Old 08-05-2007, 11:38 AM   #1
naraM
My Ride: JDM
Predator Chromiums
Hey
I was just wondering when you guys put your pred chroms on did you have to change any fuses? i dont remeber if i did. Second do you know wher the fuse box is?
E46 M3 - RIP
06 STi - Sold
E36 M3 - Current
naraM is offline   Reply With Quote
Old 08-05-2007, 12:53 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The Predator Chromiums come with a built in fuse, no need to change anything out.
Old 08-05-2007, 03:59 PM   #3
sstainba
My Ride: 02 325Ci
you'll want to swap the suplied fuse (5A) for a 1.5A.
sstainba is offline   Reply With Quote
Old 08-06-2007, 01:40 PM   #4
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
No sir. Run a 5AMP.
Jlevi SW is offline   Reply With Quote
Old 08-06-2007, 05:59 PM   #5
sstainba
My Ride: 02 325Ci
Originally Posted by Jlevi SW View Post
No sir. Run a 5AMP.
Um... no sir. 5As is about 3time the maximum rating for the ballasts. Perhaps you should look at the manufacture specs for the ballasts. And if you insist that they should have a 5A fuse, then by regulations, the wire used in the ballasts is insufficient to carry the current. You can also check up on that.
A 5A fuse is most definitely too large for this application.
Old 08-06-2007, 06:13 PM   #6
Sharky06
My Ride: 06 ZHP 6-SP
Send a message via AIM to Sharky06
No you dont need to change the fuse. It should be fine with the 5A. Fuse box is normally on top right( view from front of the engine facing the car.)
Sharky06 is offline   Reply With Quote
Old 08-06-2007, 06:28 PM   #7
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Our engineer has returned the results that 5Amp is exactly what should be in there. Thanks
Old 08-06-2007, 06:36 PM   #8
rmatt8748
My Ride: a car
Send a message via AIM to rmatt8748
i had the normal 5A fuse back in my m3 with 6k predator chromiums
no issues whatsoever
umnitza = awesome vendor
rmatt8748 is offline   Reply With Quote
Old 08-06-2007, 07:54 PM   #9
sstainba
My Ride: 02 325Ci
Your engineer is wrong. The wire leads for those are not even rated to handle that. The 20 AWG wire is rated at a max of 1.5A for power transmission. So by leaving that 5A fuse in there, you are allowing a 33% increase in the rated current capacity. That is dangerous. The entire point of the fuse is to protect the components downstream. If the fuse is too large, it doesn't do squat. You might as well have a 10A or 20A in there for all the good it will do.
If 5A was "just right" that would allow each ballast to pull approximately 35Watts of power. That is ridiculous! Even a fluorescent bulb for home use doesn't normally go above 15Watts.
If your engineer really thinks that, he's an idiot and should be fired.
Old 08-06-2007, 07:56 PM   #10
sstainba
My Ride: 02 325Ci
The problem is that you apparently don't understand the purpose of the fuse. Having a larger-than-needed one will not cause any problems - until there is a short. If a ballast shorts out and your fuse is too large, it will let the ballast burn, which can damage the wire and your car.
Surely there is someone else on here who is an electrician or an electrical engineer...
Old 08-06-2007, 08:02 PM   #11
umnitza
8774866489
umnitza's Avatar
We appreciate your concern for yourself and your fellow man, but we trust our engineers and in the 6+ years we've been working with them, we have not had a need to change the parts.
Should that need arise, we'll announce it here.
Additionally, from a non-engineering and purely field testing perspective the fuse has proven to be effective at doing exactly what it's designed to do.
Thank you.
Old 08-06-2007, 08:29 PM   #12
sstainba
My Ride: 02 325Ci
Thank you.
so damn then math and wire regulations... why bother putting a fuse in at all? it's cheaper not to.
Old 08-06-2007, 10:03 PM   #13
logikgr
logikgr's Avatar
My Ride: 2001 BMW 325i Sedan
Send a message via AIM to logikgr
I understand where you are coming from Sstainba. No need to make much noise. Just sit back, relax and wait for your, "I told you so.", moment.
logikgr is offline   Reply With Quote
Old 08-07-2007, 01:24 AM   #14
SmoKeNfLY
My Ride: AW ///M3 & SLK350
Thank you.
Hurray for field testing, I've had their gen 1s on my 2k 328i for almost 4+ years and I haven't had to replace it once. The only issue I've had with it was a wiring fault and not due to their design. When it came to lighting I only trust matt and his fine crew of installers.
SmoKeNfLY is offline   Reply With Quote
Old 08-07-2007, 02:09 AM   #15
Visor328i
My Ride: rolls on VS-XX
What's the warranty on Predator Chromiums ?? I bought mine from Jlevi almost 2 years ago and some wire connectors melted, one ring is split in half, they have fallen apart in the last few months and now they don't work at all...
Visor328i is offline   Reply With Quote
Old 08-07-2007, 03:05 AM   #16
SmoKeNfLY
Send your questions over to matt at info@umnitza.com.
Old 08-07-2007, 07:27 AM   #17
sstainba
My Ride: 02 325Ci
hmm... wires melted... i wonder if that has anything to do with the fuse being to big for them???
Old 08-07-2007, 09:53 AM   #18
umnitza
8774866489
umnitza's Avatar
Without knowing his facts, please don't speculate.
If he chooses, he can contact the original retailer and discuss his situation. We've - Umnitza and our partners and retailers - have never let a customer down when it comes to warranty or repair.
Old 08-07-2007, 09:57 AM   #19
umnitza
8774866489
umnitza's Avatar
The warranty is a lifetime.
Wire connectors not maintaining their connection are a direct result of moisture getting into them. If they are completely insulated at the time of install, you'll have many years of usage out of them without issues.
When a ring splits in half, this is something you will need to describe in more detail to your retailer - in your case JLevi and they can assist you.
Not working means that your fuse popped, as it should have, if it detected a "raised" condition - otherwise known as a short. You should go through all the troubleshooting steps with your retailer.
Old 08-07-2007, 10:32 AM   #20
sstainba
My Ride: 02 325Ci
melted wires isn't really "speculation." a fuse is designed to stop that exact thing. you even stated, erroneously, that "not working" means the fuse blew. so melted wires + blown fuse = short. however, the melted wires are a result of a fuse that is not of the correct (smaller) rating. had the fuse been smaller, it most likely would have blown before the wires melted.
anyway, "not working" does not absolutely mean the fuse is blown. it could be that the ballasts are just dead (open, not shorted) or that the rings have cracked or the ring electrodes have become to corroded to maintain an arc.
oh, and by "cracked ring" i mean that the gas discharge tube inside the plastic housing has cracked. that would allow the gas to escape and prevent a plasma arc from forming between the electrodes. --> no light.
