Old 06-12-2007, 11:28 AM   #1
Desi_2001_M3
My Ride: 2001 Bmw M3 6Spd
Question m3 covertiable led tail lights...
i have a 2001 m3 covertiable and i want to get the led tail lights put on it... what patrs do i need to order from the dealership? as much as i could find out online, you can only get them from dealeership, not from any1 outside... i went to the dealership and they said it couldn't be done...they seemed more confused than anything else...i dont have a problem installing it myself, just need to know what parts do i need to order and if someone has a DIY for it, it would be helpful...
Bottom = My Future Wife
Top = The Girl that will make me cheat on my wife
Desi_2001_M3 is offline   Reply With Quote
Old 06-12-2007, 02:39 PM   #2
airm45
My Ride: BMW330ci Convertible
[IMG][/IMG]
you need these part numbers (parts listed under Cab). you might also want to get your 3rd brake light changed too. Tischer BMW carries all the parts you need. You will also need to reflash your LCM if you get a bulb out warning.
airm45 is offline   Reply With Quote
Old 06-12-2007, 02:40 PM   #3
airm45
Old 06-12-2007, 11:09 PM   #4
Desi_2001_M3
thank you sir...any special instructions installing them?
Old 06-13-2007, 01:04 AM   #5
paraklas
My Ride: ESS TS2 320ci
If your car is dated before 09/2001 you will need a new LCM (Light control module). If it's after, you can go to the dealer and re-program your existing unit.
You also need the actual rear LED tail lights, and the wiring harness adaptor (plug on the LED tails is different than the plug on the bulb tails)
edit:
You WILL get the bulb out warning and your trafficators WILL blink very fast and you will also experience flickering on one of the tails if you don't sort the LCM; re-code or get a new one
Old 06-13-2007, 09:37 AM   #6
airm45
after getting the parts I mentioned above, it's a pretty straight forward install.
-take off the backings of your original tailights
-unplug everythiung, unscrew everything,
-take off the old weather coverings as they will not work with the LED tailights.
-attach the new weather coverings to the LED's
-Plug the retrofit adapter cables in to the LED tailights,
-plug the other end into the car.
-put in the tailights, screw in everything
-Put the new backings on
-test everything, go get your LCM reflashed
another note (to get the ABLAS ring to work, you need to follow the instructions in the thread: http://forum.e46fanatics.com/showthr...96#post1569696)
Old 06-14-2007, 09:35 AM   #7
Jason@Tischer
Your #1 OEM BMW Part Source
Jason@Tischer's Avatar
My Ride: '02 Dinan 330ci
Send a message via AIM to Jason@Tischer
LED Taillight Special w/ FREE Shipping
If you need installation instructions, e-mail me at jreighard@tischer.com and I'll be happy to send you a set over. Thanks for keeping us in mind!
Jason Reighard
Internet Parts Manager, getBMWparts.com
Email: getHelp@getBMWparts.com AIM: Jason at Tischer Follow Us: FaceBook | Twitter
Jason@Tischer is offline   Reply With Quote
