The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 5.00 average.
Old 12-12-2007, 02:32 PM   #241
The Chosen One
My Ride: E46
After mesuring and looking for a couple of days, to see if it was possible to make the speakers move some degrees, he decided NOT TO DO IT.
Why?
Well, This is what's behind the speaker. (2 pencilstripes) On the back there's the guidance for the window.
He can avoid these, but then the speaker must come out more then 7 centimeters to the middle.
Also there's no place to mount the motor like the wanted.
If we look at this, he has to cut out too much steel plating, and the speaker won't be on the ideal place still.
Ah well. Got another idea to place the speakers, and that is to make floorpods.
He's going to wait what they say at FOCAL about the liters he'll need if it plays in a airtight box. If that will be too much, the speakers will get in the doorpanels in a simpel, but good way...
So you see, some things just don't go like you wanted
The Chosen One is offline   Reply With Quote
Old 12-12-2007, 02:37 PM   #242
The Chosen One
My Ride: E46
ok, the speaker will come in to the panel.
In a more normal way
He milded some MDF wooden rings to tighten on the doorpanel.
To lock the speakers tight he made a extra alu plate of 6mm thick.
Here he can use the screws that came with the FOCALS. These are special screws that click-in the grill.
This is an seperate little cap that goes on top. This model will be editted more.
This will come nice when it's finished.
For the moment, he's busy trying to find the same material to cover the panel.
Old 12-12-2007, 02:39 PM   #243
The Chosen One
My Ride: E46
Designerdepartment going at full speed
Worked on the ring where the speaker goes in, more smooth now.
Step by step, till it workes out to something he likes;
On picture, maybe it doesn't look so good, but IRL it looks fine. The forms he made also come back in the original panel. So it's more styled this way.
Old 12-12-2007, 02:45 PM   #244
The Chosen One
My Ride: E46
Here a couple of pics of the original doorpanel, to compare more easy
And this is what it's going to be. The door, on the speaker, gained 2cm more to the inside of the car. This is what he had to do to get the speaker in there in a good way.
The seperate polyester cap, that goes over the speaker, will come in silver, like the christmasballs and the trim.
This will contrast with the rest.
Picture with the grill.
If we look at this all, we think it doesn't contrast to much with the lines, shape of the original panel.
Has to be rubbed and finished some more.
On the backside of the panel, maybe there will come a little light, that shines when the door is opened. Partially to fill up the big piece.
He doens't like such big thing in carbon fibres
(well, I do, but it's his car and project)
Old 12-12-2007, 04:36 PM   #245
M3_Jaydee
My Ride: e70 and e91 LCI
As I said 10x before: amazing labour guys
M3 = GONE!
Check out www.youtube.com/m3jaydee - enjoy the past ;)
M3_Jaydee is offline   Reply With Quote
Old 12-12-2007, 06:04 PM   #246
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Whyyyyyyy is he messing up the red door panel pieces!?????!!
hi its me alec is offline   Reply With Quote
Old 12-18-2007, 08:23 AM   #247
The Chosen One
My Ride: E46
In the meanwhile he made a whole into the doors platework, behind the speaker.
You can see the windowglider. Just nog touching the speaker
Made some more parts, to fill up the other wholes.
On the background, there's a alu plate of 4mm thick. Very hard and strong.
In the middle you can see 2 Carbonkevlar parts. He made em as thin als possible but as strong as an ox.
On the foreground you see 4 little rings he made, to screw the doorpanel extra tight.
If you look to the second on the right, there's a little rubber he pasted on. On the place where he screwed it. This to prevent resonance.
On the picture you see a little pole picking out. That's MEGA IMPORTANT.
Behind the speaker, there'll be another screw, so we can attach it even more in the middle.
Everything mounted:
This won't be the end of the door. HE has to make some tiny wholes airtight, but that won't go untill the has all the material to fill up the sound.
All he makes, will be filled up with this material. What exactly his going to use, he's not sure. we'ill keep u informed.
As you can see, he's putting a lot of work into all this. And more work is coming up so the sound won't be lost...
I think this is a type of work, that is underestimated be many people. But the work will pay of in the end, that's what we are sure of...
Old 12-18-2007, 08:31 AM   #248
BMWDEMON
My Ride: E90 M3 & 05 E46 M3
Send a message via AIM to BMWDEMON
L, you made my morning again! nice work guys!
M
BMW ARMY!
2005 E46 M3 IB ZCP - DD modded
SOLD but not forgetten
BMWDEMON is offline   Reply With Quote
Old 12-18-2007, 02:36 PM   #249
Fredrik M
My Ride: 125i Coupe 2011
Noooo!!! Don't destroy that lovely read leather , just imagine how nice it would look in contrast to black shiny carbonfibre.
/Fredrik
E46 330i sold and replaced with an 2011 125iC
Fredrik M is offline   Reply With Quote
Old 12-18-2007, 07:12 PM   #250
tiggaatl
My Ride: 05 330i ZHP
Send a message via AIM to tiggaatl Send a message via Yahoo to tiggaatl
All I can say is wow. That Trunk set-up is sick. Nice work.
~"I mod, therefore I am"~
tiggaatl is offline   Reply With Quote
Old 12-18-2007, 08:19 PM   #251
T330
My Ride: X5
Send a message via AIM to T330
nice work!!! but that poor imola leather
T330 is offline   Reply With Quote
Old 12-18-2007, 08:30 PM   #252
Studdly_Studright
My Ride: 135i
wow this car is going to be amazing he paid a lot of attention to detail! it makes me want to go do a DIY! :
Studdly_Studright is offline   Reply With Quote
Old 12-18-2007, 09:22 PM   #253
CrazyArmenian
My Ride: 07 BMW 335i Coupe
niceeee update us...
CrazyArmenian is offline   Reply With Quote
Old 12-18-2007, 11:46 PM   #254
Hey-G
My Ride: E46's
sick project! THe only thing I haven't liked thus far is the CF speedometer trim. BUt love the work!
-=It's all about style=-
Hey-G is offline   Reply With Quote
Old 12-19-2007, 02:50 AM   #255
The Chosen One
My Ride: E46
don't cry for the imola leather
you don't know what's coming...
" sometimes you have to go BACK to go FORWARD "
Old 12-20-2007, 05:05 PM   #256
sterile stork
My Ride: '11 STi
Threads like this make me so happy!! Thank you for keeping us all updated on the small things! Your friend is damn talented at everything he is setting himself to!
sterile stork is offline   Reply With Quote
Old 12-20-2007, 07:41 PM   #257
T330
My Ride: X5
Old 12-21-2007, 11:26 AM   #258
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
wow
/_________\
O==[][]==O
Old 12-24-2007, 12:00 PM   #259
robolop
My Ride: 323ci
Carbon Project Belgium
Hi all,
I'm Robolop, the Belgian owner of this Beryllium Beamer.
I hereby would like to thank all of you for the positive comments on this topic.
Especially to TCO, for his effort in translating everything from Dutch to English.
Unfortunately, I'm not good in writing English,
nevertheless, I'm quite able to understand written English.
Season's Greatings from Europe.
God bless you,
Robolop...
robolop is offline   Reply With Quote
Old 12-24-2007, 01:53 PM   #260
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
Originally Posted by robolop View Post
Hi all,
God bless you,
Robolop...
very nice work robolop. keep it up
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Rate This Thread
