Thread Tools Search this Thread Rating: Thread Rating: 263 votes, 5.00 average. Display Modes
Old 09-20-2007, 06:41 AM   #21
botaman
My Ride: 330xi/530 Blown
It works. I owe you a few beer. It has been over a week now w/o the dreaded CEL. Because there was no room on the E39 where the O2 goes, I only used the short NON FOULERS but so far I'm excited. Thank you very much for damn good idea
botaman is offline   Reply With Quote
Old 09-20-2007, 07:35 AM   #22
Deep Blue
Banned
My Ride: M52TUB28
You are very welcome. Good luck. I am keeping my fingers cross
Sometimes the CEL light when come but it will go away randomly. It all depends on the temperature, weather condition, and the way you push your car. For example, expect the CEL to come on in a cold morning when you are flooring/over-reving your engine. But again, no worries because the light will eventually go away.
this is just a "trick" and not a "fix"
Deep Blue is offline   Reply With Quote
Old 09-20-2007, 11:33 AM   #23
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Doesn't work for everyone, unfortunately. I have 2 non-foulers AND cats, and I still have an SES. My issue is that my cats and O2s are in the middle of my car. Being so far back, the DME is getting confused because the O2s aren't getting the pulses when they should.
The other issue is for anyone who has the new Technik Gen3s. As I found out (along with a few others), Technik made a poor call with the positioning of the O2s (poor for the people needing to install 2 non-foulers. The issue being that the O2 plus 2 non-foulers is too long to install if you want to keep your transmission. It butts right into the bellhousing.
Luckily, software is on the way. I had to take the expensive route.
Kudos to you for the writeup, though. It WILL work for a lot of people.
Old 09-20-2007, 06:02 PM   #24
Deep Blue
Banned
My Ride: M52TUB28
Good point.
I have a very similiar setup as yours except for the headers and the type of Cats.
I have a TSE3 with Technik Gen 2 with magnaflow cats. I plugged up the second headers o2 sockets and welded my own past the transmission pan.
Old 11-26-2007, 01:17 AM   #25
JC7727
JC7727's Avatar
My Ride: 01 330i
Send a message via AIM to JC7727
what software can remove this code?
Sponsored by Jlevi StreetWerks
FOR SALE: http://forum.e46fanatics.com/showthread.php?t=417026
JC7727 is offline   Reply With Quote
Old 11-28-2007, 02:24 PM   #26
dpgrand
My Ride: 2005 330xi
AA software will fix it.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 12-04-2007, 10:01 PM   #27
JC7727
JC7727's Avatar
My Ride: 01 330i
They told me its not possible?
Old 12-13-2007, 10:22 PM   #28
dpgrand
My Ride: 2005 330xi
yes they can...
Old 01-03-2008, 12:52 PM   #29
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
what about passing emissions with high flow cats? anyone had a problem with that?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 01-03-2008, 09:04 PM   #30
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
I haven't had to smog my car yet with the headers/cats...
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 02-12-2008, 12:47 AM   #31
2003330i
My Ride: SC'330izhp,09 335i,
my car is at rogue right now. does this work. i have the technik headers and just want this check engine light off
2003330i is offline   Reply With Quote
Old 02-12-2008, 12:50 AM   #32
2003330i
bjlk
Old 02-18-2008, 05:06 PM   #33
schon weg
My Ride: 2001 325xi
Anyone know if cat-delete software prevents the catalyst monitor from coming online? Why does this monitor take so long to reset?
2001 325xi: Jet Black, Black leather, Premium package, 3.0L DIY engine swap, ESS software, BFP CAI, Technik headers, custom TSE3, RT cats, Stage II fw w/ M5 clutch, pulleys, EVO3 SSK, H&R springs/Koni Sports, 18 BBS w/ S-03s, CDV omit, cosmetic stuff, et cetera.
schon weg is offline   Reply With Quote
Old 04-20-2008, 02:33 PM   #34
JC7727
JC7727's Avatar
My Ride: 01 330i
I did this and no go, the CEL came on today and I am using both the short and long fouler with high flow cat installed!
Old 04-20-2008, 02:34 PM   #35
JC7727
JC7727's Avatar
My Ride: 01 330i
Originally Posted by dpgrand View Post
yes they can...
I spoke to a software engineer, did you speak to a sales representative lol.
Old 04-20-2008, 02:56 PM   #36
AdamBath
My Ride: E30
did you check the code to make sure it is catalyst below efficiency?
AdamBath is offline   Reply With Quote
Old 04-20-2008, 03:27 PM   #37
tanzi
My Ride: 02' 325i
I talked to AA about their software to get rid of the CEL for not having cats. They said all they can do it turn off the CEL light for not having cats but when you hook it up to the computer the copmuter will not pass you!
They said:
"YOU will have to sign a waiver for the NO CATS set up, you have to also understand that you will not pass the OBD 2 scan test for emissions"
tanzi is offline   Reply With Quote
Old 04-20-2008, 03:31 PM   #38
JC7727
JC7727's Avatar
My Ride: 01 330i
Its P1192 Post-catalyst Fuel Trim System Bank 1 which is weird thats not the code I usually get? Maybe the 02 sensor is damaged?
Old 04-26-2008, 08:23 PM   #39
AdamBath
My Ride: E30
finally did this today, and got my codes cleared, we'll see if it comes back. and just an fyi, there was really not enough room to put these in, i definitely couldn't have stacked them per this thread. i only used the "long" one, the 42002, though with the stock o2 bung on the ebay headers, they are already about as raised up as the short defouler.
Old 04-27-2008, 08:49 AM   #40
Minnoe07
My Ride: 2004 BMW 330Ci
Yea, I had the same problem as you adam. I put one on to see if it would clear one bank. I definitely got both codes so I think somehow I gotta get the short and long one in, but there definitely isn't enough room. I'm thinking if I uninstall the headers, then put the defoulers on w/ O2 sensors and then put the headers back in, it should fit, but I dunno yet.
I have until December to figure it out.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
