Old 05-08-2002, 05:32 PM   #1
Samir
My Ride: Supercharged E92 M3
ITG Airfilters
Did some tests on ITG's drop-in filter for the 330 yesterday and got some nice results. The best base run before the filter installation was 198.4HP/196.0ft.lbs (car wasn't as strong as it was on Friday...added humidity could have played a role). After the install, peak HP climbed to 199.9 and torque to 197.8. This might not seem very siginificant, but peak power is not everything. The largest gains were realized in the lower rev-range, where we saw gains of 2.5HP (2.9 crank) @ 4250 and 3.2ft.lbs (3.7 crank) @ 3000. Another interesting thing to note was the car's ability to hold peak HP for an extra 250RPM @ redline. Using these results in a 1/4 mile simulator, yielded an extra 1/3 car length and 2.7 mph in the trap. Considering the ITG drop-in filter costs about $50 (about $15/HP), and when compared with Dinan's CAI ($499/11HP = $45/HP), this proves to be an excellent performance modification (also takes about 1 minute to install)...
Samir is offline   Reply With Quote
Old 05-08-2002, 05:33 PM   #2
UltimateOne
Fanatics vs. E46 DTM 4evar
My Ride: Mustang GT
Send a message via AIM to UltimateOne
Wow, this is the reason I want the ITG for my Ecis intake tube.
UltimateOne is offline   Reply With Quote
Old 05-08-2002, 05:40 PM   #3
325cic
My Ride: ACS//325CIC
Re: ITG Airfilters
Nice results, I was looking for this result too. Thanks!
Hey, how much you pay to run a dyno test like this? I hear it run about $150 to $200 for 3 times. Is it truth?
325cic is offline   Reply With Quote
Old 05-08-2002, 05:42 PM   #4
Samir
Re: Re: ITG Airfilters
That's way too steep...$75 for a few runs (3-5) is normally what a shop should charge.
Old 05-08-2002, 05:44 PM   #5
superdad
Domestic Engineer
My Ride: bmw
so would a K&N drop filter be about the same thing?
superdad is offline   Reply With Quote
Old 05-08-2002, 05:47 PM   #6
325cic
I heard K&N not as good as ITG filter, but I am not sure because I never see the comparsion between both filter.
Old 05-08-2002, 05:48 PM   #7
325cic
Re: Re: Re: ITG Airfilters
Thanks Samir,
I will keep that in mind so no one can jack **** me.
Old 05-08-2002, 06:02 PM   #8
superdad
Domestic Engineer
My Ride: bmw
So you only changed air filters and no other mods to get those numbers right?
Old 05-08-2002, 07:18 PM   #9
zivagolee
My Ride: 03 Orient Blue M3
Send a message via ICQ to zivagolee Send a message via AIM to zivagolee Send a message via Yahoo to zivagolee
Wow.. where to order one of these filters?
2003 Orient Blue M3
zivagolee is offline   Reply With Quote
Old 05-08-2002, 08:58 PM   #10
vthee
My Ride: 328i
Send a message via AIM to vthee
can someone compare the 2? i really think the gains on both are almost the same...
vthee is offline   Reply With Quote
