Thread Tools Search this Thread Rating: Thread Rating: 87 votes, 4.99 average. Display Modes
Old 07-06-2007, 05:08 AM   #1
monarc98
My Ride: 2001 330i sedan
Send a message via Yahoo to monarc98
reset service indicator
hi,
can somebody exlpian what this exactly means and what it does:
"To reset the indicator:
-The car should be off
-hold down the left instrument button (the trip odometer reset)
-while holding the key, turn the ignition to position 1 (radio)
-you will see a test menu
-keep holding the button
-after maybe 10 seconds, the word "reset" will appear
-let go of the button and press again
-THe indicator is reset!"
got 105k on my 3301 sedan the service thing started at 20000 now it's down to 18000. what gives?
monarc98 is offline   Reply With Quote
Old 07-06-2007, 08:53 AM   #2
sstainba
My Ride: 02 325Ci
that is the service indicator. it tells you how many miles you have until you need to have your oil/filter and other things changed and/or inspected.
those steps will reset it to maximum. (after you change your oil you do those)
sstainba is offline   Reply With Quote
Old 08-01-2007, 12:11 AM   #3
JJR4884
My Ride: BMW
i tried doing this today
held it until it said "reset"
hit the left button again, then it says "end"
still didn't reset????
wtf?
JJR4884 is offline   Reply With Quote
Old 08-09-2007, 10:34 PM   #4
nasdaqer
My Ride: 2000 323i
I am also having a hard time with this. I have a 2000 323i, and had the inspection warning. I managed to reset that, but I still can't get the Oil Change warning to keep from coming up.
nasdaqer is offline   Reply With Quote
Old 08-12-2007, 09:28 AM   #5
amancuso
My Ride: 128i, 330i, Z3 2.3
wtf?
'02 330i here, didn't reset on mine either.
amancuso is offline   Reply With Quote
Old 08-12-2007, 11:01 AM   #6
tyed
My Ride: E46
My process differs slightly, and it works fine on my '01 325i (for oil change intervals...haven't tried it for inspections).
- Press and hold trip meter button down and turn ignitiion key to accesory position.
- Hold until you see 'reset'.
- Release and immediately press and hold again for 5 seconds, until 'reset' flashes.
- Release and press again.
I think the last step may be where you're going wrong
Dave T
tyed is offline   Reply With Quote
Old 08-12-2007, 02:07 PM   #7
amancuso
Thanks tyed, that did the trick. I and my 330i thank you
Old 10-14-2007, 11:24 AM   #8
se93
My Ride: BMW 328ci AW MTECH2
Dave T
Does this process also work with the 2000 328Ci? I have been looking at some DIY and was wondering what actually works? I am kind of new to BMW and want to make sure i don't screw up anything.
By the way, no means of hijacking your post.
I found this information: http://forum.e46fanatics.com/showthr...ight=oil+reset
Is this the correct way to go? I just want to make sure this is adequate as i would hate to fry electrical components trying to save a few dollars.
Thanks,
se93 is offline   Reply With Quote
Old 01-01-2008, 02:13 PM   #9
BMW04E46
My Ride: 2004 325Ci SMG
gotta try this after my oil change, thanks!!
2005 Acura TL A-Spec
2004 325Ci SMG M-tech II (Sold and got 2005 Acura TL A-Spec) :-(
2002 530i Sport
1997 Mercedes Benz C280 Sport (Sold and got 2002 530i Sport!) :-)
2007 Yamaha VX Cruiser (WaveRunner)
see my garage for pics
How a Rogue IKON should look on a M-Tech II Coupe
http://forum.e46fanatics.com/showthread.php?t=537372
BMW04E46 is offline   Reply With Quote
Old 01-02-2008, 08:42 PM   #10
QBz
My Ride: 2001 330 Ci
Send a message via AIM to QBz
hey i have the same problem now i did the same process the other day and the service engine light is still on and so is my oil light but that turns off a couple seconds but my service light still stays on so maybe i may need a service because i have 76xxx miles and it may be just coincidence derno.
