Old 06-15-2007, 02:03 PM   #1
cjeezy
My Ride: 2000 323i step
Why does my car sound like a semi truck at slow speeds in the heat?
Anyone's cars ever sound really load at times when your driving at slow speeds? Mine gets very loud, almost like its sucking in a ton of wind when its hot out and I'm in stop and go traffic.
cjeezy is offline   Reply With Quote
Old 06-15-2007, 02:07 PM   #2
BlkE4600
My Ride: 99' 323i
It's your mechanical fan...it's triggered when your temp gets to a certain level (don't know what exactly the temp is). Mine does the same thing....slowly dissipates the higher gear ya go....usuallly is totally gone by the bottom of third....correct?
-Bill
18" Konig wheels/Brembo x-drilled rotors/Hawk pads/Full Hamann bodykit/H&R Springs/Kenwood K617 DVD/ 2 12" Pioneer subs/Sony Xplod 1200w amp
BlkE4600 is offline   Reply With Quote
Old 06-15-2007, 02:13 PM   #3
slog7
My Ride: 135i
I have the exact same problem...it sounds like a loud truck but right when you go past 30mph its fine.
But this only happens on really hot days(90 degrees plus)
slog7 is offline   Reply With Quote
Old 06-15-2007, 02:26 PM   #4
cjeezy
Yeah it goes away once the speed gets around 30 MPH or so. The car runs fime, it just sounds like truck. Hopefully the car getting that hot won't do any damage to the engine
Old 06-15-2007, 03:08 PM   #5
jmueller
My Ride: 2001 330ci
its fine.. its getting loud for a reason.. i wish i could set the fan to run on a switch.. either auto or on.. i had this done in my maxima when i went to the track you could keep the car engine extra cool for more power
jmueller is offline   Reply With Quote
Old 06-15-2007, 04:27 PM   #6
ms328i
My Ride: 99 328i & 04 X5
had same problem and i just recently changed my thermostat, belts, and coolant and problem solved. so far so good after a month.
ms328i is offline   Reply With Quote
Old 06-18-2007, 04:12 PM   #7
james2538
My Ride: Sold
So this is normal?
Ugh... I thought I had a leak in the air intake.
james2538 is offline   Reply With Quote
Old 06-18-2007, 04:48 PM   #8
yanksfan e46
My Ride: 04 M3
same thing here... sounds terrible but id rather have that fan go on then overheating my engine....
"It doesn't guarantee you a world championship. If you had a phenomenal football team and spent $200 [million], you could have a dynasty. In baseball, any team can beat any team on any given day. That's what makes baseball so great." GO YANKEES!!!!
I HAVE OEM STUFF FOR SALE PM ME!!!!!
yanksfan e46 is offline   Reply With Quote
Old 06-19-2007, 11:02 AM   #9
markusmark
My Ride: 2001330Ci
Automatics have a mechanical fan that has a thermally activated clutch. The noise is the fan sucking air through the AC condensor and radiator.
markusmark is offline   Reply With Quote
