HID Housing Conversion - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-09-2007, 09:35 PM   #1
Inline
My Ride: 330ci
Exclamation HID Housing Conversion
I'm going to be in the process of transferring the HID components from a '03 M3 headlight housing into a '01 330ci headlight housing. From what I've read on the forums it's possible, but im interested to know if anyone here has done it and any advice would be greatly appreciated.
If im successful with the physical aspect of the upgrade will a dealer re flash be needed to get the electric/computerized aspect in order? or will a simple fuse removal suffice?
BTW my 330 was manufactured in 10/2000.
Thanks.
Inline is offline   Reply With Quote
Old 09-09-2007, 11:52 PM   #2
sillieidiot
My Ride: '06 AW 330ci
just pulling the fuse will be sufficient. why are you transfering the HID components into your 330 housing? the whole headlight should fit in your car fine. without that need
Old 09-10-2007, 12:12 AM   #3
logikgr
logikgr's Avatar
My Ride: 2001 BMW 325i Sedan
Send a message via AIM to logikgr
Make sure to keep everything clean, wear gloves. Last thing you want is to be all done and then notice a print on the reflectors.
logikgr is offline   Reply With Quote
Old 09-10-2007, 08:17 AM   #4
Inline
My Ride: 330ci
Originally Posted by sillieidiot View Post
just pulling the fuse will be sufficient. why are you transferring the HID components into your 330 housing? the whole headlight should fit in your car fine. without that need
Thanks for the response gentleman. I would like to do that but one of the HID housings is cracked. So its a strait swap with room for the ignitors or have I opened a can of worm of immeasurable proportions?
Old 09-10-2007, 08:53 AM   #5
HighVoltage
My Ride: 2007 335i
If its just cracked you can try using jb weld or some other epoxy to seal it back up. How bad is the break?
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
Old 09-10-2007, 02:31 PM   #6
sillieidiot
^ same question, same advice. maybe post some pictures of it if you can so we can see how bad it is.
