Old 07-18-2007, 08:06 PM   #1
white46
My Ride: e46 323ci
DIY on replacing Auxiliary fan?
is there any diy on Auxiliary fan?
i searched around but couldn't find any.
my aux fan is not dying.. it's running forever after car shut off.
and from search, looks like i need to replace Auxiliary fan.
if anybody know, please post links or explain procedure.
thanks in advance.
white46 is offline   Reply With Quote
Old 07-19-2007, 12:23 AM   #2
berserker
My Ride: 2000 328i stick
32 MM thin wrench on the fan clutch nut turn quickly clockwise (towards the dirver side in canada) while at the same time holding the water pump stationary using your method of choice. Lol cant give it all away...
Loosen it off - then remove the mountng bolts seperating the fan from the clutch....
Assembly is reverse
Torque on the fan-to-clutch = 10 Nm
Maybe a couple of squirts of WD-40 a bit beforehand, and a cold beer when you are done.
berserker is offline   Reply With Quote
Old 07-19-2007, 11:08 AM   #3
markusmark
My Ride: 2001330Ci
Assembly is reverse
Only if the car has an automatic tranny. I think the gent has a manual tranny and an electric aux fan.
markusmark is offline   Reply With Quote
Old 07-19-2007, 11:28 AM   #4
white46
My Ride: e46 323ci
yeah. i'm looking for any diy or instruction on replacing the electric aux fan.
since my car is 5spd, didn't really understand which fan "berserker" was talking about.
thanks for input though, and sorry for not specifying which fan.
Old 07-19-2007, 12:14 PM   #5
SnobordBum
My Ride: '99 328i, '95 M3
Seems that everybody is having this problem within the past few weeks (including me). Replacing the fan should only take about 15 minutes. First, take off the air inlet (4 pop plastic pop rivets), and the straight section and elbow section of the plastic air piping going to the airbox. Now you should see two screws at the top of the fan housing holding it to the chassis. On mine, one was a torx and the other was a phillips, but i think both should be torx. Just remove those, unplug the fan and slide it straight up. Installation of the new one is just as easy, just make sure that the bottom of the fan engages into the little slides so its held in place.
SnobordBum is offline   Reply With Quote
Old 07-19-2007, 12:44 PM   #6
white46
My Ride: e46 323ci
thanks for input.
i kinda thought it should slide out.
i need to change mine over this weekend. the fan is constantly running even though car has been shut off.
Old 07-19-2007, 01:19 PM   #7
berserker
1. Remove the air intake cover thingy (4 pop rivets)
2. Remove the screw on the left and the pop rivet on the left (top on either side)
3. Pull up
ARE you 100% sure that it is the rad fan that is the issue?
Old 07-19-2007, 02:28 PM   #8
white46
My Ride: e46 323ci
yes. i'm 100% sure. i checked with my mechanice too.
rad fan is constantly running even after car has been shut off for 5hours. lol
thanks for the help.
Old 07-19-2007, 02:37 PM   #9
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
This should help - http://forum.e46fanatics.com/showthread.php?t=483472
Tim
tim330i is offline   Reply With Quote
Old 07-19-2007, 02:45 PM   #10
white46
My Ride: e46 323ci
thank you boss.
Old 01-26-2008, 01:57 PM   #11
littlelenny
My Ride: 2003 330i
How about testing the auxiliary radiator fan.
Do's anybody know how to test the auxiliary radiator fan?
littlelenny is offline   Reply With Quote
Old 01-26-2008, 02:19 PM   #12
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
To test for what? To see if it kicks on? There is a thermo switch on the lower radiator hose that tells the fan to kick on once the coolant reaches a certain temperature this way it cools off the radiator. You can unplug that sensor and jump the 2 wires on the harness side and if the fans resistor is still good it should kick on, if not check your fuses and if those are all good ad still nothing more than likely the resistor to the fan is bad and you could jump the fans motor directly.
Jared
Ivegotissues666 is offline   Reply With Quote
