Old 06-02-2007, 09:59 AM   #1
jasoncrowley
My Ride: 01 325i
What am I doing wrong? Pics included of my wiring (Angel Eyes Installation)
I haven't tried to hide any wires yet or done any electrical tape work. I'm no electrician and I can't seem to find out whats wrong.
[IMG]http://www.***********.com/ims/u/1906/7849/172379.jpg[/IMG]
[IMG]http://www.***********.com/ims/u/1906/7849/172380.jpg[/IMG]
[IMG]http://www.***********.com/ims/u/1906/7849/172381.jpg[/IMG]
[IMG]http://www.***********.com/ims/u/1906/7849/172382.jpg[/IMG]
[IMG]http://www.***********.com/ims/u/1906/7849/171907.jpg[/IMG]
jasoncrowley is offline   Reply With Quote
Old 06-02-2007, 11:21 AM   #2
jasoncrowley
My Ride: 01 325i
Old 06-02-2007, 11:38 AM   #3
dragonz
My Ride: 323i
what problems are you having? angel eyes not lighting up? You'll get answers as the day goes along its too early!
is the red wire tapped into the red/yellow striped wire in the ECU?
Also check the wire prongs in the ballast.
dragonz is offline   Reply With Quote
Old 06-02-2007, 11:38 AM   #4
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
i had same problem, i wired them to my accessory wire and grounded it to some nuts. so yeah helllpppp
aphhpa is offline   Reply With Quote
Old 06-02-2007, 12:46 PM   #5
e34werkz
My Ride: F30
Should'a used a t-tap instead. Try checking the fuse and see if that's the issue.
BMWCCA Member#395677
e34werkz is offline   Reply With Quote
Old 06-02-2007, 12:48 PM   #6
jasoncrowley
My Ride: 01 325i
Yeah, the angel eyes simply do not work.
I used a t-tap the first go round to no avail...maybe I'll replace the fuse that came with the angel eyes.
Old 06-02-2007, 03:29 PM   #7
e34werkz
My Ride: F30
Be sure to wrap it up with some electrical tape. BTW, is the ground wire frayed too? I would check the fuse first, then the connections.
Old 06-02-2007, 04:10 PM   #8
xPhantom
My Ride: 2003 BMW M3 (TiAg)
Send a message via AIM to xPhantom
i would put the ground and the relay in the same spot...
that's how i did it in mine.
and for the power, instead of actually doing it where the terminal is..
do it on the other side, under the bolt.
follow this DIY: http://www.fastm.com/m3/angeleyes.html
xPhantom is offline   Reply With Quote
Old 07-02-2007, 07:15 PM   #9
jasoncrowley
My Ride: 01 325i
just in case anyone has a similar problem doing this project, I just moved my ground () and all is well.
Old 07-02-2007, 07:33 PM   #10
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep ground can cause that issue. Please wrap that ECU tap in electrical tape at the very least, that is asking for issues.
Old 07-03-2007, 12:38 AM   #11
paraklas
My Ride: ESS TS2 320ci
picture #2. I found out that using grounds like that don't always work.
there's paint underneath the nut. as others say, move your ground to the ground terminal
Old 07-03-2007, 01:44 AM   #12
AzCamel
AzCamel's Avatar
My Ride: Soon To be Boosted
Ground it to the negative terminal next to the power terminal in the open area on the passenger side. 2nd, the wire you taped into the ECU is not the power wire, it is only the remote switch to your angel eyes, wire that wire into the positive terminal and tap your remote wire into the ecu wire. If you just mistakenly said power wire when you ment remote wire then ignore the 2nd part.
02 M3 SMG Vert
Dinan 3.91 / Dinan SMG Software / Dinan ECU Stage 1 / Beyern Mesh 19's / BSW Sound / EAS LED Angel Eyes / ETC..
94 Supra FOR SALE, OR TRADE FOR NSX
Precision SP63 / Tial / Apex-i / TRD / Seibon / Do-Luck / CCW / Recaro / Eibach / Top-Secret / Greddy / ETC...
AzCamel is offline   Reply With Quote
Old 07-04-2007, 04:50 PM   #13
garodgers
My Ride: '01 325i
I would definately agree with the previous 2 posts. You can pump power into them all day but until you have a solid ground, the circuit won't close and nothing will happen. Easiest way to check this, grab a cheap multimeter from radioshack and check the measurements between the contacts (+) and (-). Good luck.
garodgers is offline   Reply With Quote
Old 07-04-2007, 08:41 PM   #14
BlkE4600
My Ride: 99' 323i
I just installed ine yesterday and had no issues. I used the spot recommended in the write-up and merely scraped away the paint behind the nut to make sure that there was a good ground.
-Bill
18" Konig wheels/Brembo x-drilled rotors/Hawk pads/Full Hamann bodykit/H&R Springs/Kenwood K617 DVD/ 2 12" Pioneer subs/Sony Xplod 1200w amp
BlkE4600 is offline   Reply With Quote
