Old 07-14-2007, 06:46 PM   #41
sillieidiot
My Ride: '06 AW 330ci
yea they will work fine. the ones that came for me had black and red wiring. the black was the ground. so it was black (from the ballast) to brown (from the relay). just in case you got the same colors as well.
Old 02-20-2008, 04:37 PM   #42
Bert336
My Ride: 330i ZHP 6MT
hey guys i just order some replacement ballast from vibelights.com. one question though. any of you know which side of the ring is positive and which one is negative? i had cut the connectors off of mine due to a replacement i had to do a while back and ever since i havent installed a new ballast so i forgot which one is which.. thanks a bunch!
Bert336 is offline   Reply With Quote
Old 02-20-2008, 04:46 PM   #43
sillieidiot
for the white wires? it doesn't matter.
Old 02-21-2008, 07:53 AM   #44
Bert336
my rings i believe have the blue wires but the ballast do have the white wires..
Old 02-21-2008, 07:59 AM   #45
ca1242
My Ride: 2003 330i
Still doesn't matter. VOltage coming out of the ballast is AC, so it has no + or -
Old 02-21-2008, 05:08 PM   #46
Bert336
cool. thanks! =]
Old 02-22-2008, 05:26 PM   #47
Bert336
alright well i got my DDEs hooked up, let them warm up but one one ring i see a slight discoloration compared to the other 3...they are all 6k...but one of them has light a greenish color instead of a bright white..i used one of my old ballast...could it be a bad ballast or a bad ring? do rings ever go bad?
Old 02-22-2008, 06:15 PM   #48
sillieidiot
yes the rings go bad. take your new one and use it on the side with the bad ring. see if that helps any.
