Old 08-24-2007, 12:49 PM   #1
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
help with p46 projecting on diff levels?
one side projects higher than the other, i had someone drive my car so i can test it and one is bright and the other is not, then when i get real low the other one gets just as bright, is there a way to change the levels or something?
aphhpa is offline   Reply With Quote
Old 08-24-2007, 03:05 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep, there are vertical adjustment knobs right on top of the headlight that you can turn. There are also horizontal adjustment knobs that you can turn with a flat head on the back of the headlight.
Old 08-24-2007, 05:32 PM   #3
jbost002
My Ride: 2003 BMW 325i
How do you know the proper level to adjust to? What's a good guide to use?
jbost002 is offline   Reply With Quote
Old 08-25-2007, 01:00 AM   #4
aphhpa
My Ride: 2001 330Ci
I second that, I cant get tem on the exact same level now.. is there a way to do that? and how do I know if it may be too high or low?
Old 08-25-2007, 03:01 AM   #5
sillieidiot
My Ride: '06 AW 330ci
using the adjustment knobs on top of the headlights
1. find a flat level place in front of a wall
2. park your car close to the wall
3. mark (with tape or something bright so you can see it from far) here the headlights would be on the wall if they were touching
4. back up (straight from where you were from the wall) 20ft.
5. adjust so that the top of the cutoff is 3 inches below the mark (from #3)
6. you're done, now enjoy not blinding people.
