Old 07-09-2007, 08:05 AM   #1
320de46m47
My Ride: 320D Touring
Bluetooth/Siemens BIT II phone installation
Does anyone have install instructions for cars that are not pre-wired? Thanks
320de46m47 is offline   Reply With Quote
Old 07-09-2007, 08:58 AM   #2
320de46m47
actually forget the bluetooth , its the siemens bit II im interested in as i have the tranciever for this...
i have most of the parts i need but there are still some connections that dont work!?!
im missing one or two small things but what are they?
if anyone can point me to a pdf id be very grateful
Old 07-09-2007, 09:26 AM   #3
320de46m47
these are the connections im most baffled about
Old 07-10-2007, 01:46 PM   #4
320de46m47
this is what ive got so far
the box at the bottom is the transceiver
not sure really about the aerial connections
Old 07-10-2007, 01:56 PM   #5
daytonaviolet
My Ride: 2004 M3
Send a message via AIM to daytonaviolet Send a message via MSN to daytonaviolet Send a message via Yahoo to daytonaviolet
im confused...
1) are you doing BT install or hardwire phone?
2) are u planning on using ULF or TCU
daytonaviolet is offline   Reply With Quote
Old 07-10-2007, 02:01 PM   #6
320de46m47
its a single band siemens bit II (GSM network) handsfree phone...quite old technology but i like it as it uses my sim card (a duplicate) stays in the car, is reported to have very good reception, hooks up to everything, is hands free and has an orange display identicle to other interior lights
Old 07-10-2007, 02:04 PM   #7
daytonaviolet
My Ride: 2004 M3
so.. its hardwired and not bluetooth?
Old 07-10-2007, 02:07 PM   #8
320de46m47
yes indeed
Old 07-10-2007, 02:10 PM   #9
daytonaviolet
My Ride: 2004 M3
yes indeed
then.. no need for the BT antenna item #6. also.. do you have bmw assist? if not, no need for the shark fin.
i believe the shark fin connects to the #1 location on the ULF or TCU.
Old 07-13-2007, 07:50 AM   #10
320de46m47
i think i have confused you by saying its hardwired too ...the handset is wireless. no 6 is not a bt antenna its called a basis antenna and it does actually form part of the pdf instructions which i have (although they are for a half wired car which mine is not) that was my difficulty uc. no 6 provides a wireless link to the handset. i have since learned how to wire it all up the shark fin will serve i hope as a single band antenna which is needed (hoping anyway)
this is a diagram for anyone else who goes down this road..
the pink line would be the normal route of the antenna ...i have discovered part number 61126912541 instead
a longer version of this
part no. 84110025711 is a male FAKRA to mini uhf connector
i will upgrade to bt later ...i have the ejectbox just need the module
Old 08-19-2007, 05:57 PM   #11
320de46m47
Tried hooking it all up this afternoon...
The power supply A10 goes into the upper F39 with 5 amp fuse - but then problem is the dashboard (the three main dials backlighting) remains lit up when car is off and the key is out for some reason?!??!!
Also there is no wire for pin 4 on X18126 to to connect A13 to? I plugged the connector into the empty hole no. 4 as per the instructions
radio says --:--
the handset shows a not charging battery symbol and says "searching base"... and doesnt find it
my instructions state that the ejectbox needs "registering with the transceiver" as follows:-
set the switch in the eject box to I
turn ign pos 1 for 15 seconds
switch ign to 0 without 8 seconds (dont understand "without" a mistake?)
wait a further 2 seconds
switch eject box switch back to 0
and then this not possible because base not found....
turn on handset
press ok
enter 0000 ( i have a new transceiver so no code set)
Tried transceiver connections other way round also :oops:
Transceiver does make noises when tryoing
Nothing happens
Old 02-06-2009, 04:31 AM   #12
keeper01
My Ride: 320Ci
hi 320de46m47
Did you ever got the setup to work? My car is not prewired so I am trying my hand at BT installation I have the wired harness similar to yours but it did not come with the 54 pin plug it came with the blue 26 pin plug and a white 18 pin plug, I see in your diagram above you have a adapter that connects and convert both pin plugs to the 54 pin plug which goes into the ULF. Do you know where I can purchase one?
keeper01 is offline   Reply With Quote
