Thread Tools Search this Thread Rating: Thread Rating: 34 votes, 5.00 average. Display Modes
Old 10-06-2010, 01:18 PM   #21
Sixracer
My Ride: '01 325xiT, '85 M635
Anyone want to add the differential fluid change onto this thread? I was hoping to dot he diffs on my Xi at the same time.
...................2001 325Xi Touring..................1985 M635Csi..................
Sixracer is offline   Reply With Quote
Old 10-06-2010, 07:26 PM   #22
Kubica
My Ride: 2003 325xi
You just need a 14mm hex head socket and 2 quarts of some 75w90.
Old 10-07-2010, 11:10 AM   #23
Sixracer
A few images of the trans, xfer case, and diffs. I figure these will help me locate the plugs. (#5 on the trans, #10 on the xfer case, #10 on front diff, #5 on rear diff).
I picked up all the crush washers from Pelican parts.
Got the fluids from Turner:
http://www.turnermotorsport.com/html...=E46Xi-REDLINE
Seems like getting access to some of these plugs is going to be pain in the ass.
ID:	378669   Click image for larger version
ID:	378670   Click image for larger version
ID:	378671   Click image for larger version
Old 10-07-2010, 06:31 PM   #24
Kubica
My Ride: 2003 325xi
No it's easy with the car on 4 jackstands. Just take the front two shields off. The front fill faces the driver's side wheel. The drain points down and to the back of the car.
Put the 14mm socket on a 3 inch extension- can easily get all 4 this way.
Old 07-06-2011, 05:28 PM   #25
zhenkaaaM3
My Ride: Fst'r then your e46
i just did this fluid change with royal purple. Another DIY from mad russian.net says to use 2 bottles and also get a third. I probably used only 1 1/2 bottles. Do m3's use more fluid then a regular m54 engine?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 07-07-2011, 05:42 AM   #26
TiAg323ci
My Ride: 2000 323ci
I am not sure about M3's but I just flushed my 323ci's tranny with a little under 2 quarts of Redline MTL and about 1 1/2 quarts of Redline 75w90 in the differential. Car shifts like butter now - would highly recommend this to anyone with a manual
Koni FSD's | Eibach Pro Springs |Staggered 19" VMR 710's | Hotchkiss Sway Bars | BMW Performance CF Strut Bar | Meyle HD Control Arms, RSM, Diff. bushing | Powerflex FCAB, RTAB| Brembo Sport Slotted Rotors + Akebono Euro Ceramic | Simota CF CAI | Conforti Shark Injector | Stewart Water Pump | M3 front and rear spoilers | Depo smoked front/side signals, Eagle Eye smoked LED tails | ACS interior trim/pedals | UUC Rob Knob 5 & floor mats |
TiAg323ci is offline   Reply With Quote
Old 07-07-2011, 11:50 AM   #27
zhenkaaaM3
I need to do the differential.
Eugene
Old 08-12-2011, 06:18 PM   #28
E46BimmerLover
My Ride: 2001 325Ci ZPP/ZSP
Thanks for the sweet write up, each step worked flawlessly, the zip ties are needed for tubing if your not using a pump, without them oil will get everywhere lol, and boy is that stuff stinky. I noticed alot smoother shifting and gear engagement with the Royal Purple.
E46BimmerLover is offline   Reply With Quote
Old 09-19-2011, 11:14 AM   #29
CaptainMorganS4
My Ride: 01BMW330CI SOLDb5s4
im having issues with my 2nd gear popping out of place and reverse no longer activating the mirrors. should i try flushing the trans. fluid or should i just go ahead and accept its the trans mounts or possibly the bushings/synchro's that need replacing. (which means i have to fork over $$$ to rebuild the transmissions forks/bushings.) pun intended i just bought this car and its already as bad as my audi s4.
CaptainMorganS4 is offline   Reply With Quote
Old 12-29-2011, 02:58 PM   #30
e46frvr
My Ride: 02 330i
I know its been a while but for those who stumble on this thread - for mirrors, toggle the left/right switch on the mirror adjustment knob to the driver side.
And CaptainMorganS4, any updates on your issue? Just wondering..
PM me if you need help on any of below
DIY Maintenance: Alternator -- Master Brake Cylinder -- Brake Booster -- ABS/DSC unit removal/reinstall
DIY Mods: Bluetooth -- Plasti dip kidney grills and headlight inserts
WTB: Short shifter kit --Clear/smoked corners -- Clear/smoked side markers -- LED tails -- Angel eyes
e46frvr is offline   Reply With Quote
Old 12-30-2011, 05:14 PM   #31
CaptainMorganS4
sold the car.
like father.. like son
Old 05-14-2012, 04:13 AM   #32
ZANIESXD
My Ride: 2002 325i Sedan
pretty good tutorial but i dont think you need to waste 7 steps on jacking a car lol.
ZANIESXD is offline   Reply With Quote
Old 12-07-2012, 03:14 AM   #33
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
Is it nessecary to bleed the clutch after mtf change? Or is it as easy as changing the oil...
SteadyMobbin is offline   Reply With Quote
Old 01-04-2013, 09:11 PM   #34
mikeetastic
My Ride: lots of 3
bumping up this thread.. what is the torque for the drain and fill plugs please? will do mine soon..
should have done this when my tranny is on the ground when i did my clutch... argggh!
edit: any other fluid alternative aside from Royal Purple? my auto parts shops doesnt carry it for some reason.. how bout Pennzoil Synchromesh?
TIA..
mikeetastic is offline   Reply With Quote
Old 04-15-2013, 12:02 AM   #35
aglushen325ci
My Ride: 2003 BMW 325Ci
Transmission drain or fill plug tightening torque
Originally Posted by tim330i View Post
...Tighten to 44lbs-ft (I think).
Bentley Manual says:
Transmission drain or fill plug tightening torque: 50 Nm (37 ft-lb)
aglushen325ci is offline   Reply With Quote
Old 04-23-2013, 09:00 PM   #36
jerseyBMW2000
My Ride: 200 323i
Question
I've seen other posts/videos and have heard from some of my mechanic friends that you should flush the transmission at least once before buttoning it back up...Maybe flushing isn't the right word...they say to drain the old stuff, fill it with new and run it though the gears, then to drain it again and fill it with brand new fluid...thoughts?
jerseyBMW2000 is offline   Reply With Quote
Old 07-04-2013, 11:33 PM   #37
Hovs13
My Ride: E46 325ci
Manual Transmission Fluid Change DIY (Instructions & Pictures)
Changed my MT fluid earlier today. 1st change ever with 195k kms. Here's what came out. Pretty nasty. Click image for larger version
Hovs13 is offline   Reply With Quote
Old 07-09-2013, 01:32 AM   #38
bee-em-dougle-u
My Ride: 2002 BMW 325i
Nice write-up & pics! I'd add one other step to the procedure: drive the car at least around the block to warm up the fluid before you drain it, as it'll drain quicker and more completely. If you've been driving the car for an extended period, let it cool off for 30-45 minutes so it's still warm, but not scalding hot.
--Doug
bee-em-dougle-u is offline   Reply With Quote
Old 04-06-2014, 12:38 PM   #39
jason330cic
My Ride: 2001 330cic
I changed my transmission fluid today, it was very easy to do. You do not really have to jack up all four wheels to get the car level. Instead I jacked up the front of the car drained and filled it then lowered the car back down to get it level and let the extra fluid drain out of the fill hole.
Jason330cic
jason330cic is offline   Reply With Quote
Old 04-06-2014, 08:36 PM   #40
Optio
My Ride: 328i
This is how I did too.....much easier
Optio is offline   Reply With Quote
