The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 5.00 average.
Old 03-09-2010, 03:15 AM   #1221
hennep E46
My Ride: BMW e46 318i 1998
Hi Rob, where any of the links i gave you usefull, or did you buy the M-techII rearbumper at the stealer. Looking forward to see what you are going to do with it. I should start my search on a M-techII rear as well.
hennep E46 is offline   Reply With Quote
Old 03-19-2010, 03:18 PM   #1222
robolop
My Ride: 323ci
The hardest part of the exhausts is behind me now, and it worked out fine.
I put a lot of measure-work into it, but I'm proud to say that it's perfect onto the milimeter.
On this picture, the end-pipes aren't mounted yet. Going to measure this again when it's all finished. Cause I hate it when mufflers come out to far.
The original plastic piece on the bottom of the bumper....it already made a one way trip to the bin.
It didn't fit one bit anymore, and off-course I want to change the model to something more beautiful.
Here you can see the building of it.
First I glued OAZE on the piece with hot glue. This material rubs like butter, and so I got a model faster.
Once I had this, I taped it all with paper-tape.
Here you can see the original exhaust where the quad's are mounted on to.
I put on 4 layers of fiberglass polyester so it's all a bit more robust.
robolop is offline   Reply With Quote
Old 03-19-2010, 03:42 PM   #1223
jstrat85
My Ride: mercedes,porsche,bmw
wow everything looks sick!!!
jstrat85 is offline   Reply With Quote
Old 03-21-2010, 10:24 AM   #1224
robolop
My Ride: 323ci
THX DUDE.
Old 03-21-2010, 11:46 AM   #1225
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
can you take a pic of a better underview of the right side exhaust?
**amazing work!**
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 03-21-2010, 11:50 AM   #1226
330ciandr6
My Ride: .
questions:
1. why has this not been stickied yet?
2. why have you not started a business selling stuff you make cause your talent is amazing?
so awesome how you pretty much make all your own parts. just insane. I'm actually gonna cross post this on a few forums.
Old 03-22-2010, 01:59 PM   #1227
robolop
My Ride: 323ci
Put some model into the polyester piece. Needs to be some more refining for the finishing offÖ
Cause Iím convinced that everything fits 100%, I discovered something.
If you look at this picture, it seems something is not 100% right somewhere.
You see that the inner muffles are a bit higher then the outer ones. I already noticed this on several other cars too.
This is one of my favourites, and I immediately noticed that the exhausts werenít on 1 line.
I never saw the car IRL, but Iím 200% sure that these are correctly placed too.
It just gives you a distorted image cause of the rounding of the bumper.
I for one, will think 2 times before I say that mufflers are placed awry.
I also tried to make some pictures, exactly in the middle of the rear, but thatís not so easy.
To make the polyester piece the same LEFT as RIGHT, I made a mold.
Sometimes itís quite simpleÖ.when you know it
Old 03-22-2010, 02:07 PM   #1228
Bartacus
My Ride: 2002 320i Sedan
Rob is not only a creative genius, but a metalhead too. If you were a woman Rob, I'd marry you.
Bartacus is offline   Reply With Quote
Old 03-22-2010, 06:16 PM   #1229
The Chosen One
My Ride: E46
you are doing a fiiiiiiiiiiiiiine job mate!!
The Chosen One is offline   Reply With Quote
Old 03-23-2010, 06:20 AM   #1230
robolop
My Ride: 323ci
THX DUDI
Old 03-31-2010, 03:58 AM   #1231
robolop
My Ride: 323ci
This piece will connect nicely onto the exhausts. First, I taped the bumper.
Put on 4 layers of fiberglass cloth.
This will be the foundation for the piece.
I glued some MDF against this, and put some model into it.
Then I mounted it on the car, and you can see I'm working with great accuracy.
The space between the tubes and the piece is not more then 2 or 3 mm.
I want as little space as possible between there, but this is a bit TOO small. A child knows this will rattle after 5 kilometers.
So I took a little slath of 6 mm, and drew it out nicely onto the piece.
Then I defined the length of the tubes.
You can see the line, that they'll come out about 10mm. The outer mufflers will come out a bit more.
I determined this by the rounding of the bumper, when you look from above.
Then I looked with a sway-hook to get them diagonal aligned.
Here you can see how many space I have now. I sprayed the piece black to have a better view on it.
Now I'm about to saw the tubes on the good lenght, and spot-weld them on 4 places, then again, making sure they are still on the same line.
I made a mold of the black piece you see here. For the moment it is drying.
Once this piece is ready, I'm putting it back in the mold.
Old 03-31-2010, 04:57 AM   #1232
hennep E46
Excellent work again Rob, is there going to come something in between the open space of the exhaust tips or are you gonna leave this space open.
Old 03-31-2010, 02:58 PM   #1233
The Chosen One
My Ride: E46
Old 04-02-2010, 07:14 AM   #1234
robolop
My Ride: 323ci
THX DUDE 's
Old 04-02-2010, 07:54 AM   #1235
h82lose
My Ride: 335i
wow, amazing job!
h82lose is offline   Reply With Quote
Old 04-02-2010, 09:04 AM   #1236
jbfrancis3
Formerly Snox400
My Ride: 1999 323i
Awesome progress!
The exhaust tips look so much better even though they haven't been cut down yet. I didn't read carefully enough above and thought that quad pipes were the final look, without the 'end-pipes'....
jbfrancis3
jbfrancis3 is offline   Reply With Quote
Old 04-03-2010, 05:33 AM   #1237
robolop
My Ride: 323ci
This is the polyester piece that came out of the mold. You can see I painted it black...and you know what happens next...
I can tighten this piece with screws on the backside. IF the epoxy or the varnish would fall in after a while, maybe from the heat, I can reel it off, and varnish it again.
The tips are customized, and I point-welded them on.
On this picture you can see I sawed them af slantlng. I did this because it looks a bit more refined that way, but that's each for his own.
You can also see that I only let them come out about 10mm
During a test-drive I noticed that the mufflers came against the sides a few times. I fixed this by adding a bit more space in between, it's now 8mm
This is a picture that makes you say: "it's ok, or no, put it in the bin"
You be the judge, but I like it.
Once I had all of this, I dismantled it all, and welded the tips completely.
Afterwards, I mounted it all again, said some prayers that it didn't become awry from the welding.
For the moment it's all at the painters shop.
Because I don't have a line in the front bumper, I'm going to delete this with the rear bumper as well.
I also bought some M-Tech II sideskirts, so they are getting painted as well.
The end is coming near...and that's a good thing. I'm getting a bit sick working on that rear bumper, but already looking forward of messing with the ICE again.
When you do something different now and then...you stay sharp
Old 04-03-2010, 06:12 AM   #1238
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
as usual - great work
do all four tips get exhaust passing through them? I cant tell if or how the pipe routes over to the right side of the vehicle
I would love to do something along the same lines on my sedan
/_________\
O==[][]==O
Old 04-03-2010, 10:06 AM   #1239
robolop
My Ride: 323ci
I bought this one on ebay, for a bargain.
Old 04-03-2010, 10:07 AM   #1240
robolop
My Ride: 323ci
**amazing work!**
When I keep my camera this low, it won't work LOL
Rate This Thread
