Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 09-05-2007, 12:06 PM   #1
DiceyOne
My Ride: 1999 328i
Send a message via AIM to DiceyOne
Hum/Buzz noise after ignition shut off. any ideas?
The story goes pretty much how the title says it. After i cut the ignition there is a humming/buzzing that comes from the engine bay and lasts for about 1 second. It definitely sounds like some sort of pressure being released with the way that it fades out. I also get the same humming noise if i jab the throttle before the engine responds to the increase of gas. It doesn't seem to be effecting the performance of the car but it does piss me off. any ideas on what this could be? thanks for the help.
DiceyOne is offline   Reply With Quote
Old 09-05-2007, 12:15 PM   #2
jmcdolej
My Ride: 328i-GONE ;(
Not the fan I take it? Sometimes on hot days my fan runs for a few after I shut the car off. Just a thought.
http://forum.e46fanatics.com/showthr...670&highlight=
The story of the "thing" in my sig!!!!!!
jmcdolej is offline   Reply With Quote
Old 09-05-2007, 04:32 PM   #3
DiceyOne
My Ride: 1999 328i
no i don't belive that it's the fan. i really wish i knew how to just record that sound and then somehow post it. it's just this hum/buzz that sounds like the car's way of sighing after i turn it off...haha i'm not that hard on it.
a friend of mine mentioned something about a positive crank case ventilation valve. i don't exactly understand what that is or even if it applies to BMW's but that's my only lead so far.
Old 09-05-2007, 04:37 PM   #4
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Do you have DDE's installed?
hi its me alec is offline   Reply With Quote
Old 09-05-2007, 04:38 PM   #5
jmcdolej
That was my next thought.
Old 09-05-2007, 05:29 PM   #6
DiceyOne
My Ride: 1999 328i
No DDE's but i do have some aftermarket H7 bulbs. not sure if that would be a problem.
Old 09-06-2007, 06:55 PM   #7
logikgr
logikgr's Avatar
My Ride: 2001 BMW 325i Sedan
Send a message via AIM to logikgr
Are you sure it's not the HVAC opening up?
logikgr is offline   Reply With Quote
Old 09-06-2007, 08:35 PM   #8
adamlutz
My Ride: 1999 323i
I have a noise after i turn off the car too - what is the HVAC and what does that sound like?
BMW OF MANHATTAN & LITTLE GARAGE SERVICED
adamlutz is offline   Reply With Quote
Old 09-06-2007, 09:06 PM   #9
vstol
My Ride: 2000 323i E46
Defective pressure regulating valve under the intake manifold. You can do two fairly simple things to confirm. With the engine idling, undo and slightly lift the oil service/fill cap on the cam cover. You may feel a lot of resistance - suction. At the same time, if the valve is defective, it will buzz. Clear cause and effect. Also, while at idle, place you hand on the vacuum line that attaches at the front of the cam cover near the VANOS. With you hand on the vacuum line, have someone turn off the ignition. When you hear the buzz at shut-off you will also feel it in the line. There are other ways to check the valve performance, but this is quick and costs nothing. Good luck.
vstol is offline   Reply With Quote
Old 04-21-2008, 01:34 PM   #10
Dkny956
My Ride: 2000 323i
2003 323i
My car does the same thing! It is the Idle Regulating Valve, I know this for sure but i dont know why it makes that weird sound when i shut of the car. Its the little diaphragm that makes the sound.
Dkny956 is offline   Reply With Quote
Old 05-05-2009, 02:19 AM   #11
Toadfart
My Ride: 04 330i ZHP
my car buzzes and it keeps my angel eyes on. Which is tapped into the ecu harness under the drivers side fender area as well as the footwell. The car buzzes and the light stays on even after i shut off the car and the footwell light is off.
Toadfart is offline   Reply With Quote
Old 03-15-2010, 12:19 PM   #12
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I've heard this noise before. I heard it again last night and got curious. I had just turned off the car after a 400mi road trip, with the last 160mi being non-stop. I could hear the hum from inside the car. I took the key out of the ignition and opened the hood. It was dark, but I could tell the noise was coming from near the intake-side of the engine. Sounds like an electric motor.
It made a humming noise for about 1 minute. As soon as it stopped, I heard about a 2-3 second *ppsssshhhh* pressure relief noise. There was also a brief groaning/creaking noise, just like when you set the e-brake and get out of the car and the suspension settles. I had already been out of the car for about 20 seconds, though.
Any thoughts on the groaning/creaking noise in conjunction with the humming noise? Maybe it was just a coincidence the suspension settled exactly at the same time...?
Old 03-15-2010, 12:40 PM   #13
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: 05 ZHP
Most bimmers do that, its certain components that need an extra couple seconds to shut down...if you have CAI mod, you'll hear it just a little bit more after shutting down your car...as far thathumming noise if you jab the throttle, don't know about that...
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 03-15-2010, 02:19 PM   #14
Malladawg
Beware of pwner
Malladawg's Avatar
My Ride: 2000 323I OrientBlau
Send a message via AIM to Malladawg Send a message via MSN to Malladawg Send a message via Yahoo to Malladawg
That's a normal noise for my car, but I have dde's installed. I think it's a normal thing when shutting down.
Malladawg is offline   Reply With Quote
Old 03-15-2010, 05:21 PM   #15
bimminge46
My Ride: 323Ci, 89 325i ETA
That is normal after shutdown. Mine also does the same.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 03-15-2010, 06:57 PM   #16
Redline
Redline's Avatar
My Ride: ///M3 Vert
Idk my car does this also, it makes a humming sound that sounds like it's coming from the center of the dash behind the radio. Also idk if this is normal but when I turn the key to the on position before startup my car makes a loud high pitched humming/ whining kind of sound, it sounds Sort of like a lamborghini before startup when the key is in the same position before you turn the key and is rather annoying. Any idea what that is?
k.
///M
Old 03-09-2011, 11:20 AM   #17
drfreeman
My Ride: 330i ZHP Titanium Si
check CCVV, if it failed it will generated honking, goose noise after engine shut down. It is diffrent from the normal hissssss....sound after you shut down engine. CCVV stated crank case ventilation valve.
drfreeman is offline   Reply With Quote
