Old 08-26-2007, 02:36 AM   #1
vanillaface
My Ride: '00 328i
Need new HID bulbs, what are my options?
...on a 2000 BMW 328i w/projector HID headlamps. The driver side bulb is flickering on and off with the headlight error light on the dash visible. I'm going to assume this means I need a new bulb.
I'm looking for something that looks white and casts a good amount of light. I don't want a purple sheen nor a dull yellow. What are the options?
vanillaface is offline   Reply With Quote
Old 08-26-2007, 03:23 AM   #2
JJR4884
My Ride: BMW
k you have two options.......
your problem might not be the bulb, it could be your stock ballast
first thing to do......... switch your two headlights
if the other side flickers, then you know its the bulb
if the same side flickers, then you know its the ballast
if option 1 is the case, then go to visionbulbs.com or another sponsor from this website, and get some new bulbs (get 6000k )
if the same side flickers (option 2), then that means the ballast is probably on its way out, and you would have to replace it from the dealer, or as i would suggest, find it online for a lot cheaper
JJR4884 is offline   Reply With Quote
Old 08-26-2007, 03:57 AM   #3
sillieidiot
My Ride: '06 AW 330ci
it's most likely your bulb given the year of your bmw and given that they are your stock xenons. if you never changed out your bulbs, it's probably time.
5000k would be your best bet. it's pure white, no yellow or hint of blue. these are rare. other wise 4300k (stock) or 6000k.
Old 08-26-2007, 12:50 PM   #4
vanillaface
My Ride: '00 328i
Thanks for the quick relplies, and good idea about bulb/ballast testing. I've never had issues with HIDs in the past, so I've never had to learn the ins and outs.
What brands have a good reputation and/or inexpensive? After reading other posts on the subject, I've decided on 6000k.
I've seen several options online, but I understand that there's always those secret deals or niche brands that everyone on a forum generally knows about. Any help is greatly appreciated.
Old 08-26-2007, 03:54 PM   #5
sillieidiot
buy from visionbulbs. they have the cheapest pair here. for one of the best 6000k brand. it would be the phillips ultinons. but those are very expensive. for what you're looking for, i'd say just get the visionbulbs ones. they last a long time anyhow
Old 08-26-2007, 07:04 PM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Definitely make sure it's the bulb first, if it is the bulb we have D2S replacement bulbs for your OEM xenons right on our website. You can even upgrade the color temperature to a more pure white 6000k. Here is the product page for you:
D2S OEM Xenon Upgrade Bulbs
Old 08-27-2007, 11:47 AM   #7
vanillaface
My Ride: '00 328i
I did the bulb-switch as someone suggested, and it certainly is the bulb. Thanks for the help!
