Sponsored by BAVSOUND
Old 07-17-2007, 05:26 AM   #1
bjarneb
My Ride: BMW 320i E46
Navi retrofit install in E46
I`ve bought the BMW 16/9 professional headunit and the retrofit cable,
but there is no picture on the screen. I have the MK4 DVD Business navi computer. But when I tryed a MK4 DVD professional navi computer it works.
so I need to reconfig. the computer from business to professional.?
anyone have a DIY guide?
bjarneb is offline   Reply With Quote
Old 07-17-2007, 10:39 AM   #2
Technic
My Ride: 2015 320i
First connect the GT-1
1. Code ZCS/FA
2. select after sales replacement(retrofit)( i know it isn't, but other wise you can't code the MK4
3. select IKE
4. select language
5. then you have to selet the 3 languages
6. Then on the nav screen you wil see load software. But you can't see because your Nav still isn't code for the Monitor. Butt you musst put the V26 in the MK4.
7. after you putt the V26 you have to wait in about 2 minutes the screen wil come, last time it took about 4 minutes.
8. After the succesfull software load , you have to select recode the Navigation computer, an you can code the MK4 to your car.
http://www.x5world.com/navigation-sy...+code+language
Technic is offline   Reply With Quote
Old 07-17-2007, 10:41 AM   #3
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
from what i have seen, its very costly to do the retrofit.... i would just go aftermarket if i cared enough about having a screen... just my 2 cents
that said, good luck with the install
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 07-17-2007, 01:00 PM   #4
bjarneb
Thank you technik!
silly question perhaps, but what is a GT-1?
Old 07-17-2007, 01:31 PM   #5
Technic
My Ride: 2015 320i
Thank you technik!
Your local BMW dealer technician's diagnostic computer...
Old 07-25-2007, 03:28 AM   #6
p1tse
My Ride: Audi TT-admiring M3s
i've seen a write up, and looks a massive job
p1tse is offline   Reply With Quote
Old 07-29-2007, 04:52 PM   #7
bjarneb
now I have a new problem, the radio i have recieved is one with round connectors, and my retrofitcable has flat connectors, and they are both numbered so if I connect them i order to the numbers, it will short my fuse
any one have a wire diagram for the BM24 radio
If i only had knew how much trouble this retrogfit would cost, in time and agony, I would have bought the newest pioneer, because one can make that look like a pretty sweet install.
Old 07-29-2007, 07:36 PM   #8
Technic
My Ride: 2015 320i
There are OEM adapters (round to flat) for your issue...
Old 07-31-2007, 01:21 PM   #9
bjarneb
allrighty now I have navi and radio that works, but there is still one problem, my navi headunit (16/9) has a CD player behind the screen and when I got the Radio to work I thougth the cd player would work as well, but when I press the MODE button there is only radio and tape, I dont think it rekognizes the cd player, and I dont have a tape player
Old 07-31-2007, 01:53 PM   #10
Technic
My Ride: 2015 320i
The tuner that you got is hardwired for a Tape player; remember, you started from a Business Nav, which only came with Tape so the tuner did not have to recognize anything other than Tape.
You need a new/used BM54 Tuner which then will be able to recognize the CD Player housing in your upgraded Professional Nav screen (16:9).
Old 08-01-2007, 06:38 PM   #11
bjarneb
well thanks a bunch Technic, since I don`t have the BM54 tuner by hand anythime soon, I was wondering if I could use a Ipod for a music source? with the correct adapter of course.. and if I can, will I be able to use my steering wheel controller to change track?
Old 08-01-2007, 06:41 PM   #12
bjarneb
or maybe I can use a aftermarket cdchanger?
I am going on a roadtrip for summer vacation, and I need my music
Old 08-01-2007, 08:04 PM   #13
Technic
My Ride: 2015 320i
I guess that everything else -other than the CD Player housing- should be good to go...
