Old 06-28-2007, 06:57 PM   #1
pwrsld12
My Ride: 325ci
Send a message via AIM to pwrsld12
fast turn signal problem, answers here!
my right turn signal (the larger orange corner) flashes excessively quick and wont run when the night lights are on.
ive searched this before and it happens to many people but i couldnt find an actual solution, just that a lot of people have it.
is the problem with the bulb, or electronics, or a fuse
easy fix or no?
mucho $$$$ or inexpensive repair?
THANKS
black on black 2001 e46 325ci 5 speed
"If you are under control you're going too slow" --Parneli Jones
***NWS SIG REMOVED***
pwrsld12 is offline   Reply With Quote
Old 06-28-2007, 07:21 PM   #2
TX
My Ride: '01 330i ZSP ZPP
Send a message via ICQ to TX Send a message via AIM to TX Send a message via MSN to TX Send a message via Yahoo to TX
I think I've heard that this happens when there's a bad connection either between the wiring and the bulb socket or between the bulb socket and the bulb itself. You could try replacing the bulb and socket. Maybe it's a good time to upgrade to clear corners?
TX is offline   Reply With Quote
Old 06-28-2007, 10:14 PM   #3
Cheezemurda
My Ride: 2002 330ci
It blinks fast because one of your bulbs are out. Probably the rear turn signal.
Cheezemurda is offline   Reply With Quote
Old 06-29-2007, 04:19 PM   #4
pwrsld12
My Ride: 325ci
i guess that could be since it doesnt turn on, i thought that was just related cut out or something.
but then the warning light that comes on is on the front of the car, not the back
Old 06-29-2007, 07:56 PM   #5
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
change the bulb?
BreakMyWallet is offline   Reply With Quote
Old 06-29-2007, 08:41 PM   #6
pwrsld12
My Ride: 325ci
where would i get a new one?
Old 06-29-2007, 09:06 PM   #7
whosechariot727
My Ride: 2001 325i
Send a message via AIM to whosechariot727
Not necessarily, i have this problem and i have no bulbs out. Another member on the forums had the same problem and found out it was corrosion on the connectors. He took all of the connectors and cleaned them and hasn't had a problem again. I'm going to do this real soon. Just my .02
2001 325i
5Mt, Black on Tanin
Light Gunmetal ZHP Reps
CF Csl Trunk
Tinted Tails
4300k P46's
20% Tint
whosechariot727 is offline   Reply With Quote
