Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
Rating:
Display Modes |
#181 |
it seems as though this issue mainly affects sedans, though i'm getting the same error on my coupe. Does anyone know where I can ground the wire to on a coupe with upgraded aftermarket LED tails? I can take what ever pics you guys will need.
#182 |
I'm trying to clean off the plugs on the 8-pin connector in my tail lamp. Can anyone explain what the trick is to get the wires/plugs to release from the connector housing? The dealer says it requires a special tool, but people here seem to be removing them with no difficulty. I'm tryng tweezers to compress the two flanges on the plugs but with no luck. Thanks.
#183 |
Can i use 22 instead of 18 guage
well anyways i did but is it safe? |
#184 |
I just did the taillight fix. It took longer to gather the tools than to do the fix!
#185 | |
Thanks ssm1991. Your taillight fix worked perfectly. I use to get intermittent lamp failure and when I activated my turn signals it would blink rapidly. Your instructions fixed everything.
Thanks so much you saved me a ton of dough and frustration. Quote:
#186 |
2005xi Touring
I am a new BMW owner and so working on this car is still new to me. I would assume that this fix would work for the wagon as well? I have the flickering drivers side headlight. Should I start looking at the drivers side tail light assembly, like is there a correlation between the side of the flickering light? Removing the tail light assembly I assume is pretty easy once the panel covering the area is removed?
Thanks guys and gals for a great thread! |
#187 | |
As with shock29's situation my lp bulbs fell out in my hand and the parts must be replaced. Anyone know where I can look to find the license plate lamp parts? -Mark |
#188 |
Great fix. You guys rock! One thing I did different: I simply cut the brown wire instead of trimming off the insulation. I then used a wire nut to connect the end of the brown wire running from the vehicle to the new wire. The other end of the new wire runs to the metal frame of the light fixture. As mentioned above, getting the tools and supplies took longer than making the repair.
You guys made my weekend. I hate taking my vehicle to a mechanic. I'd much rather fix it myself. |
#189 |
Is it ok to completely unplug the brown wire from the 8-pin connector and connect it to the ground tab of the taillight? It is the way it was done by the dealer on my car.
#190 |
#191 |
Is pOst#188 above your post the same solution. looks like it worked for him. Someone, pls correct me if I am wrong.
#192 |
Yeah, it sounds like the same way it was done by dealer (while on warranty) on my car. For me it looks like acceptable solution, but need a confirmation.
#193 |
THANKS to ssm1991
His fix and info was invaluable...did same on my 2003 325i & all is AOK now! Will try and and attach 3 pix of my repair job... ...couldn't seem to attach pics Last edited by wranders; 04-10-2011 at 03:27 PM. Reason: ...couldn't seem to attach pics |
#194 |
Just did mine this weekend. Working like a charm. The ground from car bypasses the plug and goes straight into the metal of the bulb housing. Had the bulb out light on the dashboard, but disappeared after the first time I hit the left/right turn indicator lights on.
#195 |
grouind issue can cause BIG problems
i was reading your post i know its been a long time and you may not even opwn your bmw anymore ,but had to respond .i bought my first and probably last BMW 01 330cic recently ,i knew i had a few issues to deal with tires, brakes and cel light but the taillight issuer on mine turned into a huge mess .i had the red light of death at light go on several times and drop to failsafe ,my battery light was blinking and several other lights led me to beleive i had a short or something . I checked the rear light socket and sure enough burnt connector and brown ground wire , i ordered anew housing after calling BMW dealwer and they told me i could only buy fix kit consisting ofboth housings and connectors etc for 200.00 plus . I am getting a real bad taste in my mouth with this issue (fire hazard ) and the transmission consumer repot posts of the hundreds probably thousands that have had trans troubles with as littlwe as 20000 miles BMW says there not aware of any trans troubles at all .How could a luxury auto maker have such deceptive policies and customer service be sooo bad . i ordered a new bulb housing from AM Auto but thery sent the wrong one ,i have to try to find another supplier as dealer or should i say stealer wont sell any of the parts seperate
frustrated in kentucky tom |
#196 | |
Luxury auto maker doesn't care about small potatoes for those that go and buy a 10 year old car and expect it to be brand new. They will always have followers and those that curse them as they fix their cars. Good luck with your search for fixes--the one good thing about BMW ownership is that there is a large fan base, and plenty of DIYs to go around. Try the other forums to help expand your exposure and soon enough you'll be your own master mechanic. |
#197 |
Rear tail lights ground issue
Hi,
I've 2004 325i and was facing the same problem. I did all the steps as shown in the pictures and wow! lights were all gone and everything looked perfect. I simply cut the brown wire and grounded that to the tab using a spade connector. But after 10 days, the tail light in the dash board came up again although all lights are working fine and then next day my car won't start. Checked the battery with AAA and they told that there is drainage in battery of 2.64 A. Can someone please tell me if grounding the wire on the tab causing this drainage?? has anyone faced the same issue after grounding the wire? |
#198 |
tailight
i fixed my tailight the other day ,using a couple of parts from the hardware store and a new piece of wire .i puchased the new bulb carrier from getbmwparts.com and all my lights work now but still have the dash ones on . go figure oh well ill have to do some more cyfering on this one .
#199 |
I have a question if my plug housing where #3 is already burned and also the carrier plug housing is somewhat can i do this DIY and will it work or do I have to buy another plug housing
[SIGPIC]
#200 |
For some reason my 99 323 does not have that "tab" in which apparently everybody has grounded their new wire to. Where should I ground mine if this tab is not present? I've looked at it 200000 times and can't seem to find that little tab.
