Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Old 08-14-2007, 03:00 PM   #1
simplyj
My Ride: the subway
Opinions on Gaspari SizeOn vs. regular Creatine Monohydrate?
SizeOn has gotten good reviews on the web, but I'm always skeptical about the new creatine kid on the block. I don't know much about creatine gluconate which is used in SizeOn, but Gaspari guarantees no stomach bloat and discomfort. I tried monohydrate a couple years ago and my stomach couldn't handle it. I was thinking about giving it another try but then came across SizeOn on BB.com. Thoughts?
simplyj is offline   Reply With Quote
Old 08-14-2007, 03:46 PM   #2
M3bluewater
My Ride: 95 M3
Send a message via AIM to M3bluewater
Use monohydrate. Its been the only tried and true for so many years...
There are now studies that show how other creatines (besides monohydate) convert to creatinine (the stuff you pee out) much faster. Yeah, you might get faster absorbtion and no bloating or whatever but what you flush down the toilet will be expensive stuff!!!
''Creatine ethyl ester rapidly degrades to creatinine in stomach acid"
Child R1 and Tallon MJ2
1Department of Life Sciences, Kingston University, Penrhyn Rd, Kingston-upon-Thames, United Kingdom. 2University of Northumbria, Sport Sciences, Northumbria University, Northumberland Building, Newcastle upon Tyne, United Kingdom, DrChild@CR-Technologies.net
Creatine ethyl ester (CEE) is a commercially available synthetic creatine that is now widely used in dietary supplements. It comprises of creatine with an ethyl group attached and this molecular configuration is reported to provide several advantages over creatine monohydrate (CM). The Medical Research Institute (CA, USA) claim that the CEE in their product (CE2) provides greater solubility in lipids, leading to improved absorption. Similarly San (San Corporation, CA, USA) claim that the CEE in their product (San CM2 Alpha) avoids the breakdown of creatine to creatinine in stomach acids. Ultimately it is claimed that CEE products provide greater absorption and efficacy than CM. To date, none of these claims have been evaluated by an independent, or university laboratory and no comparative data are available on CEE and CM.
This study assessed the availability of creatine from three commercial creatine products during degradation in acidic conditions similar to those that occur in the stomach. They comprised of two products containing CEE (San CM2 Alpha and CE2) and commercially available CM (CreapureŇ). An independent laboratory, using testing guidelines recommended by the United States Pharmacopeia (USP), performed the analysis. Each product was incubated in 900ml of pH 1 HCL at 37± 1oC and samples where drawn at 5, 30 and 120 minutes. Creatine availability was assessed by immediately assaying for free creatine, CEE and the creatine breakdown product creatinine, using HPLC (UV)
After 30 minutes incubation only 73% of the initial CEE present was available from CE2, while the amount of CEE available from San CM2 Alpha was even lower at only 62%. In contrast, more than 99% of the creatine remained available from the CM product. These reductions in CEE availability were accompanied by substantial creatinine formation, without the appearance of free creatine. After 120minutes incubation 72% of the CEE was available from CE2 with only 11% available from San CM2 Alpha, while more than 99% of the creatine remained available from CM.
CEE is claimed to provide several advantages over CM because of increased solubility and stability. In practice, the addition of the ethyl group to creatine actually reduces acid stability and accelerates its breakdown to creatinine. This substantially reduces creatine availability in its esterified form and as a consequence creatines such as San CM2 and CE2 are inferior to CM as a source of free creatine.''
''Kre-alkalyn® supplementation has no beneficial effect on creatine-to-creatinine conversion rates.
Tallon MJ1 and Child R2
1University of Northumbria, Sport Sciences, Northumbria University, Northumberland Building, Newcastle upon Tyne, United Kingdom, 2Department of Life Sciences, Kingston University, Penrhyn Rd, Kingston-upon-Thames, United Kingdom. DrTallon@CR-Technologies.net
All American Pharmaceutical and Natural Foods Corp. (Billings, MT, USA) claim that Kre-alkalyn® (KA) a "Buffered" creatine, is 100% stable in stomach acid and does not convert to creatinine. In contrast, they also claim that creatine monohydrate (CM) is highly pH labile with more than 90% of the creatine converting to the degradation product creatinine in stomach acids. To date, no independent or university laboratory has evaluated the stability of KA in stomach acids, assessed its possible conversion to creatinine, or made direct comparisons of acid stability with CM.
This study examined whether KA supplementation reduced the rate of creatine conversion to creatinine, relative to commercially available CM (CreapureŇ). Creatine products were analyzed by an independent commercial laboratory using testing guidelines recommended by the United States Pharmacopeia (USP). Each product was incubated in 900ml of pH 1 HCL at 37± 1oC and samples where drawn at 5, 30 and 120 minutes and immediately analyzed by HPLC (UV) for creatine and creatinine.
In contrast to the claims of All American Pharmaceutical and Natural Foods Corp., the rate of creatinine formation from CM was found to be less than 1% of the initial dose, demonstrating that CM is extremely stable under acidic conditions that replicate those of the stomach. This study also showed that KA supplementation actually resulted in 35% greater conversion of creatine to creatinine than CM. In conclusion the conversion of creatine to creatinine is not a limitation in the delivery of creatine from CM and KA is less stable than CM in the acid conditions of the stomach.''
They dont talk about SizoOn or the creatine gluconate, but c'mon, Gaspari is just another company out there trying to make $$$ off of a hyped up product. Im sure if they did a study like this w/ SizeON vs. CM, the CM would once again take the cake.
Just stick to the basics and get some generic bulk creatine monohydrate!
Paul
M3bluewater is offline   Reply With Quote
Old 08-14-2007, 04:46 PM   #3
bimmerchop
My Ride: E46 M3
I have no experience with SizeOn, but 99% of the time, most creatine products are all hype. I'm a monohydrate fan
Rich | Flickr | Instagram
- AW/IR 6MT E46 M3
- JB/B 5MT E46 328i
- Pearl Stg3+ B5 S4 (sold)
EURO.techniks
bimmerchop is offline   Reply With Quote
