Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 06-25-2007, 11:28 AM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Oil change DIY (instructions & pictures)
I changed my oil over the weekend to Royal Purple and figured I would do a DIY on changing oil. The details are going to vary from car to car slightly.
Quick tool list -
** 17mm Box wrench (could also use a 17mm socket)
** 36mm socket for the filter housing (you can use a channel locks, but the socket is so much easier)
** set of jack stands
** Jack. I have a craftsman from Sears. I used to use cheap jacks, but now I will never go back.
** Use this at your own risk **
1. My car is too low to jack up from the center jack point. To get it high enough I used the stock jack to lift it up some.
2. With the car on the stock jack I could slide my main jack under the center jack point and get the car in the air.
3. I then placed jack stands at the two stock jack locations and slowly lowered the car on to them.
(had to borrow this image from another DIYs)
4. Find the drain plug and put a catch pan of some sort under it. I use a large kitty litter tray (don't ask) because of the size of it. The oil shoots out of the pan a good 12 inches so you need to either guess where it is going to end up or have a large pan. Use a 17mm socket or wrench to loosen the drain plug.
5. Once you losen the plug with the wrench you can back it out with your hand. I push the plug in with my thumb while twisting it out with my fingers. This way you are still plugging the pan while loosening the plug.
6. If you follow my directions about holding the plug in while loosening it you will have the plug fully loose but you are holding the oil in still. Make sure you pan is in the right place and quickly move the plug out of the way. If you do it right you shouldn't get oil on your hand.
7. New Filter - Thanks Tisher BMW - www.mileoneparts.com
8. Inside the filter find the rubber O ring and copper crush washer
9. While the oil is draining out clean off the drain plug and replace the copper crush washer
10. Use a big ass socket (edit - 36mm - from bimmertools.com here) to remove the top of the oil filter compartment. If you don't have a socket you can use a rag and a channel locks.
tim330i is offline   Reply With Quote
Old 06-25-2007, 11:49 AM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
11. Once you have the top of the filter housing loose I put a bunch of paper towels in that area because I always get oil on everything
12. Get a plastic bag large enough for the filter and place that right next to the housing. Pull the filter housing top up and the filter and a bunch of oil will come with it. Put it and the housing top directly into the bag. Hold the filter thought the bag and pull the housing top out of the filter. This will keep most of the oil in the bag and not on you, your drive way, car, etc.
13. Clean up the housing top and remove the O ring seal
14. Slide the new filter on the housing top. Replace the o ring seal, make sure the O ring is straight in the channel and apply a light layer of oil to the O ring (stick your finger in some oil and rub it on the ring). Put the housing top with the filter now on back into the aluminum housing on the engine block. Tighten the housing top to 25Nm or until it is "good and tight".
15. At this point the oil flow should have slowed to a drip. I like to put the plug in last as I have found that a decent amount of oil comes out when you remove the filter and you want that dirty oil out. Reinstall the drain plug and tighten. The drain plug is hollow so be very careful to not over tighten it. Better to have it drip a bit of oil (as you can tighten it later) than have it break off in your oil pan.
16. I used a bit of brake cleaner to get the oil off the bottom of the pan.
17. Add new oil. The capacity is 6.9 US quarts. I used the new Royal Purple 5w40 (details here)
18. As you add the oil check the drain plug to make sure you don't have any leaks.
19. Remove car from jack stands by reversing the procedure for raising the car.
20. Double check oil level with dip stick. Remember the oil level will change once the car is level and once you have started the car and the oil flows into all the cavities in the engine.
21. Reset the service indicator (tells you how many miles till you need to change your oil again) by following these easy steps. These are not my directions so please don't ask me about this part because I have no idea.
--The car should be off
--hold down the left instrument button (the trip odometer reset)
--while holding the key, turn the ignition to position 1 (radio)
--you will see a test menu
--keep holding the button
--after maybe 10 seconds, the word "reset" will appear
--let go of the button and press again
--The indicator is reset!"
Old 06-25-2007, 12:05 PM   #3
kaosblue
My Ride: 2001 330ci
Great write-up looks like I have something to do now this weekend.
kaosblue is offline   Reply With Quote
Old 06-25-2007, 12:22 PM   #4
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
thanks for the write up!!
btw.. how can we attach the pix like that so we can organize words with every pic?..
did you attach the pix in another thread and then relinked them?
