Old 06-21-2007, 10:23 PM   #1
Forester
My Ride: vintage JDM
Bi-xenon Headlight Level Adjuster Question
I was told by my mechanic that my headlight leveling sensor was broken for some time and it had became rusty when he was installing my suspension today. I was browsing through realoem.com but then I couldn't find the corresponding part. Just wondering if anyone here knows where the part is on the site, and how much would it approximately cost?
I realized my headlights are pointed towards the ground instead of pointing forward, I guess it's because of the damaged leveling sensor. Is there any way that I can adjust them before having the adjuster replaced in the panel? I drive a 2003 325i with bi-xenon headlights.
Thanks for helping!
Forester is offline   Reply With Quote
Old 06-22-2007, 12:15 AM   #2
m3m3me
My Ride: 2002 M3
hmmmm. I've modified my E46 to have quad xenons and am very familiar withh the internal workings of our headlamps. I know of nothing that can rust. There is a plastic threaded rod which captures a plastic threaded bolt, but nothing subject to oxidation. The thumb knobs you use to adjust pitch and yaw have a pinion gear which drive the threaded bolt gear. They can be past their functional range and have come out of a captive sleeve. That is repairable, but you must be brave first to remove headlamps from te car and begin dissecting them. Just look before you leap. This description sounds confusing to me and I know what it looks like. Sorry. I have a couple extra motor drives. I don't know if they're sold separate or not.
m3m3me is offline   Reply With Quote
Old 06-22-2007, 01:09 AM   #3
Painterdude
My Ride: 330Ci
The mechanic sounds like he is talking about the arm that is mounted to the lower control arm.
I've never seen one that is rusty, but I have seen them broken when someone works on the suspension and doesn't remove it first.
Did you notice your lights pointed downward the last time you drove it at night before the mechanic worked on it.
My guess and it's just a guess is that the mechanic broke the arm when he was working on the suspension.
Painterdude is offline   Reply With Quote
Old 06-22-2007, 01:19 AM   #4
Forester
Thanks for the reply.
So what does the arm look like? Is it shown in the parts diagram? And do I need to replace the arm itself or the entire system?
Old 06-22-2007, 02:38 AM   #5
eneka
My Ride: 2003 325i
when you start your car does the headlights tilt up and down?
eneka is offline   Reply With Quote
Old 06-22-2007, 08:32 AM   #6
Forester
Yes it does
Old 09-25-2007, 11:27 PM   #7
Nolimit124
My Ride: 330 XI
i have the same problem with my car its defiantly the sensor. However i dont even know what to do about the problem any help for us????????????????????????????????
Nolimit124 is offline   Reply With Quote
Old 09-27-2007, 05:27 PM   #8
e.barr
My Ride: 320ci
Hi, the part you are looking for is called an "angle joint.
Its part number in the UK is 37 14 6 766 778 and costs 7.38GBP before tax.
Its made up of two plastic/metal ball joints that are connected by a small metal rod that is bent so that it will bolt to the sensor and the lower control arm.
The joint is secured by two selflocking nuts making this an easy diy once the front wheel has been removed.
e.barr is offline   Reply With Quote
Old 09-27-2007, 10:04 PM   #9
sillieidiot
My Ride: '06 AW 330ci
Thanks for helping!
your mechanic is lying. he broke it while he was installing your suspension. the arm to that is plastic, so how car it rust? if you want to know what we're talking about. jack up your car and take off the front wheel. you should see it near the sway bar end link.
here's a picture of it, it's far so you can't see the details, but that's just where it's located:
http://www.e46fanatics.com/howto/pic...g&directory=12
Old 05-14-2009, 09:23 PM   #10
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
This part is not the part that breaks. It's the plastic part that breaks #4. You have to replace the entire sensor. That's a ~60 USD
phamine is offline   Reply With Quote
Old 08-14-2010, 12:42 PM   #11
alwaysbored786
My Ride: M3
damn i think i broke mine too, is there a way i can replace it? do zhp control arms have a place for this thing?
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 11-04-2010, 12:51 AM   #12
daonlydann
My Ride: 05 330i
I broke the front angle joint, #5 in the diagram. I forgot to remove it while replacing my struts and it came off in 2 pieces. I put them back together (shoved the black bushing back into the metal tube, but it didnt fit perfectly) My headlights point downward too much. If I replace the #5, you think it would solve the problem? It doesnt seem like it's a sensor or does anything.
daonlydann is offline   Reply With Quote
Old 11-04-2010, 12:59 AM   #13
TerraPhantm
My Ride: M3 & ZHP
Yep, they all have the hole to mount the sensor
Old 01-26-2011, 03:12 PM   #14
Orangeathlete
My Ride: 2004 BMW 330i
Most responses touch on broken parts of xenon adjustments. Since your headlights tilt up and down when you turned the car on, did you try turning the small black hand-adjust located near the back and top of the headlight?
My 2004 E46 xenon bulbs looked fine but over 6-years tilted downwards. So I left the headlights on, focussed at my garage wall, and opened the hood. I then turned the hand adjust until each one raised a little and were at the same level. Later that evening I stopped my car in a relatively dark parking lot and did the adjustment again to tweak the projection distance.
Easy fix in my case. Hope it works for you.
Orangeathlete is offline   Reply With Quote
