Sponsored by BAVSOUND
Old 06-05-2007, 02:52 AM   #1
rcurley55
My Ride: 2001 IR M3 Coupe
My latest install inside
So, I've never been shy about showing my installs, what did work, what didn't - so why stop now - get ready, this one is going to be an interesting experiment!
Here's the ride (nice work on the porta crapper in the back eh... )
So I decided that the theme of this install is stealth and integration. Essentially, I don't want to see a piece of gear, but if I do, I want it to look as oem as possible.
So let's start with an equipment list:
Alpine TME-M740BT - 7" wide/touch screen w/bluetooth
Alpine VPA-B222 - Vehicle Hub Pro
Alpine NVE-N872A - DVD Navigation
Alpine CHA-S624 - 6 Disc Changer w/ Optical
Alpine PXA-H701 - Multimedia Processor
Alpine KCE-422i - High-Speed iPod cable
Alpine PDX-4.150 - Front Stage Amplifier
Alpine PDX-1.1000 - Subwoofer Amplifier
SEAS RS165F - Lotus Reference Components (Active)
JL Audio 8IB4s (4) - 8" IB Subwoofers
So, as you can see, that's 10lbs of $&^! to put in a 5lb bag
And onto the install....
Life's too short not to be M-Powered
rcurley55 is offline   Reply With Quote
Old 06-05-2007, 02:54 AM   #2
rcurley55
Now, my car started off as non factory, but I scored the parts from a fellow fanatic - Open up the door and this is what we get - nice space for alpine goodies
Peel back the carpeting, and this is the mounting system:
Well, that's a start...a ton of mdf brackets, hacking away at the oem bracket, and a few iterations later (with a crazy install procedure) we get to this:
And if we replace the carpet and take a look at the results, I'd say it's looking ok
There's just barely enough room back there for the gear + the MILES of wire needed ton install all of this stuff. You can also see the speaker wires from my previous install back there.
This is going to be interesting, but so far so good.
Old 06-05-2007, 02:54 AM   #3
rcurley55
I still need to go back and sound deaden, but I wanted to get the brackets started first so I can measure for wires and this will lead me to installing the amps. Right now, I'm just test fitting the amps.
After the amount of installs that I've done in this trunk, the spare tire well was looking a little ratty - I had some Stinger Road Kill Spray sitting around, so I threw down a few coats, that you can see in the background.
Now these PDX's are small, but my spare tire well is even smaller - and they have to fit under the factory floor - about 2" of clearance - this should be interesting:
And that's it for right now...more tomorrow hopefully
Old 06-05-2007, 05:37 AM   #4
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
damn dude.. sounds like a strate up legit setup. GL. cant wait to see the results
BreakMyWallet is offline   Reply With Quote
Old 06-05-2007, 09:51 AM   #5
co_spgs_330ci
My Ride: 2003 330ci
Looks great! Keep taking photos and keep us posted on progress.
I have much of the same Alpine equipment and plan to relocate some of it from the spare tire well to the area under the changer. I'm interested in seeing your wiring there once it's all done. Thanks for providing updates.
co_spgs_330ci is offline   Reply With Quote
Old 06-05-2007, 11:38 AM   #6
schnitzer323ci
My Ride: 2000 323ci
Subscribed.
schnitzer323ci is offline   Reply With Quote
Old 06-05-2007, 11:57 AM   #7
Striker169
My Ride: 2003 BMW 330i
Send a message via AIM to Striker169
Nice! This is going to be pretty badass I can tell already
Striker169 is offline   Reply With Quote
Old 06-05-2007, 12:19 PM   #8
dan4081
My Ride: 2000 323i
What are you planning to do with the subs? Through the rear deck or the back seat?
dan4081 is offline   Reply With Quote
Old 06-05-2007, 12:20 PM   #9
Titansilber330D
My Ride: 330D Sport
Nice one, I am planning to do a vehicle hub/TME-740BT install in the next month or two so this thread is just what I need.
If I may be forward enough to make requests, I am particularly interested in how you connect the radio antenna and other minor wiring issues.
When I am doing mine I will be sure to reciprocate with some install pics of my own.
Titansilber330D is offline   Reply With Quote
Old 06-05-2007, 12:25 PM   #10
rcurley55
subs will be through the rear shelf
Titan - I'll cover/document all of those things - this will be a sort of diy for installing the hub in this car. I won't cover every little step (such/how I mounted the hub) but I'll cover all of the wiring.
Old 06-05-2007, 12:45 PM   #11
dan4081
My Ride: 2000 323i
[QUOTE=rcurley55;6120216]subs will be through the rear shelf
QUOTE]
Thanks, can't wait to see what you do with the rear deck.
Old 06-05-2007, 03:33 PM   #12
Titansilber330D
My Ride: 330D Sport
Thanks rcurley. Physical mounting won't be an issue, and as I have no plans to add a changer or processor I will have more than enough space. My concerns would be how you connect to the OEM antenna (do you go back up to the dash or connect it direct to amplifier in C pillar?), and how you mount/connect the IR repeater and SWI controller if you will be using those.
I don't know how long the wiring harness is for the VPA, but I don't know of a switched 12V source in the trunk (I don't have an OEM amp there). I am sure I can figure something out, but still interested how you and others tackle it.
Old 06-05-2007, 08:57 PM   #13
SrCsTc@MyBimmer.net
Past Site Sponsor
SrCsTc@MyBimmer.net's Avatar
My Ride: 00 323Ci
Send a message via AIM to SrCsTc@MyBimmer.net Send a message via Yahoo to SrCsTc@MyBimmer.net
Nice! What did you use for sound deadening in the spare tire area?
SrCsTc@MyBimmer.net is offline   Reply With Quote
Old 06-05-2007, 10:01 PM   #14
M3islove
My Ride: 2001 330Ci
looks good so far.
i love the look of those alpine amps. let me know how they work out for you, i might upgrade.
Image and video hosting by TinyPic
click above to be redirected
M3islove is offline   Reply With Quote
Old 06-05-2007, 10:03 PM   #15
rcurley55
Stinger Road Kill - rich, you have a pm
Old 06-05-2007, 10:07 PM   #16
dynamictype
My Ride: 2012 BMW 535i
Great Project!!
dynamictype is offline   Reply With Quote
Old 06-06-2007, 12:04 PM   #17
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Looks great...it's been awhile.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-06-2007, 12:09 PM   #18
rcurley55
yes, it's been far too long. the zapco setup was nice, but it lacked nav, lacked ipod integration, and it just grated on me to see speakers all abound.
then alpine released the vehicle hub pro - and well....you know how that goes.
Old 06-06-2007, 01:36 PM   #19
bigjae1976
bigjae1976's Avatar
I really like the PPI arts you had.
Actually, you should have more than 2" of clearance for the amps if you are willing to build a new spare tire well cover. You should have a lot more room.
Old 06-06-2007, 01:38 PM   #20
rcurley55
The arts were fun, but they had to go. I'm trying to avoid the new spare tire well cover - this car will look about 95% stock when all is said and done - sleeper at it's best
