Thread Tools Search this Thread Rating: Thread Rating: 263 votes, 5.00 average. Display Modes
Old 04-27-2008, 04:31 PM   #41
AdamBath
My Ride: E30
Originally Posted by Minnoe07 View Post
Yea, I had the same problem as you adam. I put one on to see if it would clear one bank. I definitely got both codes so I think somehow I gotta get the short and long one in, but there definitely isn't enough room. I'm thinking if I uninstall the headers, then put the defoulers on w/ O2 sensors and then put the headers back in, it should fit, but I dunno yet.
I have until December to figure it out.
i doubt itd fit even doing that with the short and the long one, mine are already touching the transmission with just the long one.
AdamBath is offline   Reply With Quote
Old 04-27-2008, 06:08 PM   #42
Minnoe07
My Ride: 2004 BMW 330Ci
Well, let me know if your CEL ever comes back on.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 05-06-2008, 11:27 PM   #43
JC7727
JC7727's Avatar
My Ride: 01 330i
Send a message via AIM to JC7727
I did it but now I am getting P1192 code which I never had before. I think I may have messed up an 02 sensor, anyone know how to check?
Sponsored by Jlevi StreetWerks
FOR SALE: http://forum.e46fanatics.com/showthread.php?t=417026
JC7727 is offline   Reply With Quote
Old 05-07-2008, 12:51 AM   #44
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
sorry but you guys might of went through all this trouble for nothing... check out this thread
http://forum.e46fanatics.com/showthr...42#post7864042
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 05-07-2008, 01:26 AM   #45
JC7727
JC7727's Avatar
My Ride: 01 330i
that would be 140 dollars vs 10
Old 05-07-2008, 01:28 AM   #46
jetskier88
its only $70?? or would you need to buy 2?? the description is not clear at all..
Old 05-07-2008, 01:29 AM   #47
JC7727
JC7727's Avatar
My Ride: 01 330i
no idea from that discription
Old 05-07-2008, 07:04 AM   #48
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Originally Posted by JC7727 View Post
Its P1192 Post-catalyst Fuel Trim System Bank 1 which is weird thats not the code I usually get? Maybe the 02 sensor is damaged?
What ?
I read somewhere else that post-cat sensor has NO effect on fuel trim, it just measures cat efficiency. How then, could there be a post-cat fuel trim system ? I'd suspect from this that the post-cat sensor does have some effect ?
Can anyone confirm or clarify ?
tony325ci_51 is offline   Reply With Quote
Old 05-07-2008, 07:05 AM   #49
brewster240
My Ride: 02 325it, 95 m3
1 for each sensor, and they dont always work.
brewster240 is offline   Reply With Quote
Old 05-07-2008, 08:20 AM   #50
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
those are too far downstream and might need a heated o2 application,had that problem with my firebird, p1192 is a post catalyst fuel trim system -bank 1
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 05-07-2008, 02:43 PM   #51
JC7727
JC7727's Avatar
My Ride: 01 330i
do you see the cat I have, its after it. Its not like I have no cat but I guess its not efficent enough since its only one.
Old 05-07-2008, 03:29 PM   #52
AdamBath
My Ride: E30
why do you have foulers on if you have a cat?
Old 05-07-2008, 03:53 PM   #53
jetskier88
its the cool thing to do.. duh..
Old 05-07-2008, 04:00 PM   #54
JC7727
JC7727's Avatar
My Ride: 01 330i
I still get cat inefficiency codes despite the cat Its a know problem since they are not in the headers and the computer doesnt see them as doing a good enough job.
Old 06-05-2008, 09:23 AM   #55
ATLZHP6M
My Ride: TS2+ ZHP, ESS E39 M5
Spark non-foulers did not work for me.
Hello guys,
I completed this mod a couple of days ago and I got a CEL with the following codes:
P2271 (O2 Bank 1 Sensor 2 Signal Stuck Rich)
P2096 (Post Catalyst Fuel Trim Bank 1 System too Lean)
P2098 (Post Catalyst fuel trim bank 2 system too lean)
I have ESS software and they did the Post Cat O2 sensor delete for me but the car was not able to pass emissions. I had them put the O2 sensors back on and I was able to pass emissions without cats however a few days later the car threw a CEL.
I guess this mod does not work for everyone... Do you guys think my O2 sensors have gone bad?
ESS TS2+ Street/Track Toy
ATLZHP6M is offline   Reply With Quote
Old 06-06-2008, 09:33 AM   #56
jetskier88
Originally Posted by ATLZHP6M View Post
Hello guys,
how were u able to pass emissions with the ESS software??? i thought software removes the CEL on the dash but it actually shows up when you read the codes???
Old 06-06-2008, 11:03 AM   #57
ATLZHP6M
ESS put the Post O2 sensors back into the system.
I was able to pass emissions even though I had two incomplete OBDII monitors.
Check Engine came on a couple of days later.
I took one of the nonfoulers out of each of the sensors and reset my codes, so far so good...
Old 06-09-2008, 09:27 PM   #58
Minnoe07
Well, I finally got my CELs to disappear and not come back!
My story is as follows:
Originally I put one non-fouler b/c I couldn't get the other one in. There was still a CEL. So recently, I found a crow's feet socket that fit over the other O2 sensor so I could get it out. Unfortunately, somehow, it got cross threaded and I could only back it out a few threads. And then it would not budge. So I figured, screw it. I put the car back down. Went to autozone and cleared the codes. It has been almost a week and a half and no codes!
I guess when I backed out that one O2 sensor it was enough to be similar to the "non-fouler mod" and I no longer throw a CEL. And my O2 sensor that I banged up pretty well seems to be worked just fine. I'm just happy I can pass emissions now.
Old 06-13-2008, 01:40 PM   #59
n2Bimmer
My Ride: Loves Corners
so since there is 4 in total do you use one plug for each hole on the heades??
Old 06-13-2008, 09:17 PM   #60
jetskier88
no you only put them on the last two O2 sensors
