Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 08-30-2007, 05:05 PM   #1
mpegripper
My Ride: M3
Send a message via AIM to mpegripper
double din install floor vent damper
did anyone modify their's or fabricate a new one?
everything i found was of people cutting their's out.
i want to keep mine and am trying to find a solution
100% Stock
mpegripper is offline   Reply With Quote
Old 08-31-2007, 07:04 AM   #2
SrCsTc@MyBimmer.net
Past Site Sponsor
SrCsTc@MyBimmer.net's Avatar
My Ride: 00 323Ci
Send a message via AIM to SrCsTc@MyBimmer.net Send a message via Yahoo to SrCsTc@MyBimmer.net
http://forum.e46fanatics.com/showpos...&postcount=275
SrCsTc@MyBimmer.net is offline   Reply With Quote
Old 08-31-2007, 07:06 AM   #3
SrCsTc@MyBimmer.net
Past Site Sponsor
My Ride: 00 323Ci
These were also posted by another member of this forum...
Old 08-31-2007, 07:08 AM   #4
ca1242
My Ride: 2003 330i
What we do is a bit simpler than ^.
There is an attachment point on each damper for the connecting rod. We cut them out with a dremel, relocate them to the lower part of the dampers, Tack them with glue, then epoxy them and fill the upper holes. The original rod is reused and works normally. You do have to notch out a 1/2" corner out of the right damper so it clears the new "walls".
Old 08-31-2007, 01:00 PM   #5
mpegripper
My Ride: M3
awesome, thanks guys
100% Stock
Old 08-31-2007, 02:10 PM   #6
Cruzer03
My Ride: 03.5 M3 JB/IR
Pics?
Cruzer03 is offline   Reply With Quote
Old 09-03-2007, 06:41 AM   #7
ca1242
My Ride: 2003 330i
Here's a couple pics:
ID:	241007  Click image for larger version
ID:	241008  Click image for larger version
Old 09-04-2007, 11:19 AM   #8
Cruzer03
^ Thanks!
Old 09-04-2007, 02:35 PM   #9
amunoz27e
My Ride: 325ci
Hey Cruz, I like your location "Hooters Germany" LOL
Hey Thanks CA1242, thats a great idea. I kept all of my parts I took off so all I have to do is do the fabrication and wallah my vents are back in operation.
Bilstein PSS10 Coilovers | Highline Tuning Catback Exhaust | Double Din Audio | Lots of Carbon Fiber Interior/Engine Bay | 19x8,19x9.5 Wheels | RIP - Reiger Body Kit .
amunoz27e is offline   Reply With Quote
Old 09-06-2007, 06:56 AM   #10
Cruzer03
I know, I like it too....
Are you willing to help if I decide to go with a Double DIN?
Old 09-06-2007, 10:07 AM   #11
amunoz27e
My Ride: 325ci
Sorry to jack this thread MPEGRIPPER.
Sure. Just let me know when you want to do it, I think I still have the old metal template, if not its easy to make.
Hey Cruz I found the SD chip on the European maps for my nav on ebay, ordered it last night. It was 75 dollars cheaper than from Garmin.
You coming to the Ansbach car show saturday? I am at Graffenwoehr right now, but on my way back I am stopping at the show on Saturday. Not sure what time the guys from K-town are leaving but they want me to hold 5 spaces, if you comming, let me know so I can hold a spot for you too.
Old 12-27-2007, 03:16 AM   #12
mpegripper
My Ride: M3
i'm actually going to do this real soon, do u have the template?
100% Stock
Old 12-30-2007, 05:02 PM   #13
amunoz27e
My Ride: 325ci
Sorry I got rid of it, but it was sort of easy to make. Got some tin snips, bought two sheets of thin metal, I think they were 12 x 12 inches. Measured the width, depth, and height and traced it on the metal sheet, then cut corners out, bent metal in to make the box leaving a small lip on other side that way I had something to mount it to. Drilled some holes to mount it on the back wall.
Here are some pics. First pic you will see the radio metal mounting bracket. I used that to mount the radio instead of mounting the radio to the plastic mounting bracket with MDF boards as everyone posts in the forum. Last pic shows a slight gap at the bottom, but that was fixed once I powered up the radio and adjusted the screen angle. Hope this helps.
ID:	254489  Click image for larger version
ID:	254490  Click image for larger version
Old 03-31-2008, 09:06 AM   #14
mquraish
My Ride: 330xi
how to get right damper out
I know this thread is a bit old, but can you tell me how to get the right damper out to work on it without breaking it? I can't figure out how to get it out without breaking off the arm on top.
thanks for any help.
mquraish is offline   Reply With Quote
Old 03-31-2008, 11:37 AM   #15
ca1242
My Ride: 2003 330i
1. Remove top control arm (white).
2. pry apart duct connections (damper is between the two ducts)
3. wiggle damper out (while prying duct joint apart)
Old 04-01-2008, 10:26 PM   #16
mquraish
My Ride: 330xi
thanks for the reply - I'll give it a shot
Old 05-10-2008, 02:50 PM   #17
mquraish
My Ride: 330xi
just wanted to pass on another take on the damper issue, HERE.
Old 05-11-2008, 08:01 AM   #18
ca1242
My Ride: 2003 330i
That is exactly what we do with the dampers.
Old 05-11-2008, 02:51 PM   #19
mquraish
My Ride: 330xi
nice - I thought I was taking it a step further than what you guys had posted in other threads - but I guess I'm still behind the curve.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2010 performanceIX Inc - privacy policy - terms of use
