Old 06-07-2007, 11:18 AM   #1
Kreuzen
My Ride: 2001 325i
Send a message via AIM to Kreuzen
Very dim P46 Ring...
It looks almost off but if you disconnect it from power it goes completely off I have verified all connections yet to no avail, it was working splendid last night and this morning. I returned from breakfast to notice one had failed, anybody have any suggestions that I can try before warranty return?
Kreuzen is offline   Reply With Quote
Old 06-07-2007, 12:07 PM   #2
sstainba
My Ride: 02 325Ci
just a single ring ? might be a bad ring then...
sstainba is offline   Reply With Quote
Old 06-07-2007, 12:15 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Nick,
Try swapping the ballast from the dim side to the non dim side and vice versa to see if the problem switches sides.
Old 06-07-2007, 05:26 PM   #4
Kreuzen
My Ride: 2001 325i
I tried hooking it up on the same ballast but tried the other power connector and the ring still is dim... I will attempt and swap ballasts from one side to ther other tomorrow morning...
Old 06-07-2007, 10:37 PM   #5
sstainba
My Ride: 02 325Ci
If only one of the rings on a single ballast is dim, then it is the ring and not the ballast. Swapping them is pointless at this point. Get a replacement ring.
Old 06-08-2007, 12:40 AM   #6
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Not necessarily, you can have a bad ballast that only causes one ring to go dim.
