Old 07-09-2007, 03:05 AM   #1
summit425
My Ride: E46 AW 323Ci
how often do you change your engine oil?
hello guys
I want to get this answer by using search but I can't fine the result of my question.
Anyway I went to the dealership one day and they told me that I have to change my engine oil/10000km
Some others told me to change 5000km.
one guy told me I can ride 1 year / engine oil change..
which one is correct??
Also I am thinking of using Castrol Syntec 5W-30. My previous one was 5W-50
What is the difference between Castrol SYNTEC BLEND and CAstrol Syntec?
sorry for so many questions
summit425 is offline   Reply With Quote
Old 07-09-2007, 03:34 AM   #2
Emanuel
My Ride: '00 Z3C/'07 Z4MC
BMW says the E46 needs an oil change once every 15,000 miles, or once per year, whichever comes first. Though most people feel that's too long an interval (I do mine every 7500 miles), truth is everyone that's had an engine oil analysis done has found the oil is indeed fine at 15k. In sum, if it makes you uncomfortable, more frequent changes are cheap and won't hurt, but the factory interval is fine.
Syntec blend in synthetic and dino oil, and not as durable as 100% synthetic (Syntec).
Emanuel is offline   Reply With Quote
Old 07-09-2007, 04:41 AM   #3
320de46m47
My Ride: 320D Touring
it's the one really effective thing you can/must do to maintain longevity of the engine so 10 000km for me. oil degrades over time/use it doesn't switch off its effectiveness at a magic number.
320de46m47 is offline   Reply With Quote
Old 07-09-2007, 08:16 AM   #4
SteveX82
My Ride: 2001 325i
What idiot told you that? An Exxon employee?
Changing your oil any more often than every 7500 miles (as opposed to the ~2272miles "suggested" to you) is a complete waste of time, money, and natural resources.
SteveX82 is offline   Reply With Quote
Old 07-09-2007, 10:32 AM   #5
ca1242
My Ride: 2003 330i
I try to at every 5,000. I wouldn't go farther than 7500 max.
You will not get a firm answer on this topic, just different opinions.
Old 07-09-2007, 11:31 AM   #6
redwood77
My Ride: e46
once a year for me.
redwood77 is offline   Reply With Quote
Old 07-09-2007, 11:50 AM   #7
hummer
My Ride: 2001 330CI
Nothing but pure synthetic and check for A3-B3 on the label. Minimum wt, if it's other than BMW 5-30 oil, is 5-40 or maybe 0-40 Mobil 1. General consensus is 7,500 miles or once a year. You might notice that most oil companies are coming out with a 5-40 for european cars. Forget the 5-30 and most certainly the 0-30 oils. If you're in a hot climate got to 10-40 or 15-50.
Old 07-09-2007, 12:01 PM   #8
markusmark
My Ride: 2001330Ci
Every 5000 miles. Now using Redline but will switch back to the stuff from the dealer at next change.
markusmark is offline   Reply With Quote
Old 07-09-2007, 01:30 PM   #9
320de46m47
ok look
3000 miles just silly
5000 miles a bit silly
7500 miles very prudent (me, actually verging on a bit silly as i change at 6,500)
10000 miles normal sensible
15000 miles a bit careless (BMW!)
once a year ??!!??
and dont forget your engine breather
Old 07-09-2007, 02:08 PM   #10
GRIDLOCK
My Ride: E36 / E46
I change every 5 to 7k.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 07-09-2007, 02:15 PM   #11
320de46m47
new category ....daft lol
Old 07-09-2007, 02:31 PM   #12
raptorman5174
My Ride: 330i ZHP
BMW Says every 15,000 miles. Thats way to much for me. I'll go for about 9000 miles and then chage it. usually last me more then a few months. Also you can change the oil filter in your car with out having to drain the oil. that alone should give you a few more thousand miles. And oil filters are cheap.
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
Old 07-09-2007, 03:02 PM   #13
320de46m47
revised....
2000 miles daft and idiotic
3000 miles just plain silly
6000 some do if fanatical
7500 miles very prudent (also me, actually verging on a bit silly as i change at 6,500)
9000 change filter only ...sound advice but maybe better at midway between oil change
10000 miles normal sensible mr normal average
15000 miles a bit careless but probably ok if you want to keep the car 10 years (BMW just showing off!)
once a year ??!!??
AND dont forget your engine breather!!!!!!!!
Old 07-09-2007, 03:09 PM   #14
330lover
My Ride: 01' 330ia bk/bk
Every 6k miles with mobil 1.
01' 330ia, bk/bk, moon, cd, xenon, tinted, 18x8 ASA AR1, Avon Tech M500 18/225/40 all around, Axxis brake pad, Eibach spring
330lover is offline   Reply With Quote
Old 07-09-2007, 03:41 PM   #15
bavari13
My Ride: F25 X3, E90 335i
7500
I wouldn't say anything is a waste, some people just feel more comfortable doing it at a sooner interval.
bavari13 is offline   Reply With Quote
Old 07-09-2007, 03:45 PM   #16
320de46m47
yeah the save the earth argument is a bit naff seeing as you put xxxx gallons of refined oil in the petrol tank every time you fill up
Old 07-10-2007, 11:50 AM   #17
destroyer427
My Ride: 2000 M5
Mostly due to my car having 105k miles, I plan on going every 5k mile changes with full synthetic, and for the fact I drive fairly hard. Going above 10k miles changes with a car over 100k is suicide imo. I guess it all depends on how clean/smooth you want to keep the engine for the long haul, if only keeping car for a year or two, 10-15k seems fine.
destroyer427 is offline   Reply With Quote
Old 07-10-2007, 01:36 PM   #18
todd92
My Ride: 05 330i ZHP
I just waited till the service lights came on. 17,000 miles. I had the oil analyzed by Blackstone Labs. The oil was spent, but there were no signs of any engine wear. One of the reasons the oil was spent was that in 17,000 miles I only had to add 0.7 quarts, and makeup oil is the only way to replenish the additives in oil. What a shame, my car uses virtually no oil. The car has 38,000 miles on it now and I'll change when the service lights come on again. Something else will wear out or break in the engine years before anything related to oil change intervals will. If ever.
todd92 is offline   Reply With Quote
Old 07-10-2007, 01:45 PM   #19
jwm5
My Ride: station wagon
7500 miles is a good basic, but if you put less than that a year on your car, then yes change once a year.
jwm5 is offline   Reply With Quote
Old 07-10-2007, 03:46 PM   #20
SteveX82
My Ride: 2001 325i
The "petrol" doesn't need to be disposed of and recycled in an ecological manner like waste motor oil does. Wastefulness is wastefulness, whether you're changing your oil more often than necessary because it's "cheap insurance" or you're driving a truck that gets 10mpg because you "can afford to do it". Every little bit of conservation helps.
