solution: Check engine light w/ aftermarket Headers - Page 15 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 263 votes, 5.00 average. Display Modes
Old 02-18-2011, 10:56 AM   #281
RogueStatus37
My Ride: '04 330ci
Right...so I have an inspection coming up in a few months and headers I really dont feel like paying a grand, getting the headers taken off, putting stock manifolds on, and then having the headers put back on. Now what?
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 02-18-2011, 11:15 AM   #282
TxZHP04
My Ride: ESS TS2+ ZHP
Well, you could start by reading up on the posts here in this very sub-forum. Start with these:
http://forum.e46fanatics.com/showthread.php?t=713645
http://forum.e46fanatics.com/showthr...885&highlight=
Old 09-20-2011, 01:19 PM   #283
colegdl
My Ride: e46 330i 05
How to install the 02 rear , do not have space for 02 with non Foulers , can i install them in the exhaust system
colegdl is offline   Reply With Quote
Old 09-20-2011, 02:10 PM   #284
TxZHP04
Don't waste your time messing with non-foulers. See post #282 above for some links to helpful information.
Old 09-20-2011, 02:47 PM   #285
My Ride: Lexus
When I get headers, I'll have my tuner disable the light. It'll take him 2 seconds.
Old 08-18-2012, 11:40 PM   #286
Conna22
My Ride: 2005 330ci
Okay so heres my question... well first of all I installed my ebay headers on my 2003 325i (which was a pain in the ass) and im going to have to get my O2 sensor ports moved and welded to a different spot for clearance purposes. But why cant you just plug off your post-cat O2 sensor ports and just tie them up somewhere in your engine bay? Why wouldnt that work? The post cat senors would be out of stream and essentially "tricked" too. So far that is what I have done, and im getting a CEL light. I just want to know why that wont work.
Conna22 is offline   Reply With Quote
Old 08-18-2012, 11:57 PM   #287
Keem
My Ride: MB e320/Pink Jeep
Because the O2 sensors read different O2 levels under acceleration and when coasting. If the car doesn't see the appropriate voltage levels after you take your foot off the gas or for the specific amount of gas applied it throws the CEL.
//Custom SSR GT3 Syle Wheels//12" FI SSD//CarPC//
//Tein Coilovers//5% Tint//Aluminum ACS Pedals//
//2 JBL Amplifiers//CDT Components//ZHP//
Keem is offline   Reply With Quote
Old 12-12-2012, 10:20 AM   #288
lrz14
My Ride: 2001 BMW 325ci
Ok so heres a question for everyone, i have no running o2 sensors on my car w/headers simply becasue i was left with no room to fit them. I am currently looking into fixing the problem by buying extensions. Now every where i read people say that running the car without o2 sensors is a bad thing especially the post sensors suposedly and others say to ignore it. At this point i have no idea what to think, does anyone have a thread or some input?
lrz14 is offline   Reply With Quote
Old 12-12-2012, 10:31 AM   #289
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
this setup works great on my car
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 12-14-2012, 05:14 PM   #290
lrz14
I have a couple questions for the op and anyone that has an opinion. I have no 02 sensors on my car due to the fact that i have no room, making it that i have to buy each o2 sensor a 90 degree extension in order to fit them in correctly. I also wanted to do the spark plug non-fouler mod but woudnt i be good with the amount of space i have created with the extensions in order to trick the computer? Idk if im anywhere being right on this. Also does anyone know if my check engine light will go away as soon as plug in the o2 sensors or do i have to clear the code some how?
Old 02-11-2013, 11:24 PM   #291
chanaka
My Ride: E12, E32, E46
I can say that non foulers do work. I have using them on my car for years now and no issue at all
chanaka is offline   Reply With Quote
Old 02-12-2013, 11:38 PM   #292
trentcdrums
My Ride: BMW 323i Sedan
So how do you install on the headers exactly?
Old 02-12-2013, 11:43 PM   #293
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Does that remove the check engine light or emissions?
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 02-13-2013, 07:12 AM   #294
JohnBlaze
My Ride: Black Sunshine
done right they can eliminate the dash light and pass emissions, but it's hit or miss with the sparkplug defouler method.
I've seen it work to pass emissions on a 2003 Acura RSX Type-S, but have heard of a lot of trouble when used with e46's
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 02-13-2013, 07:16 AM   #295
chanaka
My car is a 2002 320Ci Convrt with M54B22. It had headers with cats. I used performance headers with no cats.
Installed the defoulers (which are longer than spark plug defoulers).
They were welded onto the tail end of the header pipe and the sensors bolted onto them.
Have had it running for years with no issue at all.
No dash light and passes our emissions without any issue but our emissions is not hard to pass anyway
Old 03-26-2013, 02:34 PM   #296
drawz
My Ride: BMW 3-series 325
Does the 42008 Non-fouler work? Can't fint the 42009.. :\ Autozone doesn't got 42009.
drawz is offline   Reply With Quote
Old 07-25-2013, 01:58 AM   #297
drift.mechanic
My Ride: E46 323i
I'm throwing on a set of headers tomorrow, AMK racing headers for 01-05 on my 323. I know the flanges aren't the same, no worries, fabbing a twin 2.25" center pipe to a ZHP muffler
Question is, the AMK units have very very tall secondary O2 bungs. I'm wondering if it will be necessary to use the non foulers. Here's a picture to show you what I mean. One header has the non fouler, the other doesn't. The one that doesn't, notice how tall it is? The O2 element wouldn't be in the exhaust flow.
Opinions?
drift.mechanic is offline   Reply With Quote
Old 07-25-2013, 05:56 AM   #298
daniel_f.
My Ride: 330iC
like all these ebay headers, you´ll get into trouble when mounting them with installed lambda. they´ll hit the heatshield. i cutted them more then 3cm, so there was only a small thread which can handle the lambda sensor.
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-26-2013, 09:25 PM   #299
drift.mechanic
My Ride: E46 323i
Well the headers and exhaust in installed. Sounds awesome. Mid range and top end power is DRASTICALLY improved. It doesn't die out at 5500 like usually, it pulls hard to 6500.
Like I said, the sound is impressive. Very raspy but a clean sound in idle, clean tuned sound on mid load, screams when opened up. Very well worth mod. Here is the custom exhaust with a ZHP muffler, 2.25" piping, H pipe mid way down (old 323 exhaust with resonators deleted on right for comparison):
Although I did relocate the rear O2 bungs and used the spacers, I'm still throwing a code for cat efficiency. Here is the bung setup:
Here's the AMK headers I threw on. I ceramic coated them black before installation:
Sound clip of a short drive inside the car, windows up:
Sound clip at first hot start-up and small rev to 3300rpm. Notice the rasp on no load and beautiful signature low tone rumble in idle:
Hopefully this can help people decide if they want to go the header route and if so, to resonator or not to resonator.
Comments and questions are more than welcome.
Old 08-03-2013, 01:22 PM   #300
Megasquirter
My Ride: 2001 BMW 330i
I too installed the defoulers and I still get the SES light. So like the other guy said its hit or miss. The next cost effective way to delete is that resistor mod, although its not a permanet fix, its cheap. I cant seem to find that post anymore, anyone have a link to that o2 resistor mod diy?
Megasquirter is offline   Reply With Quote