Orz
BMWintoxication is offline   Reply With Quote
Old 06-25-2007, 12:56 PM   #5
tim330i
E46Fanatics Owner
tim330i's Avatar
Glad I could help!
I attached the pictures here - http://forum.e46fanatics.com/showthread.php?t=483439
Then I included them in this thread. It is easier than resizing them in photoshop or something first. I just let the forum software do the work and make the thumbnails for me
Tim
Old 06-25-2007, 02:37 PM   #6
FLPSIDE
My Ride: 325ci
Send a message via AIM to FLPSIDE
thanks so much for this.... great great write up!!!!
FLPSIDE is offline   Reply With Quote
Old 06-25-2007, 03:46 PM   #7
Bimmer360
Bimmer360's Avatar
My Ride: X5 4.4i V8 DOHC 32V
man! i never seen any DIY as perfect as this. This is not a good DIY, it is a GREAT and perfect DIY! Thank you Tim!
Bimmer360 is offline   Reply With Quote
Old 06-29-2007, 10:54 AM   #8
tim330i
E46Fanatics Owner
tim330i's Avatar
Tim
Old 07-05-2007, 08:13 PM   #9
Triflowm5+M3
Gear up, shut up!
My Ride: 2005 'Yota 4runner
Send a message via AIM to Triflowm5+M3
Tim,
after seeing numerous used oil analysis for RP oils, their street variants dont do well on extended pours and actually sheer to the next lowest viscosity...so if you started with a 40wt, i will probably sheer down to a mid to low 30wt.
I ran their 5W-30 in my 4.7L V8 4runner (one of the easiest engine's on oil around) and it sheered to a high 20wt only after some 5000 miles.
I would be very very watchful of running RP to 10,000 miles.
Triflowm5+M3 is offline   Reply With Quote
Old 07-06-2007, 04:47 AM   #10
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
time you are the man! now all I need is a code reader to reset the damn thing!
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 07-06-2007, 09:29 AM   #11
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
We've got them in stock...
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 07-06-2007, 11:02 AM   #12
kyle e46
My Ride: 325xi
how do you reset the service indicator?
kyle e46 is offline   Reply With Quote
Old 07-06-2007, 11:09 AM   #13
Triflowm5+M3
Gear up, shut up!
see thread
http://forum.e46fanatics.com/showthread.php?t=486429
Old 07-11-2007, 10:56 PM   #14
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
thanks so much for the DIY...
this was amazingly easy.. took about 25 minutes.
BreakMyWallet is offline   Reply With Quote
Old 07-13-2007, 05:25 AM   #15
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Excellent DIY...or you could use an oil evacuator if you're too lazy to get under the car.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-13-2007, 07:24 PM   #16
antzcrashing
My Ride: 2006 330i
thanks doing it tomorrow
antzcrashing is offline   Reply With Quote
Old 07-14-2007, 10:19 AM   #17
Elusive
My Ride: '02 325i, '04 ZX-10R
I talked to the guy at the parts counter at my local DIY auto shop, and he was saying that to run RP that the entire system should be flushed because RP doesnt work as well as it can when there is residual from the old oil, Has anyone heard about that?
Elusive is offline   Reply With Quote
Old 07-15-2007, 09:37 AM   #18
altoraltor
My Ride: 328ci
we i can i purchase royal purple
looking to buy royal purple . 5w40
altoraltor is offline   Reply With Quote
Old 07-19-2007, 04:41 PM   #19
AJ328CI
My Ride: 328 CI Coupe
what stores sell Royal Purple ? i don't want to buy 12 quarts from amazon for $100, also i'm asuming a 2000 328CI can take this also
AJ328CI is offline   Reply With Quote
Old 07-19-2007, 04:45 PM   #20
silicuda
My Ride: e30, e46 sold, e90
Great Writeup
However you forget to mention how to reset the oil service light
E46 currently for SALE - e30 in Garage, e90 325ci on order weeeeeeeeeeee
silicuda is offline   Reply With Quote
