Old 09-25-2007, 11:23 AM   #1
n2Bimmer
My Ride: Loves Corners
Weird Dim Angel eyes
hey fellas, i want your opinion guys, for 2 weeks my right side AE's (pred Chrom) have been dim on only one of the rings on the xenon side, the corner of the ae is dim and it fades getting brighter, so when i called the sponsor he said swith the balast, so i did, after switching to the other side the lights on the other side were okay, so i guess the ballast is okay?, do you guys think its the AE rings
Old 09-25-2007, 11:51 AM   #2
sstainba
My Ride: 02 325Ci
the electrode in the ring could be corroded which could cause this.
sstainba is offline   Reply With Quote
Old 09-25-2007, 12:04 PM   #3
n2Bimmer
huuu? whats an electri code.?? hey wats up nick maybe you can chime in. And it is NOT a cold start issue. Tnx alot guys.
Old 09-25-2007, 01:32 PM   #4
sstainba
My Ride: 02 325Ci
the electrode is the piece of metal on the inside of the ring that passes the electricity into the gas. if they become corroded, it affects the efficiency of the ionization of the gas. that can make the ring go dim. if this is the case, you'll need a new ring.
Old 09-26-2007, 11:07 AM   #5
n2Bimmer
tnx bud,anyone else, any other thoughts.
Old 10-04-2007, 12:15 PM   #6
tas
My Ride: Y2K AA SC 323i
I think I have the same issue. I got the red (Pred Chrom)from Umitza. The issue started on the first day I installed it. I have contacted him and he said send him $10 for new Ballast. I even hard wired it and used the spare ring that came in the box. Damn thing is still dim!
tas is offline   Reply With Quote
Old 10-04-2007, 04:36 PM   #7
sina518
My Ride: E46 M3
same problem
sina518 is offline   Reply With Quote
Old 10-04-2007, 07:12 PM   #8
sillieidiot
My Ride: '06 AW 330ci
bad ring, or your connections aren't secure. by connections i mean the positive and negative leads aren't getting a good connection
Old 10-08-2007, 03:42 PM   #9
islanq
My Ride: An E46 like you...
Send a message via AIM to islanq
I had the same issue, went through 3 rings, 2 ballast. The only way to get around this is to solder your connections.
Even Matt @ Umnitza will tell you this.
/Thread
islanq is offline   Reply With Quote
Old 10-08-2007, 04:29 PM   #10
n2Bimmer
um k txn guys, its still the same till this day.
Old 10-08-2007, 04:30 PM   #11
n2Bimmer
so its not the ring or the ballast???
Old 10-08-2007, 04:42 PM   #12
tas
Nope. I hard wired it as well.
Old 10-08-2007, 07:42 PM   #13
islanq
I notice I get one dim ring per side if the wires are too close together to for some reason. I don't know why in hell it would matter but when I seperate them it seems to help.
Old 10-09-2007, 10:58 AM   #14
n2Bimmer
cool ill try that.
Old 10-10-2007, 07:07 PM   #15
HighVoltage
My Ride: 2007 335i
Which wires? The wires going to the ballast from the 12V or the ones coming out of the ballast to the rings?
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
Old 10-10-2007, 07:14 PM   #16
n2Bimmer
ya which ones.
Old 12-30-2007, 03:37 PM   #17
entcee
My Ride: 2002 325i Sedan
When I installed my angel eyes this weekend I noticed this as well. It is the wires coming from the ballast to the rings. If I were to place a + wire next to a - wire, the ring would dim.
entcee is offline   Reply With Quote
Old 02-18-2008, 02:51 PM   #18
manhattanprjkt83
My Ride: 330xi
Ok I just had my umnitza's PRED CHROM's installed on Friday...
Having the same problem as described above with one of the rings dimly lighting (some of the time), occasionally it will turn on full power.
Like I said these are brand new, what is the real solution here do I eliminate the connectors? Please help this is really annoying, I didn't expect this from a quality product like this.
Thanks.
www.williamkirk.com <-That's Me
330xi aka the joint
manhattanprjkt83 is offline   Reply With Quote
Old 02-18-2008, 03:24 PM   #19
manhattanprjkt83
My Ride: 330xi
I am really hoping i can fix this without inputing a new ring, i dont want to have to take the ring out and put in a new one, that is one of the things that made me want a complete sealed unit, i dont trust myself to be doing that kind of work inside the headlight...
can someone please help me with this? Thanks.
330xi aka the joint
Old 02-18-2008, 03:27 PM   #20
sillieidiot
you don't have a sealed headlight, it should be easy as pie. and if you were to get a completely sealed unit, it would be a ***** to replace the ring once it goes out.
