Old 07-09-2007, 09:52 AM   #21
sstainba
My Ride: 02 325Ci
If you have questions about any of this stuff, send me a pm. I'm happy to answer. :-D
sstainba is offline   Reply With Quote
Old 07-09-2007, 09:33 PM   #22
sillieidiot
My Ride: '06 AW 330ci
does MECP stand for something? or do i just go and look for that?
Old 07-09-2007, 09:38 PM   #23
ca1242
My Ride: 2003 330i
http://www.mecp.com
Old 07-09-2007, 09:39 PM   #24
sillieidiot
cool. thanks a lot.
Old 07-10-2007, 01:41 AM   #25
jm323Ci
My Ride: 2003 JB M3 Coupe
Originally Posted by sstainba View Post
Disconnect your ballasts one at a time and see if the fuse still blows. If it blows with both disconnected, it's the wiring itself. It could also be the relay shorted internally. So if it blows when both ballasts are disconnected, remove the relay next...
I will give that a try now. After looking at all the wires carefully and seeing for anything that maybe exposed, I found that a small part of the insulate on the power source wire was scrapped/peeled. I went and wrapped it in 2 wraps of electrical tape.
But that didn't work =( still blew the fuse. Thanks for the input guys. This sucks cause I just got my replacement ring too and then my kit decides to go all wacked on me
jm323Ci is offline   Reply With Quote
Old 07-10-2007, 07:55 AM   #26
sstainba
My Ride: 02 325Ci
well let us know what you find...
Old 07-10-2007, 10:01 PM   #27
jm323Ci
It was my ballast.
So now the question is, can any ballast work or does it have to be a Pred.Chrom one, cause I have 2 working ballast from before, only thing is the wire colors to the harness are different colors.
Does anyone have an extra Umnitza ballast around that I can buy
Old 07-10-2007, 10:09 PM   #28
sstainba
My Ride: 02 325Ci
wire color doesn't matter. all of these ballasts are the same. as long as you hook it up with the correct polarity, you're golden. fyi, you can get new ballasts from vibelights.com for $4.50 each. they look a little different cause they're cased in aluminum, but they work perfectly.
Old 07-11-2007, 12:10 AM   #29
jm323Ci
Hey thanks for the fyi sstainba Ill go check it out now.
Have you dealt with vibelights.com before?
Old 07-11-2007, 01:43 AM   #30
sillieidiot
they are great. i've used them myself for their ballasts. works perfectly with the preds
Old 07-11-2007, 09:39 AM   #31
sstainba
My Ride: 02 325Ci
Yeah, I bought two of them to replace my ballasts. Havcen't had any trouble with them.
Old 07-11-2007, 10:28 PM   #32
jm323Ci
Awesome thanks guys, this $4.50 is way better then the $25 and w/e if its aluminum. It'll be unique.
Just one thing are the + and - ends of the wire going into the ballast from the harness the same? Or will I have to DIY the connection?
Old 07-12-2007, 12:00 AM   #33
sakums20
My Ride: 02 330ci
i used the vibelights ballast and it will only light up one ring, not both?
sakums20 is offline   Reply With Quote
Old 07-12-2007, 12:46 AM   #34
sstainba
My Ride: 02 325Ci
The connections may not be the same, but it would be best to solder them anyway. Mine weren't the same (but i got ebay rings). I soldered them and they work like a champ.
Old 07-12-2007, 10:38 PM   #35
jm323Ci
hey sillieidiot, could I ask a fav. and get a pic of your hookup.(just harness to new ballast)
Im planning to go with these.
You can just PM me the pics.
Old 07-12-2007, 11:24 PM   #36
sstainba
My Ride: 02 325Ci
if you're talking about the ones from vibelights.com - they are a 2-pin connector (don't 'member if it's male or female). I just cut them off and soldered the wires. :-)
Old 07-13-2007, 12:31 AM   #37
jm323Ci
Yeah im thinking ill have to do that too if they dont work.
Old 07-13-2007, 12:49 AM   #38
sillieidiot
sorry, i no longer have them on. i took it off so i could have my headlight warrantied since there was something wrong with the auto leveling. got a brand new headlight for free though, so that's a plus.
Old 07-13-2007, 06:46 AM   #39
sillieidiot
sorry jm323Ci, just cleared my pm box.
Old 07-14-2007, 05:32 PM   #40
jm323Ci
Oh nice, getting brand new stuff for free is great. It doesn't really need tobe usefull, haha just as long as its free.
no worries about the pics. I figure out the wiring when my ballast come. If they worked for your preds, Im going to guess they'll work for mine
