Old 09-12-2007, 04:46 PM   #1
The Nebulizer
My Ride: LSB M3 & SC'd 325Ci
my HIDs need projectors
I recently got a 2002 M3 with a really crummy HID install. (I mean really crummy - duct tape etc.) From reading several posts here it seems I need projectors to get the HID to focus properly. (Right now they are pointing down in the reflector housing and stray light is going everywhere).
What options do I have for a relatively cheap upgrade to a projector housing using the HID I have.
(I currently have dual reflector housings in pre-facelift (M3) headlight). I already have some angel eyes, so I don't really need a set with those included for the extra cost.
Do I need to know what brand HID I have? I can't find any label, but maybe a picture would help? (I can post this later if needed)
Thanks for any help you can give me. I am just now learning about all this lighting technology.
The Nebulizer is offline   Reply With Quote
Old 09-12-2007, 05:53 PM   #2
The Nebulizer
Is this what I need?
Bosch e46 ECE Projectors:
How would I install that? Does that go in place of the reflector or inside it or what? Do I need another piece?
Old 09-12-2007, 06:20 PM   #3
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
You could look on eBay and see if you can get the OEM Xenon headlights for a decent price.
Edit - This link should help: http://forum.e46fanatics.com/showthread.php?t=484614
russ330 is offline   Reply With Quote
Old 09-12-2007, 06:47 PM   #4
The Nebulizer
I suppose I need all of this actually, right? (Again, I have the actually HID already, just not mounted properly as I have reflectors.)
These are single xenon, right?
(I am getting so confused by all this terminology - but the High Beams are just reflectors so xenon, right?)
And, these would work in a '02 M3?
I'd only be missing the round decorative trim around the projector.
Am I understanding all of this. Please help me as I am really lost.
Old 09-12-2007, 07:23 PM   #5
russ330
Mod Squad
russ330's Avatar
The ones you just posted are actually bi-xenon projectors (you can tell by the horizontal line in the middle of the projector). You may not necessarily be able to reuse the HID kit you have now with new projectors, because I'm not sure if the bulbs would fit. The HID kit you have should be an H7 (bulb size/fitting) D2R (designed for reflector housings), where as stock projectors would use D2S (for projectors) I don't quite remember what the socket (i.e. H7, 9006, etc).
Old 09-12-2007, 07:27 PM   #6
The Nebulizer
I checked the bulb and it looks like the D2S kind of bulb - from what little I know. It has a metal piece that is round with a single tab. I believe H7 has 2 tabs.
So, I couldn't use this Bi-Xenon projector setup, then?
Old 09-12-2007, 07:34 PM   #7
russ330
Mod Squad
russ330's Avatar
Well looking at the thread that I posted it looks like retrofitting the projectors into the car is do-able, the problem is using your HID kit with the projectors. I suppose you could get new bulbs for your kit (they usually run about $100).
So if you tally up the prices for new bulbs ($100), the chrome projector bezels ($150), the projectors (including the bracket with the high beam assembly) ($150), you're well on your way to purchasing a set of OEM headlights.
Now granted with the exception of the bulbs I pulled the prices right off of eBay (using the first ones I found) so you may be able to find things cheaper if you shop around. I just wanted you to be aware of what you may be getting into and what type of prices you may be looking at.
Old 09-12-2007, 08:41 PM   #8
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I would honestly recommend a complete headlight replacement like our Projector46 headlights. These are comprehensive in that they include everything you need for the install and provided your current HID kit is H7 and undamaged, it could be retrofitted into the Projector housing. These also include preinstalled and built in Predator series angel eyes so you get the added benefit of a cosmetic upgrade.
Old 09-12-2007, 10:33 PM   #9
m3m3me
My Ride: 2002 M3
[IMG]http://jlevistreetwerks.com/store/images/p46%20sedan.jpg
P46s Rock! I converted my inside HIDs into bi-xenons! You Can Do It!!
ID:	242161   Click image for larger version
m3m3me is offline   Reply With Quote
Old 09-13-2007, 09:26 AM   #10
HighVoltage
My Ride: 2007 335i
Theres also the problem that if he is using the halogen housings he will also have to get a couple small misc pieces to properly mount those reflector bowls, in addition to the items you listed. Heres a link outlining those pieces:
http://www.mybimmer.net/OptimoXenonR...onRetrofit.htm
Also it seems the bi-xenon mechansim requires a bit more room in the housing than the halogen or regular xenon . So you either have to remove the bi-xenon mechanism or hack up the housing.
Actually that could be kind of a problem Nick. He already has angel eyes and would in effect be paying for another pair. Unless I am mistaken, he should also be aware that the projector46s are not bi-xenon. I dont know about The Nebulizer, but these are two things that have held me back from purchasing the projector46s.
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
Old 09-13-2007, 12:09 PM   #11
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Most of our customers who currently have angel eyes sell them in the classifieds and use that towards the purchase of the P46s. Bixenons are also a bit more difficult to retrofit as you need to run the extra wiring and reprogram the ECU.
