Old 08-07-2007, 11:20 PM   #1
area51alienware
My Ride: 03 330ci
Rear Deck Rattling From Bass!!!
my rear deck is rattling from the bass in my 330ci and i need to know how to fix it and anyone help me please?!?!?!
PUSH THE LIMITS.
area51alienware is offline   Reply With Quote
Old 08-08-2007, 12:01 AM   #2
KYC
My Ride: 2003 325 xi
You can take out the rear seat and shove old T shirts under the rear deck. That's what I did and the inside rattling stopped. I also just sound deadened my trunk lid and the inside of the rear quarter panel. That stopped 90% of the rattling and actually makes the bass much more precise.
Hope that helps!
KYC is offline   Reply With Quote
Old 08-08-2007, 01:26 PM   #3
DirtyMidget
My Ride: 2003 325ci
I have the same problem in my 325ci. I am going to stuff up some socks in there and see how it goes. Right now I have both my back seats down and it has made a huge difference. But I don't want to go around with my back seats down and someone taking a look, seeing my amp and suddenly thinks take it for themselves.
DirtyMidget is offline   Reply With Quote
Old 08-08-2007, 01:27 PM   #4
javanutsy
My Ride: 04 330Ci 6SP ZSP ZPP
I did something similar... Took out the subs and stuffed 3 tennis balls under teh rear deck. No more annoying rattles from back there.
javanutsy is offline   Reply With Quote
Old 08-08-2007, 01:36 PM   #5
intensify
My Ride: 2002 330ci
Send a message via AIM to intensify
same thing happened to me. i stuffed some thick card board in there. no more rattle for me
<div align=center><a href=http://www.intensestudio.net/images/lipsig.jpg target=_blank>http://www.intensestudio.net/images/lipsig.jpg</a>
www.myspace.com/intensestudio
intensify is offline   Reply With Quote
Old 08-08-2007, 02:29 PM   #6
mkodama
mkodama's Avatar
I had some wires that were rattling. I just laid down inside my trunk and used a few zip ties.
Old 08-08-2007, 03:36 PM   #7
DinanBMW330
My Ride: 330ci
Send a message via AIM to DinanBMW330
If you remove the HK subs that are attached inside the roof of your trunk, you will see several holes between where the subs used to be. If you put a long bolt thru there with a nut on the end and tighten it, this will apply pressure on the back shelf from the bottom (inside the trunk)
Basically, you are pressing the layers in your back shelf together with a bolt/nut, which stops it from rattling. I did it and it works great. There is a DIY with pictures on here somewhere. Do a search for HK rattle fixes or something
Andrew.
DinanBMW330 is offline   Reply With Quote
Old 08-09-2007, 12:37 AM   #8
IAmHollyWood
My Ride: 2001 325i
dynamat maybe?
2001 325i
IAmHollyWood is offline   Reply With Quote
Old 08-09-2007, 11:59 AM   #9
MerDoX
My Ride: '07 530i
Send a message via Yahoo to MerDoX
Dynamat won't help much since your HK subs are pounding against a thin top panel. That's where the bass comes through into your cabin. I use a bolt/nut to hold it in place (as described above). I think using towels or bedsheet may dampen or block out some bass but I guess tennis balls work as well.
MerDoX is offline   Reply With Quote
Old 08-09-2007, 03:25 PM   #10
DinanBMW330
My Ride: 330ci
Here is the DIY with pictures.
http://www.cardomain.com/ride/262483/2
Andrew.
Old 08-09-2007, 04:10 PM   #11
e popa
My Ride: M3,Sc323ci,Ml320
Take out the hk and jam 3 tennis balls in there 1 on each sid and 1 in the middle never rattle again.
OG f**k the fame I want the money
http://www.youtube.com/watch?v=ni6ZR18MXQ4
Supercharged 323ci SOLD SOLD SOLD
AW M3
Matte Black CSL's,gills & grills
brembos, Dinan exhaust
Alacantra wheel
OEM CSL trunk,VCSL roof,bumper,diffuser
e popa is offline   Reply With Quote
Old 08-13-2007, 01:01 PM   #12
325beemer
My Ride: 2001 325ci
wow thats jokes, i thought i was the only one stuffing t shirts in the back. looool
325beemer is offline   Reply With Quote
Old 04-22-2008, 11:43 PM   #13
CGRIZZ516
My Ride: 2000 323ci
I just did the "bolt" method and I'm more than happy. I was motivated after I put my Dice Silverline in the car. I did one thing different and folded a microfiber towel a few times and placed that between the bolt and the rear deck. The bolt was sitting flush and I figured the cloth would help reduce vibration just that little extra bit. So far I'm happy, never really was able to appreciate the HK, its really not that bad especially for a factory setup.
"If Barbie is so popular, why do you have to buy her friends???"
ECIS Intake / Shark Injector / Stock Type 44's
CGRIZZ516 is offline   Reply With Quote
Old 04-22-2008, 11:49 PM   #14
w0w
My Ride: '02 M3 Vert
anyone tried to fix the problem with the stock sound system (no hk)
daron
w0w is offline   Reply With Quote
Old 04-23-2008, 12:03 AM   #15
frogg320
My Ride: 2000 323i
Nobody suggested turning down the bass yet?
frogg320 is offline   Reply With Quote
Old 01-10-2013, 03:04 AM   #16
tacomeat1
My Ride: '05 M3 Carbon Black
How dare you even suggest that I'm tryin to look cool here!!!!
tacomeat1 is offline   Reply With Quote
Old 01-10-2013, 09:29 PM   #17
BringsMeWomen
My Ride: 2001 330ci
I have 2 alpine type r's 12' in my 330ci and have some rattling but its not terrible actually but im gonna need to try some of these suggestions to fix it.
BringsMeWomen is offline   Reply With Quote
Old 01-14-2013, 08:39 PM   #18
Zatarain
My Ride: 2000 323Ci
Just tried the sock trick and it does work for sure. I bought some tennis balls but couldnt get em in there. Long story short, my bass is a lot crispier now.
Zatarain is offline   Reply With Quote
