Sponsored by BAVSOUND
Old 09-12-2007, 06:44 AM   #1
IL8APEX
My Ride: E46 ZHP, Triumph 675
12V in Trunk, Part II: Sirius cutting out!
Awhile ago I had asked where the best place is to tap into 12v in the trunk to support the installation of my Sirius / Alpine interface. (Thread HERE)
I elected to use the amp's Yellow wire (constant 12V). For ground I used the common ground behind the CD changer rack. Everything worked smoothly and it fired up first time. However... when I turn up the volume (causing the amplifier to draw more power) the Sirius box stops playing and give me a "Acquiring Signal" message. Once it re-aquires (just a second or two) it plays for a fraction of a second before cutting out again.
I think the amplifier is drawing too many amps and starving the Sirius unit of power. Now I have to find another 12v power source in the trunk. Anyone have the wiring colors handy for the CD changer wires or Bluetooth wires? Sure would be easy to be able to tap into that instead of the amplifier power.
-Tom
IL8APEX is offline   Reply With Quote
Old 09-12-2007, 08:54 AM   #2
ca1242
My Ride: 2003 330i
Yellow wire = constant at the amp?
I believe the constant is a fat red/green wire at the OEM amp. Not sure if this wire goes to sleep though. Check it with a meter.
-Tom
Old 09-12-2007, 09:26 AM   #3
IL8APEX
If I were to guess I'd say it doesn't matter if the wire sleeps because the presets are stored in the head unit. I'll check the fat red/green wire with a meter when I get a chance, maybe over the weekend.
-Tom
Old 07-02-2013, 08:04 PM   #4
BeaMerWorld
My Ride: E46 M3 Cab
Update
Hello,
I am having the same issue and was wondering if you ever found a solution to this problem. My unit is connected to the red/green for constant power. Could you help me out.
BeaMerWorld is offline   Reply With Quote
Old 07-08-2013, 07:31 AM   #5
BeaMerWorld
My Ride: E46 M3 Cab
Ttt
Anyone else ran accross this issue before? Need some help with this.
