Old 06-02-2007, 12:19 PM   #1
FullEffect256
My Ride: 2004 330i ZHP
CDV Delete: Buy the part? or just remove?
when getting rid of the CDV, what's the difference between replacing it w/ a "gutted" one and just removing it all together? I have a 2004 330i ZHP. Also, u can just use brake fluid as clutch fluid rite? Thanks!
FullEffect256 is offline   Reply With Quote
Old 06-02-2007, 12:25 PM   #2
skipm2k
My Ride: '04 330Ci 6spd.
If you replace it with a dummy you won't risk crimping the line or your warranty.
skipm2k is offline   Reply With Quote
Old 06-03-2007, 11:40 AM   #3
r6vr6
My Ride: 2002 ///M3
I just took mine out. I believe the clutch uses fluid from the brake master cylinder. So just make sure that you replace the fluid you bleed off.
r6vr6 is offline   Reply With Quote
Old 06-03-2007, 12:39 PM   #4
raptorman5174
My Ride: 330i ZHP
would it be possible to just to take the CDV valve out, drill it out and put it back in? wouldn't that be that same as buying the actual part that cost like 30 bucks?
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 06-03-2007, 12:58 PM   #5
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
you could run the risk of metal flaking in your system. best you let the pros do it. ^
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro NC dealership.
Eurobahn BMW is offline   Reply With Quote
Old 06-04-2007, 09:38 PM   #6
raptorman5174
My Ride: 330i ZHP
i was thinking, remove the piece, put it in a drill press. use a small drill bit to drill it out. Of course you would clean it with wd-40 or some other type of parts cleaner before reinstalling it to avoid metal parts flaking off into your system.
18 VMR CSL's
Koni
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
Old 06-04-2007, 10:01 PM   #7
Eurobahn BMW
Eurobahn BMW
tell me how it goes and i might send it to you. if you can beat the 30 dollar drilling price for the the website.
Old 06-05-2007, 01:40 AM   #8
paraklas
My Ride: ESS TS2 320ci
why drill it and not keep it in case you need to put it back. if your tranny fails the dealer might blaim the missing valve.. would you risk for $30?
I bought an empty one and kept the original
Old 06-05-2007, 01:51 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Just replace the whole line with an SS line. Cheap little upgrade.
Old 06-05-2007, 07:43 PM   #10
r6vr6
My Ride: 2002 ///M3
Drilling it out yourself and cleaning it good should be okay. Mine is out of warranty so I am not trying to full anyone by putting ti back in.
Old 06-05-2007, 10:39 PM   #11
FullEffect256
ordered the modified valve and installed it today... car drives great... do you think the dealer will notice/care about the changed valve? don't see how it harms anything
Old 06-05-2007, 11:38 PM   #12
jlcool007
My Ride: E46 330ci Smoked Out
it slows the reaction (in this case from dropping the clutch) and shock to the driverterrain
_FOR SALE_ (below)
***staggered style #68 330ci spt. pgk. wheels w/ PS2's***
***full set amber 2001 330ci lights***
***99-01 coupe smoked corners***
Jason Le Blanc's Facebook profile
jlcool007 is offline   Reply With Quote
Old 06-23-2008, 07:33 PM   #13
zactastic
My Ride: Merlin nonfixed gear
Send a message via AIM to zactastic
where's the CDV DIY?
-Zach
"There is science, logic, reason; there is thought verified by experience. And then there is California." -Edward Abbey
"Learning from experience is a faculty almost never practiced." -Barbara Tuchman
...the mod bug got me and my Alpine 330ci;there's a list somewhere...
zactastic is offline   Reply With Quote
Old 07-25-2008, 09:52 AM   #15
tony325ci_51
My Ride: BMW 335i 2007 Coupe
CDV Removed. Big improvement in clutch engagement feel.
tony325ci_51 is offline   Reply With Quote
Old 08-01-2008, 02:53 AM   #16
DOB2009
My Ride: 325i
Any one know how important the power bleeder is for the CDV removal??? It just turns this DIY from free to a lot more $...
DOB2009 is offline   Reply With Quote
Old 08-01-2008, 06:31 AM   #17
tony325ci_51
It's not important if you know how to bleed clutch and brakes properly and have a friend who can press a pedal up and down when you tell them.
I used a drain tube with a one way valve that's cheaper than a pressure system, but does mean in between opening each bleed nipple you have to pump the pedal a few times, then top up fluid reservior. It's easy enough though. You don't have to bleed the brakes at the same time, but I thought as I had the car jacked up and was messing with brake fluid, drain tubes and stuff I may just as well take the wheels off and bleed the brakes at the same time.
You still can't do it for free, there's some cost and preparation involved, but yes it's cheaper without a power bleeder:
http://forum.e46fanatics.com/showpos...5&postcount=17
Old 08-01-2008, 10:53 AM   #18
sdbimmer
My Ride: 2004 325Ci
or just for fun you can make your own power bleeder. Good for Clutch and Brake bleeding.
http://forum.e46fanatics.com/showthread.php?t=513282
http://www.bmw-m.net/TechProc/bleeder.htm
sdbimmer is offline   Reply With Quote
Old 08-03-2008, 05:19 PM   #19
tony325ci_51
I had a pressure bleeder once, Gunson's I think it was, it used to hook up to a spare tyre to get the pressure. I found the job easier to do without hooking up a pessure bleeder, and as for making one, I could do the entire job quicker than I could make one so nah, not for me.
Old 08-11-2008, 03:10 PM   #20
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Ordered from Zeckhausen today
Gonna do this and the clutch stop at the same time
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
