Old 04-13-2002, 02:03 PM   #1
bimmer
My Ride: 323ci
audio question please help
The following are my audio stuff which are waiting for install
JL 12W3 sub
JL XR525cs front speakers
JL XR650cx coaxial for rear
Lanzar 4*50W amp with crossover.
I was told to wire the front and the amp on the lanzat and uses the stock amp to run the rear coax.
Will there be enough power to push the whole setup?
On the forum, I saw all of you guys use big W amp to run amp and multiple amp to run speakers.
What I am looking for is just a bit better and more bass than the stock sub and some clearer sound. Will my setup be able to do this?
bimmer is offline   Reply With Quote
Old 04-13-2002, 02:58 PM   #2
e46fanatic
My Ride: 2001 330ci
Send a message via AIM to e46fanatic
your stock amp WILL NOT push all that! dont even wast your time trying it. the best thing to do is to add a sub to the HK system and a SUB AMP. the rest of the system sounds really good. take back all the stuff you bought except for the 12 and get a SUB AMP
e46fanatic is offline   Reply With Quote
Old 04-13-2002, 03:21 PM   #3
bimmer
My Ride: 323ci
Let me clarify something
I mean use the lanzar amp to push the front speakers and the sub.
And use the stock amp to push just the rear coaxials.
Also, I have stock audio system, which is not even hk.
Old 04-13-2002, 04:04 PM   #4
e46fanatic
My Ride: 2001 330ci
OH OK
i thought you had the HK upgrade. who much was the amp you bought?
Old 04-13-2002, 10:58 PM   #5
bimmer
My Ride: 323ci
how is the price of the amp related to the question?
It is a used one but its qualify should be good.
It is the top series of lanzar amp before switching the owner.
Old 04-14-2002, 10:04 AM   #6
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
My Ride: ESS TS2+ 330Ci
Send a message via Yahoo to Dirtboy
you should have no prob running just the rear co-ax's with the stock amp. but i do recommend you put some kind of high-pass crossover or bass blocker for the rears. in good setups, rear sound is not as critical as the front soundstage.
Dirtboy is offline   Reply With Quote
