Old 09-07-2007, 12:34 AM   #1
1024m3
My Ride: 04 M3
headlight cutoff bounces over bumps
Is there a way to tighten up the guts of xenon headlights? Mine have a slight bounce when starting and rolling over bumps??
89 Mazda 2200 commuter sold
97 328i sold
97 M3/2 sold
02 X5 sold
08 X5 4.8
04 M3
98 Taurus Beater
1024m3 is offline   Reply With Quote
Old 09-07-2007, 04:39 PM   #2
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
that is probably the auto leveling in action.
SL Blak Soldier is offline   Reply With Quote
Old 09-07-2007, 05:11 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
That's normal actually, they will bounce a bit.
Old 09-07-2007, 05:43 PM   #4
n2Bimmer
My Ride: Loves Corners
that can also be your car bouncing.lol
Old 09-07-2007, 06:33 PM   #5
1024m3
My Ride: 04 M3
Good points everyone! But only the driver side bounce excessivly so I did performed a fix by stuffing a small piece of rigid foam between the housing and reflector bowl. Look for the yellow thing...you can't even see it wuith the lense back on. I need to test this tonight. Sorry for the big pics.
97 328i sold
97 M3/2 sold
02 X5 sold
08 X5 4.8
04 M3
98 Taurus Beater
Old 09-07-2007, 07:27 PM   #6
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
That looks like a solution but I would caution you against doing that for one reason, the autoleveling mechanism. Your headlights are designed with a certain amount of play so that the mechanism can adjust their aim accordingly. If you hold them in one position, you risk jamming the motor and destroying your autolevel.
Old 09-07-2007, 08:34 PM   #7
1024m3
My Ride: 04 M3
Oh I should be okay...these are OEM lights I installed and the only feature I wired in was bi-xenon.
Too lazy for autolevel...
97 328i sold
97 M3/2 sold
02 X5 sold
08 X5 4.8
04 M3
98 Taurus Beater
Old 09-07-2007, 08:55 PM   #8
LW///M3
My Ride: 05 Sti >> E46 M3
did you first make sure that it was clipped in everywhere properly, there is no reason the cutoff should shake under normal conditions.
2009 ///M3 Space Gray on Fox Red
LW///M3 is offline   Reply With Quote
Old 09-08-2007, 11:07 AM   #9
1024m3
My Ride: 04 M3
Yeah I took them out and looked for a way to tighten them but that was the best they would get. My halogen housings did the same thing but wasn't quite as loose.
Last night they did pretty good on the road.
97 328i sold
97 M3/2 sold
02 X5 sold
08 X5 4.8
04 M3
98 Taurus Beater
