Old 07-14-2007, 11:00 PM   #1
gocardinals
My Ride: 2000 323i
How do you remove the rear seat back?
I need to remove the back to the rear seat because i am installing a custom sub box. I need Help!!
gocardinals is offline   Reply With Quote
Old 07-15-2007, 12:17 AM   #2
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
you have a sedan i assume?
bottom of the seats just start pulling up.. theyll pop out in about 10 seconds.. the back of the seats you pretty much do the same thing..theyre all held in by metal clips. just start pullin
BreakMyWallet is offline   Reply With Quote
Old 07-15-2007, 07:49 PM   #3
gar777
My Ride: 2002 325i
what he said. I did this last week when installing Schroth harnesses. One tip: when putting the seat back in, you need to put two metal tabs on each side in to their respective slots and then you push down and back on the top and two male pieces will snap in to two female pieces up near the outside top of each side. There is a spring on each side which retains this part once you snap it it. good luck!
gar777 is offline   Reply With Quote
Old 12-12-2007, 09:09 PM   #4
Mike415
My Ride: '02 330i
BUMP!
I really cant get the top half out. Any suggestions? Its pretty hard to pull since I cant get my fingers behind the seats.
Sedan FYI
2002 330i GrauGruen
Mike415
Mike415 is offline   Reply With Quote
Old 12-12-2007, 09:24 PM   #5
Mike415
My Ride: '02 330i
Ok I got it.
Tip: Pull from the arm rest
(Take out arm rest by pulling up
Remove the leather covering behind it
Put your hand ion there and pull out while also pulling from the top sides. That way you can get your hand in.
2002 330i GrauGruen
Mike415