QBz is offline   Reply With Quote
Old 06-01-2008, 11:30 AM   #11
r6vr6
My Ride: 2002 ///M3
Dave T
Thanks worked on my 2004 x3.
r6vr6 is offline   Reply With Quote
Old 06-13-2008, 09:16 PM   #12
mnfarrales
My Ride: 2001 3301
fault code P01403
can you post how to fix fault code P0403 Exhaust Gas Recirculation Circuit Malfunction for 2001 330i.
mnfarrales is offline   Reply With Quote
Old 06-15-2008, 08:43 PM   #13
jayton
My Ride: 01 325i
Thanks,
The way that I understand it, is that if your car was made in June of 2000 or earlier, then you have to go to the dealer or use a special scanner that plugs into the OBDII port. If your car was made in July of 2000 or later, then the method in this thread will work.
My first post and I am actually helping someone else out!
I am new to BMW as well. I just bought a 2001 325i and I got the info above from the Haynes manual that I just got. Some people knock the Haynes manual because many times it does not go into detail enough, or leaves steps out and seems incomplete. However, for getting caught up to speed on how these BMW's work, they are worth their weight in gold.
jayton
jayton is offline   Reply With Quote
Old 06-15-2008, 08:47 PM   #14
jayton
My Ride: 01 325i
D'OH! I just now realized that I was replying to a thread from 2007.
I think you may be in the wrong thread for that. Put that code in the search box.
jayton
Old 07-04-2008, 08:01 PM   #15
RedEye
My Ride: BMW 330ci
I just tried this on my 330ci and it worked. Now its raised a new question.
...The car needed an oil service according to the dash. So i had that done, without reseting the counter. Ive just done it and at that point it was minus 3000 i think. Now it has been reset and straight away the word inspection is visble. Does that mean Inspection NOW or Inspection when the counter reaches 0?
RedEye is offline   Reply With Quote
Old 08-12-2009, 11:28 AM   #16
KazGL6
My Ride: E46 320d
I tried this on a 320d and managed to reset the oil service and pollen filter counts OK.
Brilliant forum!
Cheers,
Kaz
KazGL6 is offline   Reply With Quote
Old 08-18-2009, 01:02 PM   #17
BAYFLY
My Ride: 2001 E46
I went through this step by step and was able to reset the oil service but only to "Inspection". When I went throught the procedure again all I get is "END SIA" and it stays in the INSPECTION mode not OIL SERVICE. Can anyone help to switch this over to OIL SERVICE? Another question I have is concerning all the other codes that pop up when repeatedly pressing the trip odometer button? Can these codes be changes and what are they for?
Thanks,
Bayfly
BAYFLY is offline   Reply With Quote
Old 08-24-2009, 11:38 AM   #18
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
i reset mine today and it is showing 15525.. is there a way to make a custom value? say 7500 or 5000? thanks
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 03-12-2010, 10:06 PM   #19
kafka
My Ride: BMW //M3 (E46)
Hey, what gives. I changed the Oil in my car last weekend and I have tried the procedure suggested here a bazillion times, no luck.
I don't think it'd be different for an M3 (2003).
It eventually blinks on End and that's it, no Reset has happened.
Help please, negative numbers in the Oil Change Indicator bother me
ww
*J*
NY BMWCCA
E46 M3, mods: Aux Line In, Garage Door Universal Transmitter, CF Roundels, Clear Reflectors, Silvervision Clear Bulbs turn signals, Xenonmatch Foglights, BMWCCA Insignia on Grill, NYS BMWCCA Custom Plate.
Future Mods: Lumbar Support Retrofit, Owner Brain Transplant.
kafka is offline   Reply With Quote
Old 03-13-2010, 01:53 AM   #20
neef
My Ride: Poor
Should be the same
neef is offline   Reply With Quote
