Old 06-29-2007, 02:33 AM   #1
hammer88
My Ride: 2003 330i ZHP
Question e46 330i bulb confusion
hey fantatics,
can somebody help un-confuse me?
i'm trying to find the correct bulbs for my 330i sedan front clear corners. i pulled out the bulb and it has 180 degree offset and it also says 1156 on there.
i look on the sylvania fit guide and autozone and they both say 7506LL.
i think nick has said it's 7507 along with a couple other places. but the only thing i see 7507 for is the rear.
are some of these part numbers synonymous??
thanks for any help.
hammer88 is offline   Reply With Quote
Old 06-29-2007, 03:01 AM   #2
BimmerZealot
My Ride: N/A
7506 is the same thing as 1156, same bulb different name
BimmerZealot is offline   Reply With Quote
Old 06-29-2007, 09:05 AM   #3
sstainba
My Ride: 02 325Ci
yeah, a lot of bulbs have two different spec numbers. but in all honesty, as long as the bayonet mount pins are right, any bulb that will fit will work. some might be brighter than others or whatever... but they'll all work. :-)
sstainba is offline   Reply With Quote
Old 06-29-2007, 01:09 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
BMW was not uniform in the type of bulbs they shipped with their cars. Some are 1156, some 7507. The best way to make sure is to do what you did, pull out the stock bulb. If you perchance order the wrong offset of pins, just shave one side down and it will function just like your stock bulb.
