help with P46!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-25-2007, 10:12 PM   #1
aphhpa
My Ride: 2001 330Ci
Send a message via AIM to aphhpa
help with P46!!
I just got them and installed and they are projecting on diff levels and i spent HOURS literally trying to get them exactly the same and NOTHING works.. and one even seems bluer than the other sometimes... its just no matter what i cant get them perfect, hooowwww do you do itt?!!?!?!?!?
aphhpa is offline   Reply With Quote
Old 08-26-2007, 04:41 AM   #2
aphhpa
My Ride: 2001 330Ci
bummpp - I really wanna get this fixxed =P
Old 08-26-2007, 04:55 AM   #3
sillieidiot
My Ride: '06 AW 330ci
the adjustment knobs are on top of the headlights.
the pattern should look something like this (if you were to get them straight):
Sponsored Links
Advertisement
Old 08-26-2007, 12:10 PM   #4
sandman512
My Ride: 2005 325I
Just make sure that the bulbs are correctly seated and locked in. I had a problem once where the beam that was projected was not correct. It turns out that the bulb was locked in place, BUT was crooked. Worth a shot. Good Luck.
sandman512 is offline   Reply With Quote
Old 08-26-2007, 03:48 PM   #5
aphhpa
My Ride: 2001 330Ci
thanks heres another question tho. When i installed these i had to break ou my old headlights cuz the 2 buttom bolts were impossible for me to reach so when i installed these i only used the 2 top ones.. and no bottoms, would that maybe be why? ive played with the knobs for HOURS. 2-3 in a row 2 diff times. I cant get them right... and the lines on the wall are too different to be able to line up.. I got the bulbs preinstalled by jlevisw so I dont know how to check if they are crooked
Old 08-26-2007, 04:11 PM   #6
sillieidiot
yea that could be why. go get a magnetic and antenna. that's all you need. and a ratchet with a long socket extension.
Old 08-26-2007, 04:20 PM   #7
sandman512
My Ride: 2005 325I
First, I would do what sillie said, it was quite possible that is throwing everything off. Second, the bulbs are put into the headlight and there is a metal retaining type clip that snaps in to hold them in place. Just make sure that they(bulbs) are SEATED right in the headlight and the clip is properly attached. Also, when you move the knobs, do the headlights move at all? If not, I would contact JLEVI and ask them if they could been over extended and popped off.
Old 08-26-2007, 07:05 PM   #8
aphhpa
My Ride: 2001 330Ci
not sure if i have access to the kind tools i need.even if i did have long rachet. it didnt seem like even that would workbut ill look. but yeah when i turn the knobs the headlights do move up and down. but then when i think they may be lined up on the wall as close as they will possibly get, i stand in middle of car and slowly walk back and one gets brighter way before the other one meaning it projects higher i assume, so ill lower it and thent he lines ont he wall are way off... and then also one of them will be blue when one isnt at certain levels... grr
Old 08-26-2007, 08:11 PM   #9
sandman512
My Ride: 2005 325I
I don't know if this will help, but here is a pic. of the light pattern from 25 feet.
