability when cornering.
- Extremely lightweight using hollow carbon profile and brackets made of aluminum
I've seen a pic of this bar and its pretty clean. Its all CF and it says BMW Performance in the center. It curves towards the center of the motor, it is not straight like other strut bar designs.
BMW Performance Suspension - (E46 [not 330i, no sport suspension 226] E90 from start of production)
- Lower suspension setting of 15mm (depending on model)
It looks like there will be some type of shock and spring combo. I'll have to check the catalog again but it looks like BMW will be offering a sport shock. I think it uses the OEM spring but I don't know. ( I dont have the catalog infront of me)
BMW Performance Control Arm - (E46 330i [not with option Performance Package] or other with option sport suspension 226)
- Stiffer bushings condsiderably reduce roll and increase responsivness
Pretty much a beefer control arm. When I get a set I'll compare part numbers with other ZHP arms to see if they are the same.
BMW Performance Differential - (E46 330i [not with option Performance Package] as from 9/2000 onwards
- Boost Power transformation from 2.93 to 3.07
- 5% increase in axle ratio increases torque delivered to the ground
- Accelerates up to 60mph approx 1/2 a second faster than the standard 330i
I do not know if it is Limited Slip or not, I sure hope it is.
BMW Performance Engine Kit (e46 330i [not with option Performance Package] from 03/2003 with MS45)
- Increases engine performance to 235hp
- Boost torque by 8 ft/lb
- Raises redline to 6,800 RPM from 6,500 in regular 330i
Basically a Cam kit with software. It looks like it will be rather affordable.
BMW Performance Shift Kit - (E46 325, 330i [from 03/2003] E90 E92 E93) available 07/2007, other models in preparation
- Reduce shift travel by approx 25%
BMW Performance Exhaust - (Designed for e46 and M54 cars 325, 330i)
- Increase engine performance by up to 5hp at 6,000 rpm
- 8.8 lbs lighter than stock
- Two adjustable stainless steel tips on the rear muffler giving the exhaust a unique, high-tech look
BMW Performance Air Intake System - (E46 M54 330i, 325i)
- Increases engine performance by 3hp
- Additional inline scoop reduces system losses by 24%
nick@cunningham is offline   Reply With Quote
Old 05-29-2007, 12:30 AM   #2
happybmw
Are you happy
happybmw's Avatar
My Ride: 03' 325 XI
thx for the info, will there be an exhaust system for the e46 XIs?
happybmw is offline   Reply With Quote
Old 05-29-2007, 12:44 AM   #3
nick@cunningham
Banned
hopefully in the future
Old 05-29-2007, 10:14 AM   #4
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
Wow, cool info! Thanks for the heads up!
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
Old 05-29-2007, 10:39 AM   #5
clean-m-tech330
My Ride: Technik 330ci ZHP
Send a message via AIM to clean-m-tech330
Basically what this is, is BMW making theh ZHP m54 parts available- see how everything excludes the zhp for the most part... why don't they just call it what it is, zhp performance parts, OEM- thanks for the info nontheless- when you guys get some "motorsport" parts... let me know!
'00 Honda Civic Si- B18c5 210whp- Sold-
'05 BMW 330Ci ZHP- Technik's ZHP - Sold
'06 Acura RSX-S- Sold
'07 Subaru Satin White Pearl STI - Garage Queen
'11 Honda Civic Si Sedan - Daily
clean-m-tech330 is offline   Reply With Quote
Old 05-29-2007, 06:52 PM   #6
nick@cunningham
Banned
dont worry ill be posting regularly when the parts come out and when new parts are comnig soon.
Old 05-29-2007, 07:06 PM   #7
L73087
My Ride: 05Alpine 330CI ZHP
+1 HAHA Instead of just selling intakes and suspension BMW needs to make more forced induction kits at affordable prices not dirt cheap prices of course but not DINAN prices I guarantee everyone would be buying these cuz you wouldn't have to worry about stupid ass warranty issues I dunno thats just my $.02
L73087 is offline   Reply With Quote
Old 05-29-2007, 10:41 PM   #8
SDSundevil
My Ride: 2004 330ci ZHP
Questons for Nick
1-Is the exhaust an upgrade over the zhp exhaust?
2-Is the air intake paper filter or oiled?
3-Are the stated gains in intake and exhaust(3/5hp) the same for zhp and non zhp, i.e. would my zhp be 243hp with both upgrades?
4-Do you have pricing???
I'm very interested, but nervous about pricing.
http://forum.e46fanatics.com/signaturepics/sigpic36448_2.gif
SDSundevil is offline   Reply With Quote
Old 05-29-2007, 10:42 PM   #9
SDSundevil
Mostly
The intake is all new, I'm not sure about the exhaust?
Old 05-29-2007, 11:06 PM   #10
nick@cunningham
Banned
I agree, an OEM, CARB legal FI kit with a warranty would sell like hot cakes. However, would BMW jack the prices because of all the cool features? (CARB legality, Warranty, etc)
As of right now no prices are available. There is only one catalog available per dealer and only employees are allowed to see it. I am not sure if these parts will upgrade your ZHP. Once these parts are available, I'm going to try and talk my dealership into letting me get a back to back dyno of the parts installed on a demo car.
I'm sure the intake will have a paper filter. Same as OEM. However, I'm sure a K&N will fit just fine.
Old 06-16-2007, 05:14 PM   #11
Surfcal
My Ride: 04 330i ZHP
Hey Nick,
Do you need a demo car? I have an 04 ZHP sedan, stock except a UUC TSe3 exhaust and am willing...
Surfcal is offline   Reply With Quote
Old 06-16-2007, 05:15 PM   #12
mycool
My Ride: needs rims 325i
i could be a demo too :]
bmw 325i 2001
|smoked corners|smoked side markers|Umnitza angel eyes 6k|benferCAI|xenon interior|
|xenon match fogs|chrome ambers|blackoutgrille|LED license plate lights|smoked tails|
CF emblems|cf gauge overlay| Gauge Rings|Projectors!|6k HID kit|CUSTOM CF eyelids
Project:CSL
mycool is offline   Reply With Quote
Old 06-16-2007, 06:21 PM   #13
patdeezy
My Ride: a grey e46 sedan
Send a message via AIM to patdeezy
interested in x drilled rear rotors for my 330!
-m330-
EUROPROJEKTZ
REALIE CLUB 2007 - I'M KEEPIN IT REAL!
SPONSORED BY
|SGC Godfather|
KOBE in 2012
patdeezy is offline   Reply With Quote
