Old 09-11-2007, 09:09 AM   #1
marzman
My Ride: e46 328 Coupe
LED City light question
Hi Guys,
I've just bought a pair of LED city lights for my '99 328ci... but they're throwing a code.
I've been searching and i understand the reason for this, but they're also making my turn signals stay lit permanently. This is very odd.
So, if i have my lights set to the first setting (just city lights), the turn signals light up with them, but if i have my lights at the 2nd setting, the turn signals go out, and operate as normal.
Basically, i could probably live with this... i'd just have to drive with main lights at all times instead of just city lights, but could this potentially cause problems down the line? Im not going to be putting extra load on other lights am i, causing damage?
Finally, i've seen a lot about resistors... does anyone know what resistors would be required for me to fix this? (Im going from a 12v 5w bulb to a 12v 1w bulb... now i dont know my electronics, but there's a 4w difference there... what rating resistor would i need for that??)
Cheers
Chris.
marzman is offline   Reply With Quote
Old 09-11-2007, 11:26 AM   #2
HighVoltage
My Ride: 2007 335i
Originally Posted by marzman View Post
Hi Guys,
I cant confirm this part of their operation. Hopefully someone else can chime in.
Cheers
Chris.
Keeping in mind that the actual supply voltage may range up to ~14V and down to 12V:
Resistor = (Volt * Volt ) / Power
lower range:
R = (12 * 12) / 5
R = 40 Ohms
http://www.digikey.com/scripts/DkSea...me=CWD-40CT-ND
upper range:
R = (14 * 14) / 5
R = 50 Ohms
http://www.digikey.com/scripts/DkSea...me=CWD-50CT-ND
I would try the 40 Ohms first (even @ 14V, the total power consumed for 40 Ohms is 6W and these are rated for 6.5W) and then move to the 50 Ohm if that doesnt work... BTW , these will get warm unless you can find some in the 10W+ range.
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
