Old 08-19-2007, 03:03 PM   #1
328insane
My Ride: 2000 328i
AC clutch replacement?
Can anybody tell me how hard it is to change the AC compressor clutch assembly on a 2000 328i?
Thanks in advance
328insane
328insane is offline   Reply With Quote
Old 08-19-2007, 10:15 PM   #2
328insane
My Ride: 2000 328i
nobody on this site or BF.com seems to have any input or Ideas......sweet
Old 08-20-2007, 04:58 AM   #3
illduce
Just Gettin Started
My Ride: 00 328Ci
Send a message via AIM to illduce
I'm not sure but I don't think u can replace it. I know the dealer sells the whole ac compressor they don't sell just the clutch. I had to change my ac compressor when my ac clutch went bad. got it for 150 so it wasn't bad.
illduce is offline   Reply With Quote
Old 08-20-2007, 11:15 PM   #4
328insane
My Ride: 2000 328i
how much was it to recharge the system after that? did you get the kit to DIY it? Thanks for the info.....I appreciate it
Old 08-21-2007, 04:10 PM   #5
gunth3r
My Ride: E36 M power
I replaced the clutch plate on the compressor before. The dealer doesn't sell just the clutch plate so you're going to have to find a used scrapped compressor and take off the clutch plate. I got mine free from the wrecking yard.
*Removal for a compressor that is off the car*
You can use a impact gun to get the 13mm nut off the front of the pulley then there's a series of washers that you should keep track of that comes off the pulley. Once the pulley comes off there's a clip holding the clutch plate on. Remove that and it should come off. I used this method on getting the clutch plate off the used compressor.
*Removal for the compressor on the car*
But there's no room for the impact wrench between the fan shroud so the method i used to get the clutch plate off of the compressor on the car was by holding the pulley with my hand and untightening the bolt. It only takes one swift turn to brake it loose then its no problem getting the pulley off.
After the pulley is removed you have to take off the clutch plate, First remove the clip then pull it off. It may be kinda seized from the heat of the motor so I had to spray some pb blaster on it and tap it with a screwdriver and hammer to lossen it up. Make sure you don't tap on the lip where the clip slips into. Its aluminum and will break.
I would recommend taking off the clutch pack from the compressor off the car first then you'll see what needs to be done before you do it to yours.
Make sure you clean the magnetic pulley that the clutch plate goes on before reinstalling, dirt and grim will cause it to clatter.
Good luck buddy.
FYI- It didn't fix my problem, i think i got a bad clutch pack.
gunth3r is offline   Reply With Quote
Old 08-21-2007, 11:20 PM   #6
328insane
My Ride: 2000 328i
thanks for the great info. I really appreciate it! Mine is clattering right now, I may see about taking it apart and cleaning it first. Thanks again!
Old 08-25-2007, 09:00 PM   #7
alvocado
My Ride: 2002 330CIC Sport
Are you sure it's just the clutch or is the compressor going bad? I just had one changed on a Yukon last week and learned that if you change the compressor, you also need to change the accumlator and orifice tube. You'll need to flush the system before recharging and you need to carefully measure the amount of compressor oil removed in order to fill the new unit to the same level. Unless you do A/C work often and have all the equipment, this is one to hire out IMO.
alvocado is offline   Reply With Quote
