Old 08-03-2007, 03:28 PM   #1
riznphoenix
My Ride: 2001 330i
P0705
Hey Guys,
We are going through monsoon season over here in Phoenix and it rained pretty hard. I went through a puddle and ever since that my car won't shift right there is an exclamation point where it shows what gear you're in and I ran the OBD and it came up with P0705 which is Transmission Range Sensor Circuit Malfunction (PRNDC Input). I saw a couple of other posts on that but no resoulution. I actually just put a brand new tranny in it so I'm hoping all have to do is replace that. Any stories?
Thanks guys
riznphoenix
2001 330i
riznphoenix is offline   Reply With Quote
Old 08-03-2007, 04:27 PM   #2
ssm1991
My Ride: 2004 325i
You're in luck my friend. I've been in this forum several months and you're only the second one (after me) that had this problem.
It's an easy part replacement: 3C Gearbox switch (P0705), partnum 24-10-7-507-818.
It's #9 (position switch) in this diagram from RealOEM: A5S325Z HOUSING WITH MOUNTING PARTS.
Mine was damaged because I mistakenly took the car to a high-pressure underchassis wash, so similar causes to yours.
Replace it right away. I ignored it for several days. The third time I went on limp-home mode, I couldn't even start the car -- the tranny warning lamp was just lit and didn't even display the gear position (P,N,D). Sort of like a three-strikes-you're-out thing the ECU does.
If your scan tool can reset codes, you can DIY it.
ssm1991 is offline   Reply With Quote
Old 08-03-2007, 04:33 PM   #3
ssm1991
My Ride: 2004 325i
Or maybe even just try to dry and clean the connectors with electronic cleaner spray. Maybe the connector wasn't locked/sealed right when your tranny was replaced so water got into it. It's supposed to be water-proof.
Old 08-03-2007, 05:25 PM   #4
ssm1991
My Ride: 2004 325i
Originally Posted by ssm1991 View Post
... you're only the second one (after me) that had this problem ...
Correction, you're the third one. Happened to another guy too: P0705 Code.
Good news is the solution was the same as mine. Bad news is it's $387 including labor if the dealer does it.
Old 08-03-2007, 05:41 PM   #5
riznphoenix
My Ride: 2001 330i
Awesome. I have an extended warranty on my car that covers all that, so I am going to take it in on Monday and get it fixed. Thanks man
Old 11-08-2007, 06:30 PM   #6
hil357
My Ride: 2001 BMW 325i
bump! the part is aobut $160, right? is this something you can do yourself...? i got the code tonight
hil357 is offline   Reply With Quote
Old 11-08-2007, 06:55 PM   #7
silentak1
Banned
My Ride: '03 330ci cabrio
If the $160 deal isn't real, Tischer BMW has it for $189.
Mileoneparts.com ---> 24-10-7-507-818
silentak1 is offline   Reply With Quote
Old 11-08-2007, 08:15 PM   #8
hil357
so labor is about $200..?
Old 01-02-2008, 12:41 PM   #9
Nique88
My Ride: 2000 328CI
Send a message via AIM to Nique88 Send a message via MSN to Nique88 Send a message via Yahoo to Nique88
Man I took my 2000 328ci to AAMCO. They couldnt even tell what the problem is. They replaced my gearbox and also the transmission and yet its still has the same problem. There is this burning toxic smell and RND and the SD and the M1...5 does not show. When the Error Symbol comes on the S D shows but the PRND does not.
I got the P0705 code and I saw on here that you guys have the same problem or similar. I have reported to AAMCO what u did. If they F up my ride I will report them to BAR.
Thanks. I will give u guys more updates...
Nique88 is offline   Reply With Quote
Old 11-19-2009, 11:19 PM   #10
eweis
My Ride: 1999 328i
Sorry to bump an old thread but I'm having this problem.
Actually, I just got my codes read and it came back with this one and 18 !! other codes (about 14 unique ones). All are Px7xx codes which means all are transmission-related codes. My car is a '99 328i with 125k miles.
Anyone ever have so many tranny codes getting thrown at once? I don't know where to start but on the other hand, it hasn't seemed to drive poorly other than I noticed today sort of a strange whining when accelerating.
Here are some of the codes:
p1750, p1751, p1749, p0705, p0727, p0732, p0733, p0734, p1747, p1748, p1781, p1765, p0758, p0763
eweis is offline   Reply With Quote
Old 11-16-2010, 10:55 AM   #11
karrowack
My Ride: 323it
Damn it all..
A local Mechanic recently replaced my shifter assembly after my 323i would not shift into gears. Now I have the code P0705 also now appearing days after but with no warning light in the car. How I found out about this was a fault code appeared during my State inspection on their OBD scan. Not sure how long that faulty sensor will let me drive the car..but I am depending on it for sure, so I am going to replace it.
Just thought I would also report my problem. I think it helps for everyone to see the logistics and outcomes of everyones situation when dealing with problems on their own.
karrowack is offline   Reply With Quote
Old 11-07-2011, 04:13 PM   #12
bwaymire
My Ride: bmw 323i
I got a P0705 error code after replacing the starter on my BMW323i. I read the following from Ricks free autorepair.com site "A monitoring switch is attached to the transmission where the shift cable attaches. This switch tells the computer what gear you selected. If the switch is out of adjustment, you will get
P0705 Transaxle range switch circuit malfunction (PRND321)
Here's how to adjust the switch to get the codes to go away
1) set the parking brake
2 Remove the air filter box assembly so you can access the transmission range switch.
3) Turn the key to the ON position, but do not start the vehicle. Move the shifter to the neutral position.
4) Align the alignment holes between the switch and the shift lever. Insert a 5mm drill bit into the adjustment hole to verify the proper alignment for the neutral position.
5) If the bit won't fit, the switch is out of alignment. Loosen the bolts and move the switch until you can insert the drill bit. Tighten the bolts to 96 INCH/lbs."
This fix seems easier than replacing the switch and I think we probably caused the problem when replacing the starter. Anyone concur?
bwaymire is offline   Reply With Quote
Old 03-30-2015, 11:46 AM   #13
DEADF15H
My Ride: 2001 325i Auto
I realize this is an old thread I'm resurrecting, but this was the first one I've seen with a resolution other than just replacing the part. I will try this, if I can find the "alignment holes between the switch and the shift lever". Then I'll pull the electrical connector, clean it and apply some dielectric grease. My problem is intermittent, I use the undercarriage wash at the carwash, so my guess is a loose or wet electrical connection may be the issue.
DEADF15H is offline   Reply With Quote
