Old 05-31-2007, 12:34 PM   #1
Elusive
My Ride: '02 325i, '04 ZX-10R
Aftermarket Headlights
Has anyone switched out stock to an aftermarket brand, which ones are preferred, I was looking at some one piece headlight and turn signal units that also had angel eyes preinstalled, any suggestions??
Elusive is offline   Reply With Quote
Old 05-31-2007, 01:13 PM   #2
roy.jovero
My Ride: 2000 328i
P46's?
roy.jovero is offline   Reply With Quote
Old 05-31-2007, 01:19 PM   #3
Sam 330ci
My Ride: 3 Pedals - 3 Litres
Send a message via AIM to Sam 330ci
Theres a whole forum dedicated to lighting, i only have like 30 posts so I'm as much a n00b as anyone but . . .
. . . search.
Sam 330ci is offline   Reply With Quote
Old 05-31-2007, 01:30 PM   #4
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Send a message via AIM to 2000_328CI Send a message via MSN to 2000_328CI
that said, i went from oem halogens to Projector46s with 6k xenon angel eyes, 6k xenon low beams, and 6k xenon fog lights.. i also bought 6k led turn signals for the front,.
call up the guys at jlevisw.com and they will help you out
angel eyes, turn signals, and fogs
full setup at night
Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244
Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM
Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI
Old 05-31-2007, 01:49 PM   #5
Sam 330ci
full setup at night
Hey when you did that, did you need to re-program your ECU? Are you getting any bulb failure lights on the dash?
I'm thinking about it but would rather keep halogens and have no annoying llow beam failure messages like I had on my e36
Old 05-31-2007, 04:15 PM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
If you are looking for aftermarket headlights go with our Projector46's. They are complete headlight replacements that have preinstalled Predator Series angel eyes and our ProLumen HID kits. This is a fully comprehensive kit that includes everything you need for the complete install and is plug and play. Here is the product page for more information:
Projector46 Headlight
Old 05-31-2007, 04:23 PM   #7
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
+1
Old 05-31-2007, 04:23 PM   #8
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
+1
Old 05-31-2007, 04:42 PM   #9
numba1guju
My Ride: 2013 328i
Send a message via AIM to numba1guju
if your wanting to get rid of bulb failure put a resistor in and youre good to go
2002 325i: Black/Black
Mods: Clears, VM V715 Matte Black 19in staggered, 20% tint all around, Suspension Technique Coilovers, p46s 6000k w/ aurora 60LED
numba1guju is offline   Reply With Quote
Old 05-31-2007, 04:58 PM   #10
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
That or just get the ECU reflashed.
Old 05-31-2007, 11:52 PM   #11
Elusive
. . . search.
Yeah so I get the whole search bit now, so I dont plan on making the same mistake again, but WTF do you just go around looking for things to make comments on and be a pen15???
As for everyone else that actually had advise, thanks
Old 06-01-2007, 09:55 AM   #12
4g63GSX
My Ride: 07 RRS 03 325 94 GSX
full setup at night
I love it...it's this guy:
Regarding resistors, LCM flash, etc. It seems to differ from model of e46 to the next on what you should do to cure operating problems. For instance, it seems for a facelifted e46 you should NOT flash the LCM, but use capacitors to help with flickering. I think the earlier models you pull fuse xx to get rid of bulb warnings, etc. It will differ depending on the model.
4g63GSX is offline   Reply With Quote
Old 06-01-2007, 01:09 PM   #13
fandy
My Ride: E46 318i 00
how bout vibrating hid lights ? (appears only at the left headlight) made a topic and they told me to get LCM flashed, 2000 318i , so what u advise?
fandy is offline   Reply With Quote
Old 06-01-2007, 03:01 PM   #14
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
vibrating? I think you mean flickering
Old 06-07-2007, 09:02 AM   #15
fandy
no, its clearly not a flicker. its vibrating...the lights stays on, it's just vibrating, the case on LED, now thats flicker...
