Old 06-11-2007, 12:26 PM   #1
RangerX
My Ride: '03 330i / '04 Z4
Send a message via AIM to RangerX Send a message via MSN to RangerX
Predator Chromiums - Ring Install - Question
So I installed my new predator's this weekend and they look totally sick. (thanks Nick from JleviSW for the help)
I have a quick question though. The only problem I ran into was the ring install on the xenon light. When re-inserting the inlay, it kept pushing the ring back into a uneven vertical position. After playing around with them for a while, I was able to put hte inlay back in, but i had to lift up on it and force it over the ring.... which did knock it off veritcal sync a little, but not alot. After putting the light housing back together, for good sanity reasons... I checked to make sure the auto leveler was still working properly. This appears to be working fine.
My concern is the somewhat steady pressure from the inlay on the top of the ring. I'm assuming it's fine, but I was just curious. Also, I have no problem taking a dremel tool to the inlay and cutting out a section so the ring sits ok, has anyone done this yet? Is it an acceptable solution?
RangerX is offline   Reply With Quote
Old 06-11-2007, 07:14 PM   #2
330ciblackout
My Ride: 02 330cic
I haad same problem, did the dremel trick on mine.
330ciblackout is offline   Reply With Quote
Old 06-12-2007, 12:40 AM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Glad I could help out
There is no need to dremel the headlight trim. It's all about positioning the ring which should be pushed back to right before the first clip.
Old 06-12-2007, 06:48 AM   #4
ports
My Ride: '09 Audi A4
Send a message via AIM to ports
how did you guys get the ring to stay securely in place? because i couldnt push it back beyond the first clip (i have an e46 with halogens) without breaking the clip.. so instead i put it on the first clip and slipped in a few drops of clear silicone.. so it works like glue.
Nothing good can come from staying with normal cars.
ports is offline   Reply With Quote
Old 06-12-2007, 12:07 PM   #5
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
You just need to wedge it on to right before the first clip. The clip is designed to bend apart a bit and hold a friction fit to the beam.
Old 06-12-2007, 01:47 PM   #6
ports
i dunno.. i bought my raptor cwp kit from bimmian.. and it showed up without my heater inverters.. i still dont have them.. but the rings didnt seem that great to me.. the clips felt like they woul easily fall apart.. and one actually did as i was installing it.... the middle part of the U that forms the clip was all white like plastic that fogs up as it is fatigued.
Old 06-12-2007, 05:44 PM   #7
330ciblackout
My Ride: 02 330cic
That pics shows how it's done, about once a week i had to take the headlights apart to put the clip back on like that. If you are lucky to have smooth roads that would work fine. I got tired of this and made a groove for the clip, have not touched them since. I think the clips should be redesigned to a longer length, so they attach like they are designed to. Seems like a band-aid for the problem.
Old 06-12-2007, 06:04 PM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Hmm your clip must be worn loose then because they are designed for friction fit. All of our cars are installed just like that and we have not had any rings fall off, even on daily driven and track vehicles
Old 06-12-2007, 06:38 PM   #9
330ciblackout
My Ride: 02 330cic
Not ripping on the product by any means, I love them, but they did that since I took them out of the package. I dont see it as a big deal, just some thing that comes with using aftermarket parts. Like said, they have not came loose since. They are by far my favorite mod.............
Old 06-12-2007, 07:35 PM   #10
LW///M3
My Ride: 05 Sti >> E46 M3
why not use some JB weld to hold those clips in place after they are seated correctly, it would NEVER move again
2009 ///M3 Space Gray on Fox Red
LW///M3 is offline   Reply With Quote
